Date/Time: Tue, 22 Apr 2025 02:21:37 +0000
Replay
View Count: 294
[2023-02-27 15:16:43] |
User936653 - Posts: 5 |
When i have multiple of the same charts up during replay, some seem to be at different times... is there a way to make it so all the charts run at the same time and speed?
[2023-02-27 17:59:50] |
As long as you select multiple charts for the replay using one of the options here: Replaying Charts: Charts to Replay And do not use the option for Skip Empty Periods: Replaying Charts: Skip Empty Periods Then you should be fine. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
