Date/Time: Tue, 22 Apr 2025 02:21:35 +0000
Data for charts
View Count: 269
[2023-02-27 15:16:01] |
matt rataj - Posts: 2 |
Hey guys so quick question. i use ninja trader to trade.. is there a way that i can use sierra for charting and use whatever data services you guys use for real time data? im not looking to connect ninja to you guys. i dont need to do that. Whatever data providers you guys use is fine, i just want real time data to chart. Thanks guys
[2023-02-27 17:15:03] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Be sure to read the page linked above completely before making a further inquiry regarding real-time *futures* data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
