Date/Time: Tue, 22 Apr 2025 02:24:38 +0000
Volume Filter
View Count: 274
[2023-02-27 15:12:48] |
xdoniox - Posts: 2 |
Thank you very much for information. Now I see packege nr 12. But I still in Volume Filter Settings I cant exclude some data. I see all or nothing. I was shure that packege 12 gives me tick data and I will exclude low orders to see only big , but I cant. Could you explain me what I need to use VOLUME FILTER? Regards TOM |
[2023-02-27 17:11:51] |
If you are referring to filtering Market by Order data, then refer to the following: Market By Order Data: Adjusting Minimum Quantity to Display for Market by Order Data Otherwise, if you are referring to filtering the volume in general, then refer to the following: Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
