Date/Time: Tue, 22 Apr 2025 02:21:38 +0000
market depth
View Count: 288
[2023-02-27 09:48:30]
pdom86 - Posts: 4
Hi.
I am experiencing problem with market depth DOM data. it only shows values of 2 current traded ticks but does not show any other awainting orders like it used to before. I have package 11 so I am not sure where the issue is as I have not changed any settings.
imageScreenshot_1.png / V - Attached On 2023-02-27 09:47:28 UTC - Size: 96.4 KB - 84 views
[2023-02-27 16:04:13]
John - SC Support - Posts: 39395
You do not have any exchanges active on your account for our Denali Exchange Data Feed, therefore you are getting your data from your trading service.
If you want the Denali data, then you need to activate the exchange(s) you want at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
