Date/Time: Tue, 22 Apr 2025 02:24:33 +0000
What exchange to activate for indexes that above 20, 50, 200 moving averages.
View Count: 329
[2023-02-27 03:26:50] |
lovelivelaught - Posts: 70 |
Hello I could not figure out what exchange I should activate to get a real time data for indexes that above 20, 50, 200 moving averages. Specifically I am looking for Nasdaq and S&P sectors. Would it be a part of Nasdaq and S&P indexes exchanges Thank you in advance. |
[2023-02-27 08:36:27] |
Sierra_Chart Engineering - Posts: 19290 |
We are not sure what symbols you are referring to, but we do not think there is real-time data for what you are referring to.
[2023-02-27 18:46:57] |
Exaple $NDTW, $DITW, $MMTW, $S5TW - major indexes above 20 moving average
[2023-02-27 22:25:47] |
For those 4 symbols there is data available, although it will be delayed data. This just happens to be available from our provider for the indices at this time. You would have to check if others are available by opening a chart for the symbol.
