Date/Time: Tue, 22 Apr 2025 02:24:39 +0000
DOM & Chart - P/L mismatch
View Count: 377
[2023-02-27 02:36:24]
LeTigre - Posts: 2
I'm having some difficulty with how the P/L is displayed on the chart after I enter a trade. I'm sure I'm doing something wrong but can't find a solution in the forum or guide.
I'm trading F.US.MNQ on the DOM and would like the trade to appear on the F.US.ENQ chart. The P/L in the DOM (MNQ) does not match the P/L on the chart (ENQ). It appears as if the P/L on the chart is double. P/L on the DOM is 3.50P and the P/L on the chart is 7. There's no pattern to the difference. Almost as if there is a delay between the DOM and the chart
Chart Settings
Symbol: ENQ
Trade and Current Quote Symbol: MNQ
Use as Trade Only Symbol: Yes
Currency Value Per Tick: 0.5
Show Order Fills and Positions are checked on the chart
Thank you
[2023-02-27 05:33:30]
LeTigre - Posts: 2
These are the resources I've checked so far today
Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu)
Profit/Loss Calculations and Symbol Settings
Date Time Of Last Edit: 2023-02-27 08:37:26
[2023-02-27 08:45:10]
Sierra_Chart Engineering - Posts: 19290
Yes these are correct:
Chart Settings
Symbol: ENQ
For additional information, refer to:
Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu)
