Date/Time: Tue, 22 Apr 2025 02:21:37 +0000
Change delta profile numbers
View Count: 391
[2023-02-26 23:15:00] |
OriolCasas - Posts: 189 |
Hello, See picture attached, the delta profile on the left. How can I change the size and color of the letters of the delta profile? Thank you |
[2023-02-27 08:03:15] |
Sierra_Chart Engineering - Posts: 19290 |
Are you referring to the Numbers Bars study or the Volume by Price study?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-02-27 08:03:20
[2023-02-27 09:10:15] |
The volume by price study.
[2023-02-27 16:01:11] |
Refer to the following: Volume By Price Study: Volume Numbers Text Color and Size (SG7) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
