Date/Time: Tue, 26 Nov 2024 19:56:08 +0000
Go To Date and Time
View Count: 2179
[2014-06-12 18:02:24] |
GCAdmin - Posts: 35 |
Is there a feature other than the replay option that allows you to go to a specific date and time for all charts in a chartbook at the same time? We know that you can use the CHART>> GO TO option for individual charts, but if I have say 3-4 charts in a chartbook and want them all to go to a specific time and date without it being a replay is there an option to do them all at the same time? Thanks! |
[2014-06-12 18:48:17] |
This can be accomplished by linking the Scroll Position between the charts. Refer to this section here about chart linking: http://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#ChartLinking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
