Date/Time: Tue, 22 Apr 2025 02:24:38 +0000
Trade window for chart issue
View Count: 402
[2023-02-26 20:36:19] |
OriolCasas - Posts: 189 |
Hello, I am having issues with my chart trading window. It moved somehow to an edge of the chart and there is no way I can put it in the right place, Obviously I tried to delete it and and then go to trade - open trade window for chart and it appears on the exact same place. How can I move it? Thank you |
[2023-02-26 21:05:28] |
ondafringe - Posts: 322 |
See if "Trade > Attach Trade Window to Chart" is checked.
[2023-02-26 21:10:56] |
That's actually not a proble, the problem is when I detach trade window from the chart itself. If I attach to trade window to Chart it works fine. But I want to have the trade window detached. Thank you |
[2023-02-26 21:50:35] |
If you uncheck "Trade > Attach Trade Window to Chart" the trade window will "detach" and you should be able to move the trade window to wherever you want.
[2023-02-26 21:57:07] |
I did that AS EXPLAINED on the first message
[2023-02-27 08:46:12] |
Sierra_Chart Engineering - Posts: 19290 |
Reset it with this command: Chart Menu: Reset Child Window (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-27 09:23:46] |
I just made sure Global Settings >> Tool Settings >> General >> Save Tool Values Window Position for Each Chart: is enabled But the chart trade menu is still of screen, is tehre anything else I need to do? Thank you |
[2023-02-27 11:13:04] |
So resetting the Child Windows, did not resolve the problem with the Chart Trade window itself being offscreen? It should.
[2023-02-27 14:49:01] |
No it didn't
