Date/Time: Tue, 22 Apr 2025 02:21:37 +0000
ø
View Count: 292
[2023-02-26 18:23:29] |
sgne - Posts: 109 |
ø
Date Time Of Last Edit: 2024-12-05 04:16:27
[2023-02-26 18:48:30] |
Sierra_Chart Engineering - Posts: 19290 |
What we can do is at 3 additional decimal places for the microseconds. So this would be 6 places shown after the second. There would not be any separate column provided. It will just be the actual microsecond component. We cannot prevent that: And column 2 should have no millisecond value at all before 20200822.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-02-26 18:49:28
