Date/Time: Tue, 22 Apr 2025 02:21:40 +0000
Chart replay
View Count: 299
[2023-02-26 16:37:18] |
User117194 - Posts: 17 |
Hi, My chart replay control p[anel will not load I use ctrl-R and nothing happens, likewise when I select it form toolbar up the top? Thanks |
[2023-02-26 16:38:27] |
Sierra_Chart Engineering - Posts: 19290 |
Refer to: Window, CB and CW Menus: Reset Windows (Window) If that does not resolve the issue update to the latest release and then select Chart >>Reset Replay Control Panel Window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
