Date/Time: Tue, 22 Apr 2025 02:27:41 +0000
Inconsistent DOM replay
View Count: 375
[2023-02-26 02:39:29] |
sean.sean - Posts: 5 |
Hi, I often replay the DOM with my chart. Some dates that I go to replay show accurate price action movement (and to add to that I have never had a DOM replay misaligned with the the date of replay), but it does not show any resting orders on the DOM. I can't figure out why some days I am seeing the full replay of the DOM, and on other only price action with no orders. Any idea what I am missing/doing wrong? I use the Market Depth Historical Graph, and all of my chart setting for the DOM and the linked chart are exactly the same. This lead me to believe it could be something as simple as missed "Save" when closing the software, which is possible. Thank you for your time, SC is phenomenal. Sean |
[2023-02-26 10:23:43] |
Sierra_Chart Engineering - Posts: 19290 |
At the Date-Times where you are not seeing market depth data, you need to use the Market Depth Historical Graph and see if there is market depth data available. Refer to: Market Depth Historical Graph: Market Depth Historical Graph Not Displaying Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-02-26 10:23:51
