Date/Time: Tue, 22 Apr 2025 02:27:40 +0000
Widen chart value scale
View Count: 330
[2023-02-25 20:21:13]
OriolCasas - Posts: 189
How can I widen the chart value scale?
Thank you
imagewIDER CHART VALUE SCALE.png / V - Attached On 2023-02-25 20:21:08 UTC - Size: 61.1 KB - 93 views
[2023-02-27 15:08:10]
John - SC Support - Posts: 39395
You can not directly control the width of the Price Ladder. But, since it always sizes to the size of the pricing, you can change the number of digits that are displayed with the price, which would increase the width of the column. Just keep in mind this will change the way the pricing is displayed throughout the system, so it may not be what you want. Refer to the following:
Chart Settings: Price Display Format (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
