Date/Time: Tue, 22 Apr 2025 02:24:37 +0000
Customize Keyborad Shortcut for - Save all Charts from the actual ChartBook to file
View Count: 449
[2023-02-25 19:18:08]
User230940 - Posts: 121
would it be possible to get an additional Keyboard Shortcut?
I would like to have the possibilities to get a Screenshot from all Charts within the actual Chartbook.
If you have 4 Chart open in the actual Chartbook, than you will get 4 images.
Would this be possible?
I would help me a lot.
I would like to the use the UDP Interface but this works different from my understanding.
Thanks for your short feedback
best regards
[2023-02-25 19:31:43]
Sierra_Chart Engineering - Posts: 19290
This is involved for us to implement. We will see though.
You can do this using ACSIL with this function:
void sc.SaveChartImageToFileExtended(int ChartNumber, SCString &OutputPathAndFileName, int Width, int Height, int IncludeOverlays);
Date Time Of Last Edit: 2023-02-25 19:32:24
[2023-02-25 19:41:18]
ThiS ACSIL would become a study in each Chart, right?
And how should I trigger the ACSIL Function?
Today I execute my Trades via Shortcuts through my keyboard. I am able to set macros to my keyboard. And instead of sending the "open trade command" only I would send a seconds shortcut for take images afterwards.
This means everything would be done in background without any kind of losing focus.
thanks
