Date/Time: Tue, 22 Apr 2025 02:27:40 +0000
Disable downloading Historical Order Fills on Connect from External Server
View Count: 393
[2023-02-25 17:55:50]
rahul - Posts: 172
Hi, I am using Sierra Chart with CME Teton Order Routing + Denali data feed.
I noticed today that my position data did not update in time, which caused issues with my code.
It seems like I could rectify this by enabling "Use Order Fill Calculated Position" instead. How do I disable order fills from being downloaded by Dorman / Teton?
There is no such setting anymore "Global Settings >> Data/Trade Service Settings >> Trade Settings >>Download Historical Order Fills on Connect"
Thank you.
[2023-02-25 19:34:43]
Sierra_Chart Engineering - Posts: 19290
Why did the position data not update in real time? There should not be any issue with this.
Check Global Settings >>Sierra Chart Server Settings >>Maximum Historical Order Fills Days to Download.
Date Time Of Last Edit: 2023-02-25 19:35:00
[2023-02-25 19:41:05]
rahul - Posts: 172
I don't understand why. It seems like the s_SCPositionData structure, where I retrieve the Open Quantity, Last Trade Profit Loss etc was not updated instantly (like it does in simulated trading).
So when I run the backtest for the same day, it works fine with my study...but in Live Trading it gave me issues, which I believe is because of what I mentioned above.
Currently I have Max Historical Order Fill Days to Download = 124. Should I set this to 0?
I plan on using the "Use Order Fill Calculated Position" feature.
[2023-02-26 10:31:40]
This is the exact variable you are referring to:
s_SCPositionData.PositionQuantity
Refer to:
Automated Trading Management: Differences Between Live Automated Trading and Simulated Automated Trading
If you want to not download historical order fills then yes:
However, at least one day might be downloaded anyway.
Date Time Of Last Edit: 2023-02-26 10:33:50
[2023-02-26 12:57:09]
rahul - Posts: 172
Yes, I am referring to: s_SCPositionData.PositionQuantity
Is there any other setting I should consider turning ON/OFF when using "Use Order Fill Calculated Position". I assume by using this feature, Sierra Chart will use its inbuilt trade stats instead (just like simulated trading). Since I am using Market Orders mostly, I want to be sure the data received from the trading service doesn't override SC Stats.
