Date/Time: Tue, 26 Nov 2024 19:43:39 +0000
Setting a chart within a chart
View Count: 1032
[2014-06-12 15:46:57] |
EthanC - Posts: 44 |
Hi, Is there a way to set a sub-chart within a main chart? I.e ES ----------- NYSE Tick ----------- Advance-Decline Line ----------- Volume |
[2014-06-12 16:57:46] |
Yes. Refer to: http://www.sierrachart.com/index.php?l=doc/SCMarketStatistics.php#Overlaying In the case of the Volume, that is just a study. So you just add the Volume study to the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
