Date/Time: Tue, 22 Apr 2025 02:27:41 +0000
NUMBER BARS SETTINGS
View Count: 420
[2023-02-25 00:42:23]
AMINE BERRECHACH - Posts: 26
I attempted to recreate a trader's chart but encountered an issue only with the first column
Although the indicator assigned importance to all delta values, I only want the high delta values to be clearly highlighted
I want to emphasize only the significant values (Delta) and disregard the smaller ones to visualize absorption better
I suspect this issue is related to the compare threshold setting, I tried adjusting the compare threshold to different values, but there was no change in the outcome.
I wish to recreate the initial image, whereas the second one depicts my own creation.
Could you please assist me with this?
Date Time Of Last Edit: 2023-02-25 00:48:40
Private File
imageESH23-CME[M] Renko 8t #4 2023-02-24 19_46_38.022.png / V - Attached On 2023-02-25 00:48:08 UTC - Size: 116.69 KB - 106 views
[2023-02-26 12:19:19]
ticinotrader - Posts: 411
Hi Amine,
If you are a member of my site, you can anytime contact me with questions regarding the chartbooks I create. I very frequently help members to adjust existing chartbooks for their needs.
The content of the chartbooks is not locked in any way, so you can simply download them and adjust/modify them for your needs - all the settings are provided/open as well. So you can save some time...
I suppose you try to reverse-engineer the chartbook here:
https://www.ticinotrader.ch/multi-column-footprint-chartbook-for-es-and-zb/
Regards,
tt
image20221213_104558.png / V - Attached On 2023-02-26 12:19:03 UTC - Size: 171.3 KB - 80 views
[2023-02-26 12:25:08]
Thank you
I was a member of your site but my membership came to an end
I wonder if you can just tell how to use the compare threshold to give importance to just the high deltas
[2023-02-26 12:36:50]
Sure Amine, just drop me an email through my website's contact page.
