Date/Time: Tue, 22 Apr 2025 02:27:41 +0000
Chart Calc Tool
View Count: 324
[2023-02-24 23:57:45] |
Crtfyd - Posts: 281 |
vs 2458 Ive just noticed that the Chart Calculator Tool when in a different region other than Main graph doesn't work when Angle is checked.The indicator that I noticed this in is the Accumulation/Distribution Flow. |
[2023-02-27 14:45:08] |
We are not able to reproduce this. Please update to the current release and let us know if you have the same issue. Refer to the following for how to update: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
