Date/Time: Tue, 22 Apr 2025 02:18:43 +0000
Unable to activate trial
View Count: 339
[2023-02-24 17:45:16] |
Srinivasa Kancharla - Posts: 4 |
I still see Rithmic Direct package is not enabled. Could you please enable it on my trial. Thanks, |
[2023-02-24 18:44:07] |
When you are on a Trial, you are not able to connect to a trading service. To do this, you need to be on one of our Integrated packages. We have set your account to be on the Integrated Advanced with MBO package (Package 12) for the remainder of your trial time. As such, you can now connect to Rithmic. Refer to the instructions at the following link for how to connect your Sierra Chart to Rihtmic: Rithmic Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
