Date/Time: Tue, 22 Apr 2025 02:27:40 +0000
File and Edit Tabs Not Active
View Count: 295
[2023-02-24 13:55:31] |
DaveInMT - Posts: 4 |
When I open SC, all menu tabs are active except the File and Edit tabs. They are greyed out and can't be selected. Started yesterday. Not sure what I did wrong. I tried closing and opening the program, but get the same result. Thanks |
[2023-02-24 15:05:57] |
Sierra_Chart Engineering - Posts: 19290 |
So it is not possible to left click on the File menu and have it open up? Never heard of that before. Have you tried restarting your computer. We really do not know what the issue is. Nothing in Sierra Chart would cause those pop-up menus to become disabled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-24 16:06:30] |
Okay, rebooting worked. I should have tried that first. My apologies. Thanks!
