Date/Time: Tue, 22 Apr 2025 02:27:37 +0000
quote board
View Count: 293
[2023-02-24 13:10:32] |
TheFibber - Posts: 83 |
i loaded all the s&p500 list in the quote board . is there a funcion to update all the stock in the list without passing over every stock one by one? i thought it would do for me the 'scan function' but it doesn't do..could you help me?
[2023-02-24 15:40:39] |
We are not understanding the question. The Quote Board will automatically update the information for all the instruments listed in it. If you are wanting to view the charts for each stock, then that is what the Scan function will do for you. Also - we notice that you are not setup to get any real-time data for stocks from us. Therefore, if you are not getting the data from your trading service, then you would not get any updates to the Quote Board as you are not setup to get real-time data for stocks. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-02-24 15:41:47
