Date/Time: Tue, 22 Apr 2025 02:18:42 +0000
Sierra Chart will be discontinuing the FXCM trading service on March 31, 2023.
View Count: 482
[2023-02-23 22:25:35]
User744934 - Posts: 6
Thanks for your message. If i understood correctly, you will stop feed and trading from FXCM? correct?
If yes which alternative do i have for CFD trading products?
I have already payed for months subscription.
Thanks in advance!
[2023-02-24 07:31:21]
Sierra_Chart Engineering - Posts: 19290
No this is not correct!
The message made it very clear that market data from FXCM will still be supported. Only trading direct to FXCM, which next to no one uses just like three or less users use from time to time.
Refer to the message you received. We gave information answering your question. We said Interactive Brokers and LMAX.
Date Time Of Last Edit: 2023-02-24 07:31:43
[2023-02-24 10:31:08]
Calculus - Posts: 109
Few, I mis-read the original message.
So the FXCM data feed will still be working whereas the direct trading to FXCM will be discontinued.
Great news as I only use the data.
Well done, FXCM data really helps the overall Sierra package.
[2023-02-24 11:33:52]
Yes this is correct.
