Date/Time: Tue, 22 Apr 2025 02:24:34 +0000
Changing chart number
View Count: 579
[2023-02-23 21:36:04] |
OriolCasas - Posts: 189 |
Hello, How can I change the chart number? Thank you |
[2023-02-23 21:53:52] |
You can not directly. The best you could do is to duplicate a chart and it will take the next available number, starting from the lowest number. For example, if you have chart numbers 1, 2, 5, 7, then when you duplicate a chart, it will be chart #3 (then 4, then 6, then 8, 9, 10, etc.). So you would have to duplicate until you get the number you want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
