Date/Time: Sat, 19 Sep 2026 04:15:54 +0000
[Programming Help] - Donchian Channel
View Count: 761
[2023-02-23 20:19:33]
User509820 - Posts: 69
Hello, I am trying to change the donchian channel to create the the channel using the body of the candles instead of the high/lows. For example highest open/close for the top and lowest open/close for bottom channel. Is there a way to create this custom study?
[2023-02-23 20:43:42]
John - SC Support - Posts: 47939
You would have to modify the source code to do this. This study is available in the file studies7.cpp which is located in your ACS_Source folder under the main Sierra Chart folder.
Refer to the following for how to build a custom study:
How to Build an Advanced Custom Study from Source Code
[2023-02-24 18:40:31]
Found it, what exactly would I need to change to get it to perform this way indicated.
SCSFExport scsf_DonchianChannel(SCStudyInterfaceRef sc)
  SCSubgraphRef Subgraph_HighestHigh = sc.Subgraph[0];
  SCSubgraphRef Subgraph_LowestLow = sc.Subgraph[1];
  SCSubgraphRef Subgraph_Midline = sc.Subgraph[2];
  SCInputRef Input_Length = sc.Input[3];
  SCInputRef Input_UseClose = sc.Input[4];
  if (sc.SetDefaults)
    sc.GraphName = "Donchian Channel";
    sc.GraphRegion = 0;
    sc.AutoLoop = true;
    Subgraph_HighestHigh.Name= "Highest High";
    Subgraph_HighestHigh.DrawStyle= DRAWSTYLE_LINE;
    Subgraph_HighestHigh.DrawZeros= true;
    Subgraph_HighestHigh.GraphicalDisplacement= 1;
    Subgraph_LowestLow.Name = "Lowest Low";
    Subgraph_LowestLow.DrawStyle= DRAWSTYLE_LINE;
    Subgraph_LowestLow.DrawZeros= true;
    Subgraph_LowestLow.GraphicalDisplacement= 1;
    Subgraph_Midline.Name = "Mid Line";
    Subgraph_Midline.DrawStyle= DRAWSTYLE_LINE;
    Subgraph_Midline.LineStyle= LINESTYLE_DOT;
    Subgraph_Midline.DrawZeros= true;
    Subgraph_Midline.GraphicalDisplacement= 1;
    Input_Length.Name = "Length ";
    Input_Length.SetInt(5);
    Input_Length.SetIntLimits(1, MAX_STUDY_LENGTH);
    Input_UseClose.Name = "Use Close instead of High and Low";
    Input_UseClose.SetYesNo(false);
    return;
  float Lowest = FLT_MAX;
  float Highest = -FLT_MAX;
  if (Input_UseClose.GetYesNo())
    for (int BarIndex = sc.Index - (Input_Length.GetInt() - 1); BarIndex <= sc.Index; BarIndex++)
      Highest = (Highest < sc.Close[BarIndex]) ? sc.Close[BarIndex] : Highest;
      Lowest = (Lowest > sc.Close[BarIndex]) ? sc.Close[BarIndex] : Lowest;
  else
      if (Highest < sc.High[BarIndex])
        Highest = sc.High[BarIndex];
      if (Lowest > sc.Low[BarIndex])
        Lowest = sc.Low[BarIndex];
  Subgraph_HighestHigh[sc.Index] = Highest;
  Subgraph_LowestLow[sc.Index] = Lowest;
  Subgraph_Midline[sc.Index] = (Highest + Lowest)/2.0f;
