Date/Time: Tue, 22 Apr 2025 02:18:40 +0000
tradestation question regards Sierra
View Count: 915
[2023-02-23 19:18:46] |
User729169 - Posts: 1 |
Hey SIERRA, how are you doing guys ?, I hope you are fine I have an futures account at tradestation, can I use the SIERRA software with Tradestation , I mean to get the Real - time quotes ? Tnx in advance Noam Erlichman Publicity support: User729169 Account name: noamer |
[2023-02-23 20:37:07] |
Hello User729169 - We are doing fine thank you. We hope you are as well. Unfortunately you can not use Sierra Chart with Tradestation either for trading or to verify your account for the non-professional CME Group requirement. The reason for this is that Tradestation has stopped support for Sierra Chart, even though they use CQG for order routing (which we can connect to). If you just need an account for the CME Group requirement, then we recommend the solution outlined at the following link, where you can open an account for as little as $100: Easy Solution to CME Funded Trading Account Requirement For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
