Date/Time: Tue, 22 Apr 2025 02:27:41 +0000
Not receiving Market Depth Data when I am subscribed to it
View Count: 361
[2023-02-23 15:04:08]
Julio_Bourse - Posts: 4
The problem I have is that I don't have market depth on my DoMs. Usually I had full depth on bid and ask and now I don't have it anymore.
Here you can find my DoM with the problem https://www.sierrachart.com/image.php?Image=1677164356983.png
[2023-02-23 15:23:14]
SC Support - Posts: 1955
First thing - is that an ES Futures chart in your screenshot?
Second - If it is a CME exchange product (like ES Futures), then please go through the following:
File Menu: Not Receiving the Full Number of Market Depth Levels
[2023-02-23 15:35:20]
Yes I checked the settings on the chart are correct in my opinion. Can we do remote assistance?
[2023-02-23 15:40:21]
Ok i can't explain how but it's ok right now.
[2023-02-23 15:51:47]
Could you provide us with a copy of your Full Message Log, that would be interesting for us to see.
Copy and paste the *entire* copy of the Message Log into your email message or Support Board message according to the instructions below. Sending some of the lines is not helpful. The entire Message Log is needed. The Message Log does not contain any private information.
1. If the Sierra Chart Message Log is not already open, then select "Window >> Message Log" on the menu to open it. If you still do not see the log after selecting this command, then select "Window >> Reset Windows". The Message Log will be displayed in this case. If not, then select "Window >> Message Log" again.
2. Press the "Copy Log" button or use "Edit >> Copy Entire Log" on the menu on the Message Log window. This will automatically copy the Message Log to the system clipboard. Do not use the "Send for Analysis". Otherwise, the log will not be seen.
3. Move your Pointer to the message area either in the email message, Support Board or Account Support Ticket.
4. Right-click your Pointer. Select "Paste" on the menu to paste it into the message area.
[2023-02-23 15:56:31]
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2023-02-22 18:26:21.697
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 32768 | 2023-02-22 18:26:21.697
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 38.79.0.89. | 2023-02-22 18:26:21.697
[71336] Chartbook Sharing Server | Restore Settings | Read from File 'C:\SierraChart\Data\ChartbookSharing\ChartbookSharingSettings.config' | 2023-02-22 18:26:21.813
[71336] Chartbook Sharing Server | Restore Settings | Start reading internal server states | 2023-02-22 18:26:21.813
[71336] Chartbook Sharing Server | Restore Settings | Finish reading internal server states. OK | 2023-02-22 18:26:21.813
[71336] Chartbook Sharing Server | Server | Send @RestartServer to All /Start | 2023-02-22 18:26:21.813
Created the DTC Protocol server. | 2023-02-22 18:26:21.815
DTC Protocol Server listening on port 63675. | 2023-02-22 18:26:21.819
Reading Internal Order ID file. | 2023-02-22 18:26:21.820
Reading Trade Orders file. | 2023-02-22 18:26:22.003
Reading Trade Positions file. | 2023-02-22 18:26:22.004
Reading Trade Account Data files. | 2023-02-22 18:26:22.005
UDPListener (1584). Port 22904 | Listening on UDP port 22904. | 2023-02-22 18:26:22.013
Software version: 2480 64-bit | 2023-02-22 18:26:22.015
Primary Thread ID: 71336 | 2023-02-22 18:26:22.015
Usage end date: 2023-03-27 | 2023-02-22 18:26:22.015
Enabled for: Advanced Features 2. | 2023-02-22 18:26:22.015
Enabled for: Sierra Chart Historical Data Service. | 2023-02-22 18:26:22.015
Enabled for: Denali Real-Time Exchange Data Feed. | 2023-02-22 18:26:22.015
Enabled for: Delayed Denali Exchange Data Feed. | 2023-02-22 18:26:22.015
Enabled for exchange2: CME | 2023-02-22 18:26:22.015
Enabled for exchange2: fairx_exchange.data | 2023-02-22 18:26:22.015
Allow Support for Sierra Chart Data Feeds is enabled. | 2023-02-22 18:26:22.015
Current selected Data/Trading service: Rithmic Direct - DTC | 2023-02-22 18:26:22.015
Custom symbol settings values: enabled | 2023-02-22 18:26:22.015
Chart Update Interval: 500 | 2023-02-22 18:26:22.015
Intraday Data Storage Time Unit: 0 | 2023-02-22 18:26:22.015
Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2023-02-22 18:26:22.015
2023-02-22 17:26:22 Local computer time in UTC | 2023-02-22 18:26:22.015
2023-02-22 18:26:22 Local computer time in SC Time Zone | 2023-02-22 18:26:22.015
2023-02-22 17:26:20 Server time in UTC | 2023-02-22 18:26:22.015
Local computer UTC time and Server UTC time difference: 0 seconds. | 2023-02-22 18:26:22.015
Program path: C:\SierraChart\ | 2023-02-22 18:26:22.015
Data Files path: C:\SierraChart\Data\ | 2023-02-22 18:26:22.015
OS Version Number: 10.0 | 2023-02-22 18:26:22.015
Locale Setting: C | 2023-02-22 18:26:22.015
DLLs: Draw_Peak_and_Valley_642175.dll, Draw_Single_Print_642175.dll, UserContributedStudies_64.dll | 2023-02-22 18:26:22.016
Allowed protected custom studies: | 2023-02-22 18:26:22.016
Crash reporter started: true | 2023-02-22 18:26:22.016
Created the DTC Protocol historical data server. | 2023-02-22 18:26:22.053
HD Server Manager | Listening on port 11098. | 2023-02-22 18:26:22.055
Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. | 2023-02-22 18:26:22.056
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:26:22.178
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-02-22 18:26:22.244
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-02-22 18:26:22.244
Received 5 login tokens. | 2023-02-22 18:26:22.288
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 65536 | 2023-02-22 18:26:22.557
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2023-02-22 18:26:22.557
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | CloseSocket call. | 2023-02-22 18:26:22.558
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-02-22 18:26:22.559
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Closed. | 2023-02-22 18:26:22.559
Symbol settings MD5 received. Request ID: 1. | 2023-02-22 18:26:23.592
Requested symbol settings for service code rithmic_v2.trading. Request ID: 2. | 2023-02-22 18:26:23.592
Symbol settings received. Request ID: 2. | 2023-02-22 18:26:25.347
Files to Open on Startup | Opening file: SP500.cht | 2023-02-22 18:26:26.433
ESH23_FUT_CME [CBV] 1 Min #1 | Reloading chart. | 2023-02-22 18:26:26.464
ESH23_FUT_CME [CBV] 1 Min #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2023-02-22 18:26:26.464
ESH23_FUT_CME [CBV] 1 Min #1 | There are no continuous futures contract symbols. Loading data normally. | 2023-02-22 18:26:26.464
ESH23_FUT_CME [CBV] Rev. 4t #9 | Reloading chart. | 2023-02-22 18:26:26.505
ESH23_FUT_CME [CBV] Rev. 4t #9 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2023-02-22 18:26:26.505
ESH23_FUT_CME [CBV] Rev. 4t #9 | There are no continuous futures contract symbols. Loading data normally. | 2023-02-22 18:26:26.505
ESZ22 1 Sec #5 | Reloading chart. | 2023-02-22 18:26:26.553
Loading market depth data. | 2023-02-22 18:26:26.561
Loading DLL: C:\SierraChart\Data\Draw_Peak_and_Valley.dll (Draw_Peak_and_Valley_642175.dll). Handle: 66000000 | 2023-02-22 18:26:26.582
Loading DLL: C:\SierraChart\Data\Draw_Single_Print.dll (Draw_Single_Print_642175.dll). Handle: a2a0000 | 2023-02-22 18:26:26.605
ESH23_FUT_CME [CBV] 30 Min #2 | Reloading chart. | 2023-02-22 18:26:26.618
ESH23_FUT_CME [CBV] 30 Min #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2023-02-22 18:26:26.618
ESH23_FUT_CME [CBV] 30 Min #2 | There are no continuous futures contract symbols. Loading data normally. | 2023-02-22 18:26:26.618
ESH23_FUT_CME [CBV] #6 | Reloading chart. | 2023-02-22 18:26:26.640
ESH23_FUT_CME [CBV] #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2023-02-22 18:26:26.640
ESH23_FUT_CME [CBV] #6 | There are no continuous futures contract symbols. Loading data normally. | 2023-02-22 18:26:26.640
ESH23_FUT_CME #4 | Reloading chart. | 2023-02-22 18:26:26.659
Files to Open on Startup | Opening file: Dailychart.Cht | 2023-02-22 18:26:26.698
ESH23_FUT_CME [CBV] Daily #4 | Reloading chart. | 2023-02-22 18:26:26.794
ESH23_FUT_CME [CBV] Daily #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2023-02-22 18:26:26.794
ESH23_FUT_CME [CBV] Daily #4 | There are no continuous futures contract symbols. Loading data normally. | 2023-02-22 18:26:26.794
ZBU22 [CBV] Daily #3 | Reloading chart. | 2023-02-22 18:26:26.881
ZBU22 [CBV] Daily #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2023-02-22 18:26:26.881
ZBU22 [CBV] Daily #3 | There are no continuous futures contract symbols. Loading data normally. | 2023-02-22 18:26:26.881
ZFU22 [CBV] Daily #2 | Reloading chart. | 2023-02-22 18:26:26.974
ZFU22 [CBV] Daily #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2023-02-22 18:26:26.974
ZFU22 [CBV] Daily #2 | There are no continuous futures contract symbols. Loading data normally. | 2023-02-22 18:26:26.974
UDU22 [CBV] Daily #5 | Reloading chart. | 2023-02-22 18:26:27.066
UDU22 [CBV] Daily #5 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2023-02-22 18:26:27.066
UDU22 [CBV] Daily #5 | There are no continuous futures contract symbols. Loading data normally. | 2023-02-22 18:26:27.066
ZNH23 [CBV] Daily #6 | Reloading chart. | 2023-02-22 18:26:27.154
ZNH23 [CBV] Daily #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2023-02-22 18:26:27.154
ZNH23 [CBV] Daily #6 | There are no continuous futures contract symbols. Loading data normally. | 2023-02-22 18:26:27.154
Files to Open on Startup | Opening file: Marketpflbons.Cht | 2023-02-22 18:26:27.230
ZFM0-CBOT [CBV] #1 | Reloading chart. | 2023-02-22 18:26:27.321
ZFM0-CBOT [CBV] #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2023-02-22 18:26:27.321
ZFM0-CBOT [CBV] #1 | There are no continuous futures contract symbols. Loading data normally. | 2023-02-22 18:26:27.321
Files to Open on Startup | File does not exist: C:\SierraChart\Data\vlm pfl bons.Cht | 2023-02-22 18:26:27.335
ESZ22 1 Sec #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ22.scid | 2023-02-22 18:26:27.351
ESH23_FUT_CME #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 18:26:28.742
ZFM0-CBOT [CBV-D] #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ZFM0-CBOT.scid | 2023-02-22 18:26:28.745
ESH23_FUT_CME [CBV-D] 1 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 18:26:28.796
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:26:29.273
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:26:29.273
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:26:29.273
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:26:29.273
Using symbol data fast lookup vector | 2023-02-22 18:26:29.276
ESH23_FUT_CME [CBV-D] 1 Min #1 | Reloading chart. | 2023-02-22 18:26:29.310
ESH23_FUT_CME [CBV-D] 1 Min #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2023-02-22 18:26:29.310
ESH23_FUT_CME [CBV-D] 1 Min #1 | There are no continuous futures contract symbols. Loading data normally. | 2023-02-22 18:26:29.310
ESH23_FUT_CME [CBV-D] Rev. 4t #9 | Reloading chart. | 2023-02-22 18:26:29.320
ESH23_FUT_CME [CBV-D] Rev. 4t #9 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2023-02-22 18:26:29.320
ESH23_FUT_CME [CBV-D] Rev. 4t #9 | There are no continuous futures contract symbols. Loading data normally. | 2023-02-22 18:26:29.320
Starting DelayedDownloadMonitoringTimer | 2023-02-22 18:26:29.332
Starting HDTimeoutTimer | 2023-02-22 18:26:29.332
Added historical Daily data request for UDU22 to the queue. | 2023-02-22 18:26:29.332
Triggering next historical data download in queue. | 2023-02-22 18:26:29.332
HD Request # 1 | Downloading Historical Daily chart data for UDU22. Starting date: 2022-09-19. Service: nasdaq_exchange.data | 2023-02-22 18:26:29.341
Added historical Daily data request for ZBU22 to the queue. | 2023-02-22 18:26:29.348
Triggering next historical data download in queue. | 2023-02-22 18:26:29.348
Added historical Daily data request for ZFU22 to the queue. | 2023-02-22 18:26:29.351
Triggering next historical data download in queue. | 2023-02-22 18:26:29.351
Added historical Daily data request for ZNH23 to the queue. | 2023-02-22 18:26:29.354
Triggering next historical data download in queue. | 2023-02-22 18:26:29.354
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:26:29.355
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:26:29.355
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:26:29.355
HD Request # 1 | Requesting historical Daily data for UDU22 starting at 2022-09-18. SC External HD service. | 2023-02-22 18:26:29.691
HD Request # 1 | Receiving historical Daily data for UDU22 starting at 2022-09-19. | 2023-02-22 18:26:30.087
HD Request # 1 | Writing historical Daily data to the file UDU22.dly. | 2023-02-22 18:26:30.088
HD Request # 1 | Bytes received: 178 | 2023-02-22 18:26:30.093
HD Request # 1 | Received 3 Daily data records from 2022-09-19 00:00:00 to 2022-09-21 00:00:00 (3.0 days) and wrote 3 records for UDU22 | 2023-02-22 18:26:30.093
HD Request # 1 | Completion time: 1s. | 2023-02-22 18:26:30.093
HD Request # 1 | Daily data download complete for UDU22. Unique request ID: 1 | 2023-02-22 18:26:30.093
Removing historical data download ID 1. | 2023-02-22 18:26:30.093
Triggering next historical data download in queue. | 2023-02-22 18:26:30.093
HD Request # 2 | Downloading Historical Daily chart data for ZBU22. Starting date: 2022-09-19. Service: nasdaq_exchange.data | 2023-02-22 18:26:30.097
HD Request # 2 | Requesting historical Daily data for ZBU22 starting at 2022-09-18. SC External HD service. | 2023-02-22 18:26:30.464
UDU22 [CBV-D] Daily #5 | Reloading chart. | 2023-02-22 18:26:30.576
UDU22 [CBV-D] Daily #5 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2023-02-22 18:26:30.576
UDU22 [CBV-D] Daily #5 | There are no continuous futures contract symbols. Loading data normally. | 2023-02-22 18:26:30.576
HD Request # 2 | Receiving historical Daily data for ZBU22 starting at 2022-09-19. | 2023-02-22 18:26:30.730
HD Request # 2 | Writing historical Daily data to the file ZBU22.dly. | 2023-02-22 18:26:30.731
HD Request # 2 | Bytes received: 194 | 2023-02-22 18:26:30.735
HD Request # 2 | Received 3 Daily data records from 2022-09-19 00:00:00 to 2022-09-21 00:00:00 (3.0 days) and wrote 3 records for ZBU22 | 2023-02-22 18:26:30.735
HD Request # 2 | Completion time: 0s. | 2023-02-22 18:26:30.735
HD Request # 2 | Daily data download complete for ZBU22. Unique request ID: 2 | 2023-02-22 18:26:30.735
Removing historical data download ID 2. | 2023-02-22 18:26:30.735
Triggering next historical data download in queue. | 2023-02-22 18:26:30.735
HD Request # 3 | Downloading Historical Daily chart data for ZFU22. Starting date: 2022-09-28. Service: nasdaq_exchange.data | 2023-02-22 18:26:30.738
ZBU22 [CBV-D] Daily #3 | Reloading chart. | 2023-02-22 18:26:30.907
ZBU22 [CBV-D] Daily #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2023-02-22 18:26:30.907
ZBU22 [CBV-D] Daily #3 | There are no continuous futures contract symbols. Loading data normally. | 2023-02-22 18:26:30.907
HD Request # 3 | Requesting historical Daily data for ZFU22 starting at 2022-09-27. SC External HD service. | 2023-02-22 18:26:31.083
ESH23_FUT_CME [CBV-D] 1 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 18:26:31.171
HD Request # 3 | Receiving historical Daily data for ZFU22 starting at 2022-09-28. | 2023-02-22 18:26:31.582
HD Request # 3 | Writing historical Daily data to the file ZFU22.dly. | 2023-02-22 18:26:31.583
HD Request # 3 | Bytes received: 270 | 2023-02-22 18:26:31.586
HD Request # 3 | Received 4 Daily data records from 2022-09-28 00:00:00 to 2022-09-30 00:00:00 (3.0 days) and wrote 3 records for ZFU22 | 2023-02-22 18:26:31.586
HD Request # 3 | Completion time: 1s. | 2023-02-22 18:26:31.586
HD Request # 3 | Daily data download complete for ZFU22. Unique request ID: 3 | 2023-02-22 18:26:31.586
Removing historical data download ID 3. | 2023-02-22 18:26:31.586
Triggering next historical data download in queue. | 2023-02-22 18:26:31.586
HD Request # 4 | Downloading Historical Daily chart data for ZNH23. Starting date: 2023-02-16. Service: nasdaq_exchange.data | 2023-02-22 18:26:31.590
HD Request # 4 | Requesting historical Daily data for ZNH23 starting at 2023-02-15. SC External HD service. | 2023-02-22 18:26:32.211
ZFU22 [CBV-D] Daily #2 | Reloading chart. | 2023-02-22 18:26:32.218
ZFU22 [CBV-D] Daily #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2023-02-22 18:26:32.218
ZFU22 [CBV-D] Daily #2 | There are no continuous futures contract symbols. Loading data normally. | 2023-02-22 18:26:32.218
HD Request # 4 | Receiving historical Daily data for ZNH23 starting at 2023-02-16. | 2023-02-22 18:26:32.490
HD Request # 4 | Writing historical Daily data to the file ZNH23.dly. | 2023-02-22 18:26:32.491
HD Request # 4 | Bytes received: 294 | 2023-02-22 18:26:32.494
HD Request # 4 | Received 4 Daily data records from 2023-02-16 00:00:00 to 2023-02-21 00:00:00 (6.0 days) and wrote 3 records for ZNH23 | 2023-02-22 18:26:32.494
HD Request # 4 | Completion time: 1s. | 2023-02-22 18:26:32.494
HD Request # 4 | Daily data download complete for ZNH23. Unique request ID: 4 | 2023-02-22 18:26:32.494
Removing historical data download ID 4. | 2023-02-22 18:26:32.494
Triggering next historical data download in queue. | 2023-02-22 18:26:32.494
No download requests in the queue to start downloads for. | 2023-02-22 18:26:32.494
ZNH23 [CBV-D] Daily #6 | Reloading chart. | 2023-02-22 18:26:33.149
ZNH23 [CBV-D] Daily #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2023-02-22 18:26:33.149
ZNH23 [CBV-D] Daily #6 | There are no continuous futures contract symbols. Loading data normally. | 2023-02-22 18:26:33.149
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:26:33.352
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:26:33.352
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:26:33.352
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:26:33.352
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:26:33.367
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:26:33.367
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:26:33.367
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:26:37.365
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:26:37.365
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:26:37.365
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:26:37.365
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:26:37.381
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:26:37.381
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:26:37.381
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:26:41.374
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:26:41.374
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:26:41.374
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:26:41.374
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:26:41.390
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:26:41.390
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:26:41.390
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:26:45.391
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:26:45.391
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:26:45.391
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:26:45.391
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:26:45.407
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:26:45.407
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:26:45.407
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:26:49.406
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:26:49.406
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:26:49.406
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:26:49.406
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:26:49.422
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:26:49.422
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:26:49.422
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:26:53.427
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:26:53.427
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:26:53.427
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:26:53.427
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:26:53.442
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:26:53.442
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:26:53.442
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:27:01.567
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:27:01.567
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:27:01.567
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:01.567
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:27:01.586
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:27:01.586
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:01.586
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:27:05.586
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:27:05.586
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:27:05.586
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:05.586
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:27:05.603
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:27:05.604
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:05.604
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:27:09.595
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:27:09.595
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:27:09.595
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:09.595
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:27:09.611
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:27:09.611
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:09.611
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:27:13.609
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:27:13.609
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:27:13.609
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:13.609
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:27:13.624
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:27:13.624
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:13.624
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:27:17.632
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:27:17.632
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:27:17.632
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:17.632
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:27:17.648
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:27:17.648
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:17.648
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:27:21.647
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:27:21.654
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:27:21.654
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:21.654
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:27:21.665
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:27:21.665
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:21.666
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:27:25.661
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:27:25.667
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:27:25.667
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:25.667
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:27:25.679
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:27:25.679
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:25.679
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:27:29.684
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:27:29.691
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:27:29.691
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:29.691
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:27:29.717
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:27:29.717
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:29.717
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:27:33.712
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:27:33.716
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:27:33.716
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:33.716
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:27:33.725
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:27:33.725
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:33.725
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:27:37.731
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:27:37.736
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:27:37.736
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:37.736
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:27:37.763
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:27:37.763
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:37.764
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:27:38.195
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:27:38.200
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:27:38.200
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:38.200
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:27:38.217
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:27:38.217
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:38.217
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:27:42.221
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:27:42.227
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:27:42.227
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:42.227
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:27:42.240
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:27:42.240
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:42.240
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:27:46.238
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:27:46.245
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:27:46.245
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:46.245
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:27:46.258
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:27:46.258
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:46.258
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:27:50.255
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:27:50.262
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:27:50.262
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:50.262
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:27:50.274
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:27:50.274
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:50.274
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:27:54.280
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:27:54.286
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:27:54.286
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:54.286
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:27:54.312
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:27:54.312
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:54.312
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:27:58.311
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:27:58.318
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:27:58.318
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:58.318
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:27:58.331
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:27:58.331
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:27:58.331
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:28:02.334
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:28:02.340
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:28:02.340
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:02.340
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:28:02.406
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:28:02.406
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:02.406
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:28:06.419
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:28:06.427
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:28:06.427
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:06.427
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:28:06.453
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:28:06.453
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:06.453
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:28:10.464
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:28:10.471
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:28:10.471
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:10.471
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:28:10.497
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:28:10.497
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:10.497
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:28:14.496
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:28:14.502
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:28:14.502
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:14.502
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:28:14.529
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:28:14.529
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:14.530
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:28:18.515
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:28:18.521
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:28:18.521
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:18.521
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:28:18.532
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:28:18.532
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:18.533
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:28:22.545
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:28:22.551
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:28:22.551
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:22.551
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:28:22.576
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:28:22.577
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:22.577
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:28:26.575
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:28:26.582
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:28:26.582
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:26.582
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:28:26.610
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:28:26.610
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:26.610
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:28:30.621
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:28:30.627
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:28:30.627
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:30.627
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:28:30.684
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:28:30.684
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:30.684
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:28:34.691
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:28:34.697
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:28:34.697
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:34.697
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:28:34.718
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:28:34.718
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:34.718
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:28:38.725
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:28:38.732
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:28:38.732
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:38.732
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:28:38.742
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:28:38.742
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:38.743
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:28:42.742
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:28:42.751
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:28:42.751
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:42.751
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:28:42.775
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:28:42.775
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:42.775
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:28:46.766
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:28:46.773
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:28:46.773
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:46.773
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:28:46.784
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:28:46.784
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:46.784
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:28:50.780
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:28:50.788
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:28:50.788
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:50.788
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:28:50.813
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:28:50.813
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:50.813
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:28:54.821
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:28:54.828
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:28:54.828
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:54.828
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:28:54.853
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:28:54.854
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:54.854
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:28:58.857
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:28:58.863
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:28:58.863
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:58.863
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:28:58.919
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:28:58.919
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:28:58.919
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:29:02.918
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:29:02.925
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:29:02.925
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:02.925
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:29:02.951
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:29:02.951
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:02.952
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:29:06.941
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:29:06.948
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:29:06.948
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:06.948
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:29:06.958
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:29:06.958
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:06.958
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:29:10.955
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:29:10.960
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:29:10.960
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:10.960
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:29:10.972
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:29:10.972
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:10.972
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:29:14.973
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:29:14.980
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:29:14.980
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:14.980
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:29:14.991
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:29:14.991
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:14.991
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:29:18.985
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:29:18.993
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:29:18.993
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:18.993
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:29:19.003
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:29:19.003
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:19.003
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:29:23.008
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:29:23.015
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:29:23.015
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:23.015
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:29:23.040
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:29:23.040
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:23.040
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:29:27.035
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:29:27.041
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:29:27.041
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:27.041
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:29:27.052
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:29:27.052
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:27.052
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:29:31.052
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:29:31.069
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:29:31.069
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:31.069
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:29:31.092
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:29:31.092
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:31.092
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:29:35.091
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:29:35.097
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:29:35.098
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:35.098
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:29:35.125
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:29:35.125
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:35.125
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:29:39.131
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:29:39.137
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:29:39.137
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:39.137
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:29:39.149
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:29:39.149
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:39.149
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:29:43.151
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:29:43.157
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:29:43.157
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:43.157
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:29:43.185
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:29:43.185
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:43.185
Rithmic Direct - DTC | Using server connection: | 2023-02-22 18:29:47.185
Rithmic Direct - DTC | Remote address is not set. | 2023-02-22 18:29:47.193
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:29:47.193
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:47.193
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:29:47.218
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:29:47.219
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:29:47.219
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Creating socket. Using TLS 1.2. | 2023-02-22 18:30:07.187
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | New receive buffer size: 32768 | 2023-02-22 18:30:07.187
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Connecting to IP: 38.79.0.89. | 2023-02-22 18:30:07.187
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | New receive buffer size: 65536 | 2023-02-22 18:30:07.660
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Socket gracefully closed by remote side. | 2023-02-22 18:30:07.782
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | CloseSocket call. | 2023-02-22 18:30:07.783
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-02-22 18:30:07.783
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Closed. | 2023-02-22 18:30:07.783
Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated | 2023-02-22 18:31:47.224
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 | 2023-02-22 18:31:47.231
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-02-22 18:31:47.335
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-02-22 18:31:47.335
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2023-02-22 18:31:47.335
Rithmic Direct - DTC | Network connection to server complete. | 2023-02-22 18:31:47.490
Rithmic Direct - DTC | Starting socket receive thread. | 2023-02-22 18:31:47.490
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-02-22 18:31:47.492
Rithmic Direct - DTC | Sending logon request message. | 2023-02-22 18:31:47.492
File >> Disconnect selected. | 2023-02-22 18:31:47.872
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-02-22 18:31:47.874
DTC Client socket (1) | CloseSocket call. | 2023-02-22 18:31:47.874
DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2023-02-22 18:31:47.874
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:31:47.874
DTC Client socket (1) | Write has completed. Shutdown being performed. | 2023-02-22 18:31:47.958
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:31:47.958
Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated | 2023-02-22 18:31:49.930
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 | 2023-02-22 18:31:49.935
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-02-22 18:31:49.936
DTC Client socket (2) | New receive buffer size: 5242880 | 2023-02-22 18:31:49.936
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-02-22 18:31:49.936
Rithmic Direct - DTC | Network connection to server complete. | 2023-02-22 18:31:50.055
Rithmic Direct - DTC | Starting socket receive thread. | 2023-02-22 18:31:50.055
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-02-22 18:31:50.056
Rithmic Direct - DTC | Sending logon request message. | 2023-02-22 18:31:50.056
Rithmic Direct - DTC | Received logon response. | 2023-02-22 18:31:50.422
Rithmic Direct - DTC | Server Name: . | 2023-02-22 18:31:50.422
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2023-02-22 18:31:50.422
Rithmic Direct - DTC | Logon error received from server: permission denied | 2023-02-22 18:31:50.422
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:31:50.422
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:31:50.422
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-02-22 18:31:50.505
DTC Client socket (2) | CloseSocket call. | 2023-02-22 18:31:50.506
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:31:50.506
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:31:50.506
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:31:50.506
DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-02-22 18:31:50.624
DTC Client socket (2) | Closed. | 2023-02-22 18:31:50.624
Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated | 2023-02-22 18:31:54.505
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 | 2023-02-22 18:31:54.512
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-02-22 18:31:54.513
DTC Client socket (2) | New receive buffer size: 5242880 | 2023-02-22 18:31:54.513
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-02-22 18:31:54.513
File >> Disconnect selected. | 2023-02-22 18:31:54.602
DTC Client socket (2) | CloseSocket call. | 2023-02-22 18:31:54.604
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:31:54.604
DTC Client socket (2) | Closed. | 2023-02-22 18:31:54.604
Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated | 2023-02-22 18:32:12.289
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 | 2023-02-22 18:32:12.293
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-02-22 18:32:12.294
DTC Client socket (2) | New receive buffer size: 5242880 | 2023-02-22 18:32:12.294
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-02-22 18:32:12.294
Rithmic Direct - DTC | Network connection to server complete. | 2023-02-22 18:32:12.433
Rithmic Direct - DTC | Starting socket receive thread. | 2023-02-22 18:32:12.433
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-02-22 18:32:12.434
Rithmic Direct - DTC | Sending logon request message. | 2023-02-22 18:32:12.434
Rithmic Direct - DTC | Received logon response. | 2023-02-22 18:32:12.850
Rithmic Direct - DTC | Server Name: . | 2023-02-22 18:32:12.850
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2023-02-22 18:32:12.850
Rithmic Direct - DTC | Logon error received from server: permission denied | 2023-02-22 18:32:12.850
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:32:12.850
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:32:12.850
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-02-22 18:32:12.933
DTC Client socket (2) | CloseSocket call. | 2023-02-22 18:32:12.934
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:32:12.934
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:32:12.934
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:32:12.934
DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-02-22 18:32:13.056
DTC Client socket (2) | Closed. | 2023-02-22 18:32:13.056
Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated | 2023-02-22 18:32:16.922
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 | 2023-02-22 18:32:16.927
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-02-22 18:32:16.928
DTC Client socket (2) | New receive buffer size: 5242880 | 2023-02-22 18:32:16.928
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-02-22 18:32:16.928
Rithmic Direct - DTC | Network connection to server complete. | 2023-02-22 18:32:17.043
Rithmic Direct - DTC | Starting socket receive thread. | 2023-02-22 18:32:17.043
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-02-22 18:32:17.046
Rithmic Direct - DTC | Sending logon request message. | 2023-02-22 18:32:17.046
Rithmic Direct - DTC | Received logon response. | 2023-02-22 18:32:17.433
Rithmic Direct - DTC | Server Name: . | 2023-02-22 18:32:17.433
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2023-02-22 18:32:17.433
Rithmic Direct - DTC | Logon error received from server: permission denied | 2023-02-22 18:32:17.433
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:32:17.433
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:32:17.433
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-02-22 18:32:17.524
DTC Client socket (2) | CloseSocket call. | 2023-02-22 18:32:17.524
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:32:17.524
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:32:17.524
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:32:17.524
DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-02-22 18:32:17.645
DTC Client socket (2) | Closed. | 2023-02-22 18:32:17.645
File >> Disconnect selected. | 2023-02-22 18:32:20.937
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:32:20.937
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:32:20.937
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (2) | Creating socket. Using TLS 1.2. | 2023-02-22 18:32:36.940
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (2) | New receive buffer size: 32768 | 2023-02-22 18:32:36.940
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (2) | Connecting to IP: 38.79.0.89. | 2023-02-22 18:32:36.940
Rithmic Direct - DTC | Using server connection: TradeFundrr-Europe-Non-Aggregated | 2023-02-22 18:32:37.289
Rithmic Direct - DTC | Connecting to the server rsc-ie.rithmic.com. Port 40829 | 2023-02-22 18:32:37.295
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (2) | New receive buffer size: 65536 | 2023-02-22 18:32:37.414
DTC Client socket (3) | Creating socket. Using TLS 1.2. | 2023-02-22 18:32:37.432
DTC Client socket (3) | New receive buffer size: 5242880 | 2023-02-22 18:32:37.432
DTC Client socket (3) | Connecting to IP: 34.251.179.156. | 2023-02-22 18:32:37.432
Rithmic Direct - DTC | Network connection to server complete. | 2023-02-22 18:32:37.469
Rithmic Direct - DTC | Starting socket receive thread. | 2023-02-22 18:32:37.469
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-02-22 18:32:37.470
Rithmic Direct - DTC | Sending logon request message. | 2023-02-22 18:32:37.470
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (2) | Socket gracefully closed by remote side. | 2023-02-22 18:32:37.507
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (2) | CloseSocket call. | 2023-02-22 18:32:37.508
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-02-22 18:32:37.508
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (2) | Closed. | 2023-02-22 18:32:37.508
Rithmic Direct - DTC | Received logon response. | 2023-02-22 18:32:37.690
Rithmic Direct - DTC | Server Name: . | 2023-02-22 18:32:37.690
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2023-02-22 18:32:37.690
Rithmic Direct - DTC | Logon error received from server: permission denied | 2023-02-22 18:32:37.690
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:32:37.690
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:32:37.690
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-02-22 18:32:37.767
DTC Client socket (3) | CloseSocket call. | 2023-02-22 18:32:37.767
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:32:37.768
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:32:37.768
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:32:37.768
DTC Client socket (3) | Socket gracefully closed by remote side. | 2023-02-22 18:32:37.814
DTC Client socket (3) | Closed. | 2023-02-22 18:32:37.814
Rithmic Direct - DTC | Using server connection: TradeFundrr-Europe-Non-Aggregated | 2023-02-22 18:32:41.771
Rithmic Direct - DTC | Connecting to the server rsc-ie.rithmic.com. Port 40829 | 2023-02-22 18:32:41.778
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-02-22 18:32:41.779
DTC Client socket (2) | New receive buffer size: 5242880 | 2023-02-22 18:32:41.779
DTC Client socket (2) | Connecting to IP: 34.251.179.156. | 2023-02-22 18:32:41.779
Rithmic Direct - DTC | Network connection to server complete. | 2023-02-22 18:32:41.838
Rithmic Direct - DTC | Starting socket receive thread. | 2023-02-22 18:32:41.838
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-02-22 18:32:41.840
Rithmic Direct - DTC | Sending logon request message. | 2023-02-22 18:32:41.840
Rithmic Direct - DTC | Received logon response. | 2023-02-22 18:32:42.063
Rithmic Direct - DTC | Server Name: . | 2023-02-22 18:32:42.063
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2023-02-22 18:32:42.063
Rithmic Direct - DTC | Logon error received from server: permission denied | 2023-02-22 18:32:42.063
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:32:42.063
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:32:42.063
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-02-22 18:32:42.158
DTC Client socket (2) | CloseSocket call. | 2023-02-22 18:32:42.158
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:32:42.158
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:32:42.158
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:32:42.158
DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-02-22 18:32:42.195
DTC Client socket (2) | Closed. | 2023-02-22 18:32:42.195
File >> Disconnect selected. | 2023-02-22 18:32:45.575
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:32:45.575
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:32:45.575
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (2) | Creating socket. Using TLS 1.2. | 2023-02-22 18:33:01.779
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (2) | New receive buffer size: 32768 | 2023-02-22 18:33:01.779
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (2) | Connecting to IP: 38.79.0.89. | 2023-02-22 18:33:01.779
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (2) | Socket gracefully closed by remote side. | 2023-02-22 18:33:02.370
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (2) | CloseSocket call. | 2023-02-22 18:33:02.371
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-02-22 18:33:02.372
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (2) | Closed. | 2023-02-22 18:33:02.372
Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated | 2023-02-22 18:33:49.291
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 | 2023-02-22 18:33:49.296
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-02-22 18:33:49.296
DTC Client socket (2) | New receive buffer size: 5242880 | 2023-02-22 18:33:49.297
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-02-22 18:33:49.297
Rithmic Direct - DTC | Network connection to server complete. | 2023-02-22 18:33:49.452
Rithmic Direct - DTC | Starting socket receive thread. | 2023-02-22 18:33:49.452
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-02-22 18:33:49.453
Rithmic Direct - DTC | Sending logon request message. | 2023-02-22 18:33:49.453
Rithmic Direct - DTC | Received logon response. | 2023-02-22 18:33:49.804
Rithmic Direct - DTC | Server Name: . | 2023-02-22 18:33:49.804
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2023-02-22 18:33:49.804
Rithmic Direct - DTC | Logon error received from server: permission denied | 2023-02-22 18:33:49.804
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:33:49.804
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:33:49.804
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-02-22 18:33:49.972
DTC Client socket (2) | CloseSocket call. | 2023-02-22 18:33:49.972
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:33:49.973
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:33:49.973
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:33:49.973
DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-02-22 18:33:50.087
DTC Client socket (2) | Closed. | 2023-02-22 18:33:50.087
File >> Disconnect selected. | 2023-02-22 18:33:53.512
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:33:53.512
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:33:53.512
Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated | 2023-02-22 18:34:01.405
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 | 2023-02-22 18:34:01.410
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-02-22 18:34:01.418
DTC Client socket (2) | New receive buffer size: 5242880 | 2023-02-22 18:34:01.419
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-02-22 18:34:01.419
Rithmic Direct - DTC | Network connection to server complete. | 2023-02-22 18:34:01.534
Rithmic Direct - DTC | Starting socket receive thread. | 2023-02-22 18:34:01.534
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-02-22 18:34:01.535
Rithmic Direct - DTC | Sending logon request message. | 2023-02-22 18:34:01.535
Rithmic Direct - DTC | Received logon response. | 2023-02-22 18:34:01.886
Rithmic Direct - DTC | Server Name: . | 2023-02-22 18:34:01.886
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2023-02-22 18:34:01.886
Rithmic Direct - DTC | Logon error received from server: permission denied | 2023-02-22 18:34:01.886
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:34:01.886
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:34:01.886
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-02-22 18:34:01.999
DTC Client socket (2) | CloseSocket call. | 2023-02-22 18:34:01.999
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:34:01.999
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:34:01.999
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:34:02.000
DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-02-22 18:34:02.122
DTC Client socket (2) | Closed. | 2023-02-22 18:34:02.122
File >> Disconnect selected. | 2023-02-22 18:34:05.674
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:34:05.674
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:34:05.674
DTC Client socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2023-02-22 18:34:14.836
DTC Client socket (1) | Closed. | 2023-02-22 18:34:14.836
HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (2) | Creating socket. Using TLS 1.2. | 2023-02-22 18:34:21.408
HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (2) | New receive buffer size: 32768 | 2023-02-22 18:34:21.408
HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (2) | Connecting to IP: 38.79.0.89. | 2023-02-22 18:34:21.408
HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (2) | New receive buffer size: 65536 | 2023-02-22 18:34:21.972
HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (2) | Socket gracefully closed by remote side. | 2023-02-22 18:34:21.973
HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (2) | CloseSocket call. | 2023-02-22 18:34:21.974
HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-02-22 18:34:21.974
HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (2) | Closed. | 2023-02-22 18:34:21.974
Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated | 2023-02-22 18:34:39.219
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 | 2023-02-22 18:34:39.219
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-02-22 18:34:39.220
DTC Client socket (2) | New receive buffer size: 5242880 | 2023-02-22 18:34:39.220
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-02-22 18:34:39.220
Rithmic Direct - DTC | Network connection to server complete. | 2023-02-22 18:34:39.369
Rithmic Direct - DTC | Starting socket receive thread. | 2023-02-22 18:34:39.369
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-02-22 18:34:39.370
Rithmic Direct - DTC | Sending logon request message. | 2023-02-22 18:34:39.370
Rithmic Direct - DTC | Received logon response. | 2023-02-22 18:34:39.719
Rithmic Direct - DTC | Server Name: . | 2023-02-22 18:34:39.719
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2023-02-22 18:34:39.719
Rithmic Direct - DTC | Logon error received from server: permission denied | 2023-02-22 18:34:39.719
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:34:39.719
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:34:39.719
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-02-22 18:34:39.839
DTC Client socket (2) | CloseSocket call. | 2023-02-22 18:34:39.839
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:34:39.839
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:34:39.839
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:34:39.839
DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-02-22 18:34:39.953
DTC Client socket (2) | Closed. | 2023-02-22 18:34:39.953
Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated | 2023-02-22 18:34:44.010
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 | 2023-02-22 18:34:44.010
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-02-22 18:34:44.010
DTC Client socket (2) | New receive buffer size: 5242880 | 2023-02-22 18:34:44.011
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-02-22 18:34:44.011
Rithmic Direct - DTC | Network connection to server complete. | 2023-02-22 18:34:44.126
Rithmic Direct - DTC | Starting socket receive thread. | 2023-02-22 18:34:44.126
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-02-22 18:34:44.127
Rithmic Direct - DTC | Sending logon request message. | 2023-02-22 18:34:44.127
Rithmic Direct - DTC | Received logon response. | 2023-02-22 18:34:44.474
Rithmic Direct - DTC | Server Name: . | 2023-02-22 18:34:44.474
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2023-02-22 18:34:44.474
Rithmic Direct - DTC | Logon error received from server: permission denied | 2023-02-22 18:34:44.474
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:34:44.474
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:34:44.474
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-02-22 18:34:44.515
DTC Client socket (2) | CloseSocket call. | 2023-02-22 18:34:44.516
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:34:44.516
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:34:44.516
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:34:44.516
DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-02-22 18:34:44.630
DTC Client socket (2) | Closed. | 2023-02-22 18:34:44.630
DTC Client socket (1) | Deleting network socket now after delay. | 2023-02-22 18:34:44.850
Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated | 2023-02-22 18:34:48.515
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 | 2023-02-22 18:34:48.515
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-02-22 18:34:48.515
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-02-22 18:34:48.516
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2023-02-22 18:34:48.516
Rithmic Direct - DTC | Network connection to server complete. | 2023-02-22 18:34:48.630
Rithmic Direct - DTC | Starting socket receive thread. | 2023-02-22 18:34:48.630
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-02-22 18:34:48.632
Rithmic Direct - DTC | Sending logon request message. | 2023-02-22 18:34:48.632
Rithmic Direct - DTC | Received logon response. | 2023-02-22 18:34:48.979
Rithmic Direct - DTC | Server Name: . | 2023-02-22 18:34:48.979
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2023-02-22 18:34:48.979
Rithmic Direct - DTC | Logon error received from server: permission denied | 2023-02-22 18:34:48.979
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-22 18:34:48.979
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:34:48.979
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-02-22 18:34:49.103
DTC Client socket (1) | CloseSocket call. | 2023-02-22 18:34:49.103
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:34:49.103
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-22 18:34:49.103
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:34:49.103
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-02-22 18:34:49.217
DTC Client socket (1) | Closed. | 2023-02-22 18:34:49.217
File >> Disconnect selected. | 2023-02-22 18:34:52.465
DTC Client socket (0) | CloseSocket call. | 2023-02-22 18:34:52.465
Rithmic Direct - DTC | Disconnected. | 2023-02-22 18:34:52.465
HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Creating socket. Using TLS 1.2. | 2023-02-22 18:35:08.526
HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | New receive buffer size: 32768 | 2023-02-22 18:35:08.526
HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Connecting to IP: 38.79.0.89. | 2023-02-22 18:35:08.526
HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | New receive buffer size: 65536 | 2023-02-22 18:35:09.001
HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Socket gracefully closed by remote side. | 2023-02-22 18:35:09.094
HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | CloseSocket call. | 2023-02-22 18:35:09.095
HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-02-22 18:35:09.095
HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Closed. | 2023-02-22 18:35:09.095
Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated | 2023-02-22 18:38:47.149
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 | 2023-02-22 18:38:47.154
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-02-22 18:38:47.154
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-02-22 18:38:47.154
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2023-02-22 18:38:47.154
Rithmic Direct - DTC | Network connection to server complete. | 2023-02-22 18:38:47.273
Rithmic Direct - DTC | Starting socket receive thread. | 2023-02-22 18:38:47.273
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-02-22 18:38:47.274
Rithmic Direct - DTC | Sending logon request message. | 2023-02-22 18:38:47.274
Rithmic Direct - DTC | Received logon response. | 2023-02-22 18:38:47.628
Rithmic Direct - DTC | Server Name: . | 2023-02-22 18:38:47.628
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2023-02-22 18:38:47.628
Rithmic Direct - DTC | Successfully connected. | 2023-02-22 18:38:47.628
Rithmic Direct - DTC | Trading is supported. | 2023-02-22 18:38:47.628
Rithmic Direct - DTC | Order cancel and replace is supported. | 2023-02-22 18:38:47.628
Rithmic Direct - DTC | OCO Orders supported. | 2023-02-22 18:38:47.628
Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2023-02-22 18:38:47.628
Rithmic Direct - DTC | Connected to server complete. | 2023-02-22 18:38:47.628
Triggering next historical data download in queue. | 2023-02-22 18:38:47.629
Updated verified funded futures trading account ending date to: 2023-03-24 17:38:47 | 2023-02-22 18:38:47.629
No download requests in the queue to start downloads for. | 2023-02-22 18:38:47.662
Using symbol data fast lookup vector | 2023-02-22 18:38:47.663
Rithmic Direct - DTC | Starting real-time market data updates for: ESZ22. ID: 1 | 2023-02-22 18:38:47.663
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50529 | 2023-02-22 18:38:47.663
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-02-22 18:38:47.663
DTC Client socket (2) | New receive buffer size: 5242880 | 2023-02-22 18:38:47.664
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2023-02-22 18:38:47.664
Rithmic Direct - DTC | Requesting security definition data for: ESZ22. ID: 1 | 2023-02-22 18:38:47.666
Requesting market depth updates for: ESZ22 if supported. | 2023-02-22 18:38:47.666
Separate subscription for market depth updates not supported. ESZ22 | 2023-02-22 18:38:47.666
Starting DelayedDownloadMonitoringTimer | 2023-02-22 18:38:47.666
Starting HDTimeoutTimer | 2023-02-22 18:38:47.666
Added historical Intraday data request for ESZ22 to the queue. | 2023-02-22 18:38:47.666
Intraday data recording state for symbol ESZ22 is set to download 'Pending'. | 2023-02-22 18:38:47.666
Triggering next historical data download in queue. | 2023-02-22 18:38:47.666
Delaying start of download for ESZ22. | 2023-02-22 18:38:47.667
Rithmic Direct - DTC | Starting real-time market data updates for: UDU22. ID: 2 | 2023-02-22 18:38:47.759
Rithmic Direct - DTC | Requesting security definition data for: UDU22. ID: 2 | 2023-02-22 18:38:47.759
Rithmic Direct - DTC | Network connection to server complete. | 2023-02-22 18:38:47.780
Rithmic Direct - DTC | Starting socket receive thread. | 2023-02-22 18:38:47.780
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-02-22 18:38:47.781
Rithmic Direct - DTC | Sending logon request message. | 2023-02-22 18:38:47.781
Updated verified funded futures trading account ending date to: 2023-03-24 17:38:47 | 2023-02-22 18:38:47.782
Added historical Daily data request for ESH23_FUT_CME to the queue. | 2023-02-22 18:38:47.821
Triggering next historical data download in queue. | 2023-02-22 18:38:47.821
Rithmic Direct - DTC | Starting real-time market data updates for: ESH23_FUT_CME. ID: 3 | 2023-02-22 18:38:47.822
Rithmic Direct - DTC | Requesting security definition data for: ESH23_FUT_CME. ID: 3 | 2023-02-22 18:38:47.822
Added historical Intraday data request for ESH23_FUT_CME to the queue. | 2023-02-22 18:38:47.914
Intraday data recording state for symbol ESH23_FUT_CME is set to download 'Pending'. | 2023-02-22 18:38:47.914
Triggering next historical data download in queue. | 2023-02-22 18:38:47.914
Rithmic Direct - DTC | Received logon response. | 2023-02-22 18:38:48.130
Rithmic Direct - DTC | Server Name: . | 2023-02-22 18:38:48.130
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2023-02-22 18:38:48.130
Rithmic Direct - DTC | Successfully connected. | 2023-02-22 18:38:48.130
Rithmic Direct - DTC | Trading is not supported. | 2023-02-22 18:38:48.130
Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2023-02-22 18:38:48.130
Rithmic Direct - DTC | Restarting real-time data updates for symbol: ESH23_FUT_CME | 2023-02-22 18:38:48.130
Rithmic Direct - DTC | Restarting real-time data updates for symbol: ESZ22. Market Depth data restarted. | 2023-02-22 18:38:48.130
Rithmic Direct - DTC | Restarting real-time data updates for symbol: UDU22 | 2023-02-22 18:38:48.130
Rithmic Direct - DTC | Starting real-time market data updates for: ZFM0-CBOT. ID: 4 | 2023-02-22 18:38:48.220
Rithmic Direct - DTC | Requesting security definition data for: ZFM0-CBOT. ID: 4 | 2023-02-22 18:38:48.220
Added historical Intraday data request for ZFM0-CBOT to the queue. | 2023-02-22 18:38:48.220
Intraday data recording state for symbol ZFM0-CBOT is set to download 'Pending'. | 2023-02-22 18:38:48.220
Triggering next historical data download in queue. | 2023-02-22 18:38:48.220
Symbol Error - ESH23_FUT_CME is unknown, unavailable, or improperly formatted. Exchange not specified | 2023-02-22 18:38:48.292
Symbol Error - ESZ22 is unknown, unavailable, or improperly formatted. Exchange not specified | 2023-02-22 18:38:48.293
Rithmic Direct - DTC | Market Depth data has been rejected for symbol: ESZ22. Exchange not specified | 2023-02-22 18:38:48.294
Symbol Error - UDU22 is unknown, unavailable, or improperly formatted. Exchange not specified | 2023-02-22 18:38:48.294
Symbol Error - ZFM0-CBOT is unknown, unavailable, or improperly formatted. Exchange not specified | 2023-02-22 18:38:48.347
Rithmic Direct - DTC | Starting real-time market data updates for: ZBU22. ID: 5 | 2023-02-22 18:38:48.535
Rithmic Direct - DTC | Requesting security definition data for: ZBU22. ID: 5 | 2023-02-22 18:38:48.535
Rithmic Direct - DTC | Starting real-time market data updates for: ZNH23. ID: 6 | 2023-02-22 18:38:48.537
Rithmic Direct - DTC | Requesting security definition data for: ZNH23. ID: 6 | 2023-02-22 18:38:48.537
Rithmic Direct - DTC | Starting real-time market data updates for: ZFU22. ID: 7 | 2023-02-22 18:38:48.540
Rithmic Direct - DTC | Requesting security definition data for: ZFU22. ID: 7 | 2023-02-22 18:38:48.540
Symbol Error - ZBU22 is unknown, unavailable, or improperly formatted. Exchange not specified | 2023-02-22 18:38:48.650
Symbol Error - ZNH23 is unknown, unavailable, or improperly formatted. Exchange not specified | 2023-02-22 18:38:48.651
Symbol Error - ZFU22 is unknown, unavailable, or improperly formatted. Exchange not specified | 2023-02-22 18:38:48.656
HD Request # 5 | Downloading Intraday chart data for ESZ22 to the file ESZ22.scid. Service: rithmic_v2.trading | 2023-02-22 18:38:48.665
HD Request # 5 | Download start date-time: 2022-08-20 19:38:48.000000. File last date-time: 00:00:00.000000 | 2023-02-22 18:38:48.666
HD Request # 5 | Using server: rsc.rithmic.com port 50530. Use encryption. | 2023-02-22 18:38:48.666
Socket (3) | Creating socket. Using TLS 1.2. | 2023-02-22 18:38:48.666
Socket (3) | New receive buffer size: 5242880 | 2023-02-22 18:38:48.666
Socket (3) | Connecting to IP: 216.57.156.163. | 2023-02-22 18:38:48.666
HD Request # 5 | Sending historical data logon request message. | 2023-02-22 18:38:48.782
HD Request # 5 | Requesting Intraday data. Start date-time: 2022-08-20 19:38:48. Record interval: 0. Symbol: ESZ22 | 2023-02-22 18:38:49.127
Socket (3) | CloseSocket call. | 2023-02-22 18:38:49.242
HD Request # 5 | Error downloading historical Intraday data for ESZ22. Exchange not specified | 2023-02-22 18:38:49.242
Historical data download thread signaled to stop. | 2023-02-22 18:38:49.242
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:38:49.242
HD Request # 5 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for ESZ22 | 2023-02-22 18:38:49.242
HD Request # 5 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2023-02-22 18:38:49.243
HD Request # 5 | Completion time: 1s. | 2023-02-22 18:38:49.243
HD Request # 5 | Intraday data download complete for ESZ22. Unique request ID: 5 | 2023-02-22 18:38:49.243
Removing historical data download ID 5. | 2023-02-22 18:38:49.243
Real-time Intraday chart data file updates started for ESZ22 | 2023-02-22 18:38:49.243
Intraday chart data file opened for ESZ22 | 2023-02-22 18:38:49.243
HD Request # 5 | Enabling Intraday chart updating for symbol. | 2023-02-22 18:38:49.243
Triggering next historical data download in queue. | 2023-02-22 18:38:49.243
HD Request # 6 | Downloading Historical Daily chart data for ESH23_FUT_CME. Starting date: 2023-02-16. Service: rithmic_v2.trading | 2023-02-22 18:38:49.247
HD Request # 6 | Using server: rsc.rithmic.com port 50530. Use encryption. | 2023-02-22 18:38:49.247
Socket (4) | Creating socket. Using TLS 1.2. | 2023-02-22 18:38:49.248
Socket (4) | New receive buffer size: 5242880 | 2023-02-22 18:38:49.248
Socket (4) | Connecting to IP: 216.57.156.163. | 2023-02-22 18:38:49.248
Socket (3) | Socket gracefully closed by remote side. | 2023-02-22 18:38:49.357
Socket (3) | Closed. | 2023-02-22 18:38:49.357
HD Request # 6 | Sending historical data logon request message. | 2023-02-22 18:38:49.363
HD Request # 6 | Requesting historical Daily data starting at 2023-02-16. | 2023-02-22 18:38:49.710
Socket (4) | CloseSocket call. | 2023-02-22 18:38:49.823
Socket (4) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:38:49.824
HD Request # 6 | Error downloading historical Daily data for ESH23_FUT_CME. Exchange not specified | 2023-02-22 18:38:49.840
Historical data download thread signaled to stop. | 2023-02-22 18:38:49.840
HD Request # 6 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH23_FUT_CME | 2023-02-22 18:38:49.840
HD Request # 6 | Completion time: 0s. | 2023-02-22 18:38:49.840
HD Request # 6 | Daily data download complete for ESH23_FUT_CME. Unique request ID: 6 | 2023-02-22 18:38:49.840
Removing historical data download ID 6. | 2023-02-22 18:38:49.840
Triggering next historical data download in queue. | 2023-02-22 18:38:49.840
HD Request # 7 | Downloading Intraday chart data for ESH23_FUT_CME to the file ESH23_FUT_CME.scid. Service: rithmic_v2.trading | 2023-02-22 18:38:49.841
HD Request # 7 | Download start date-time: 2023-02-22 18:20:42.000000. File last date-time: 2023-02-22 18:20:42.672002 | 2023-02-22 18:38:49.841
HD Request # 7 | Using server: rsc.rithmic.com port 50530. Use encryption. | 2023-02-22 18:38:49.842
Socket (3) | Creating socket. Using TLS 1.2. | 2023-02-22 18:38:49.842
Socket (3) | New receive buffer size: 5242880 | 2023-02-22 18:38:49.842
Socket (3) | Connecting to IP: 216.57.156.163. | 2023-02-22 18:38:49.842
Socket (4) | Socket gracefully closed by remote side. | 2023-02-22 18:38:49.938
Socket (4) | Closed. | 2023-02-22 18:38:49.938
HD Request # 7 | Sending historical data logon request message. | 2023-02-22 18:38:49.956
ESH23_FUT_CME [CBV-D] Daily #4 | Reloading chart. | 2023-02-22 18:38:50.057
ESH23_FUT_CME [CBV-D] Daily #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2023-02-22 18:38:50.057
ESH23_FUT_CME [CBV-D] Daily #4 | There are no continuous futures contract symbols. Loading data normally. | 2023-02-22 18:38:50.057
HD Request # 7 | Requesting Intraday data. Start date-time: 2023-02-22 18:20:42. Record interval: 0. Symbol: ESH23_FUT_CME | 2023-02-22 18:38:50.304
Socket (3) | CloseSocket call. | 2023-02-22 18:38:50.419
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:38:50.419
Socket (3) | Socket gracefully closed by remote side. | 2023-02-22 18:38:50.533
Socket (3) | Closed. | 2023-02-22 18:38:50.533
HD Request # 7 | Error downloading historical Intraday data for ESH23_FUT_CME. Exchange not specified | 2023-02-22 18:38:50.914
Historical data download thread signaled to stop. | 2023-02-22 18:38:50.914
HD Request # 7 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for ESH23_FUT_CME | 2023-02-22 18:38:50.914
HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2023-02-22 17:20:42.672002 | 2023-02-22 18:38:50.915
HD Request # 7 | Completion time: 1s. | 2023-02-22 18:38:50.915
HD Request # 7 | Intraday data download complete for ESH23_FUT_CME. Unique request ID: 7 | 2023-02-22 18:38:50.915
Removing historical data download ID 7. | 2023-02-22 18:38:50.915
Real-time Intraday chart data file updates started for ESH23_FUT_CME | 2023-02-22 18:38:50.915
Intraday chart data file opened for ESH23_FUT_CME | 2023-02-22 18:38:50.915
HD Request # 7 | Enabling Intraday chart updating for symbol. | 2023-02-22 18:38:50.915
Triggering next historical data download in queue. | 2023-02-22 18:38:50.915
HD Request # 8 | Downloading Intraday chart data for ZFM0-CBOT to the file ZFM0-CBOT.scid. Service: rithmic_v2.trading | 2023-02-22 18:38:50.915
HD Request # 8 | Download start date-time: 2022-08-20 19:38:50.000000. File last date-time: 00:00:00.000000 | 2023-02-22 18:38:50.915
HD Request # 8 | Using server: rsc.rithmic.com port 50530. Use encryption. | 2023-02-22 18:38:50.916
Socket (3) | Creating socket. Using TLS 1.2. | 2023-02-22 18:38:50.916
Socket (3) | New receive buffer size: 5242880 | 2023-02-22 18:38:50.916
Socket (3) | Connecting to IP: 216.57.156.163. | 2023-02-22 18:38:50.916
HD Request # 8 | Sending historical data logon request message. | 2023-02-22 18:38:51.031
HD Request # 8 | Requesting Intraday data. Start date-time: 2022-08-20 19:38:50. Record interval: 0. Symbol: ZFM0-CBOT | 2023-02-22 18:38:51.379
Socket (3) | CloseSocket call. | 2023-02-22 18:38:51.493
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:38:51.493
HD Request # 8 | Error downloading historical Intraday data for ZFM0-CBOT. Exchange not specified | 2023-02-22 18:38:51.528
Historical data download thread signaled to stop. | 2023-02-22 18:38:51.528
HD Request # 8 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for ZFM0-CBOT | 2023-02-22 18:38:51.528
HD Request # 8 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2023-02-22 18:38:51.529
HD Request # 8 | Completion time: 1s. | 2023-02-22 18:38:51.529
HD Request # 8 | Intraday data download complete for ZFM0-CBOT. Unique request ID: 8 | 2023-02-22 18:38:51.529
Removing historical data download ID 8. | 2023-02-22 18:38:51.529
Real-time Intraday chart data file updates started for ZFM0-CBOT | 2023-02-22 18:38:51.529
Intraday chart data file opened for ZFM0-CBOT | 2023-02-22 18:38:51.529
HD Request # 8 | Enabling Intraday chart updating for symbol. | 2023-02-22 18:38:51.529
Triggering next historical data download in queue. | 2023-02-22 18:38:51.529
No download requests in the queue to start downloads for. | 2023-02-22 18:38:51.529
Socket (3) | Socket gracefully closed by remote side. | 2023-02-22 18:38:51.607
Socket (3) | Closed. | 2023-02-22 18:38:51.607
Requesting market depth updates for: ESH23_FUT_CME if supported. | 2023-02-22 18:38:52.636
Rithmic Direct - DTC | Market Depth data has been rejected for symbol: ESH23_FUT_CME. Exchange not specified | 2023-02-22 18:38:52.750
HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (3) | Creating socket. Using TLS 1.2. | 2023-02-22 18:39:07.152
HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (3) | New receive buffer size: 32768 | 2023-02-22 18:39:07.152
HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (3) | Connecting to IP: 38.79.0.89. | 2023-02-22 18:39:07.152
HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (3) | New receive buffer size: 65536 | 2023-02-22 18:39:07.636
HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (3) | Socket gracefully closed by remote side. | 2023-02-22 18:39:07.729
HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (3) | CloseSocket call. | 2023-02-22 18:39:07.730
HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-02-22 18:39:07.730
HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (3) | Closed. | 2023-02-22 18:39:07.730
Enabling compression for file: C:\SierraChart\Data\ESH3.CME.scid. This may take a while. | 2023-02-22 18:39:15.606
File compression enabled. C:\SierraChart\Data\ESH3.CME.scid. CompressionState=2 | 2023-02-22 18:39:15.606
ESH3.CME [CBV-D] 1 Min #1 | Reloading chart. | 2023-02-22 18:39:15.608
Added historical Intraday data request for ESH3.CME to the queue. | 2023-02-22 18:39:15.609
Triggering next historical data download in queue. | 2023-02-22 18:39:15.609
ESH3.CME [CBV-D] 1 Min #1 | Performing continuous chart historical Daily data download for symbol ESH3.CME starting at last date in file. | 2023-02-22 18:39:15.611
Added historical Daily data request for ESH3.CME to the queue. | 2023-02-22 18:39:15.611
Triggering next historical data download in queue. | 2023-02-22 18:39:15.611
ESH3.CME [CBV-D] 1 Min #1 | Waiting for historical downloads to complete with the IDs: 9, 10, | 2023-02-22 18:39:15.612
Mapping ESH3.CME to ESH23. Service code: cme | 2023-02-22 18:39:15.613
HD Request # 9 | Downloading Intraday chart data for ESH3.CME to the file ESH3.CME.scid. Service: cme | 2023-02-22 18:39:15.613
HD Request # 9 | Download start date-time: 2022-11-30 01:00:00.000000. File last date-time: 00:00:00.000000 | 2023-02-22 18:39:15.614
HD Request # 9 | Using server: ds26.sierracharts.com port 10149 | 2023-02-22 18:39:15.614
HD Request # 10 | Downloading Historical Daily chart data for ESH3.CME. Starting date: 1973-02-22. Service: rithmic.trading | 2023-02-22 18:39:15.615
Socket (3) | Creating socket. | 2023-02-22 18:39:15.623
Socket (3) | New receive buffer size: 5242880 | 2023-02-22 18:39:15.623
Socket (3) | Connecting to IP: 142.215.17.188. | 2023-02-22 18:39:15.623
HD Request # 9 | Setting DTC encoding to Binary VLS | 2023-02-22 18:39:15.854
HD Request # 9 | Sending historical data logon request message. | 2023-02-22 18:39:15.854
HD Request # 10 | Requesting historical Daily data for ESH23 starting at 1973-02-21. SC External HD service. | 2023-02-22 18:39:15.966
HD Request # 10 | Receiving historical Daily data for ESH3.CME starting at 2021-06-04. | 2023-02-22 18:39:16.256
HD Request # 10 | Writing historical Daily data to the file ESH3.CME.dly. | 2023-02-22 18:39:16.256
HD Request # 10 | Bytes received: 22448 | 2023-02-22 18:39:16.264
HD Request # 10 | Received 432 Daily data records from 2021-06-04 00:00:00 to 2023-02-21 00:00:00 (628.0 days) and wrote 432 records for ESH3.CME | 2023-02-22 18:39:16.264
HD Request # 10 | Completion time: 1s. | 2023-02-22 18:39:16.264
HD Request # 10 | Daily data download complete for ESH3.CME. Unique request ID: 10 | 2023-02-22 18:39:16.264
Removing historical data download ID 10. | 2023-02-22 18:39:16.264
Triggering next historical data download in queue. | 2023-02-22 18:39:16.264
No download requests in the queue to start downloads for. | 2023-02-22 18:39:16.265
HD Request # 9 | Requesting Intraday data. Start date-time: 2022-11-30 01:00:00. Record interval: 0. Symbol: ESH23 | 2023-02-22 18:39:16.495
HD Request # 9 | Decompressing data. | 2023-02-22 18:39:16.612
HD Request # 9 | Receiving Intraday data for ESH3.CME starting at 2022-11-30 01:00:13.733000 | 2023-02-22 18:39:16.846
HD Request # 9 | Timestamp of first Intraday data file record written: 2022-11-30 01:00:13.733000. | 2023-02-22 18:39:17.438
Enabling compression for file: C:\SierraChart\Data\MESH3.CME.scid. This may take a while. | 2023-02-22 18:39:33.257
File compression enabled. C:\SierraChart\Data\MESH3.CME.scid. CompressionState=0 | 2023-02-22 18:39:33.257
MESH3.CME #4 | Reloading chart. | 2023-02-22 18:39:33.259
MESH3.CME #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 18:39:33.269
Mapping MESH3.CME to MESH23. Service code: cme | 2023-02-22 18:39:33.787
Denali Data Feed | Starting real-time market data updates for: MESH3.CME (MESH23). ID: 9 Service code: cme | 2023-02-22 18:39:33.787
Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443 | 2023-02-22 18:39:33.787
Denali Data Feed | Requesting security definition data for: MESH3.CME (MESH23). ID: 9 | 2023-02-22 18:39:33.791
Added historical Intraday data request for MESH3.CME to the queue. | 2023-02-22 18:39:33.791
Intraday data recording state for symbol MESH3.CME is set to download 'Pending'. | 2023-02-22 18:39:33.791
Triggering next historical data download in queue. | 2023-02-22 18:39:33.791
DTC Client socket (4) | Creating socket. | 2023-02-22 18:39:33.799
DTC Client socket (4) | New receive buffer size: 5242880 | 2023-02-22 18:39:33.799
DTC Client socket (4) | Connecting to IP: 142.215.18.147. | 2023-02-22 18:39:33.799
Denali Data Feed | Network connection to server complete. | 2023-02-22 18:39:33.960
Denali Data Feed | Starting socket receive thread. | 2023-02-22 18:39:33.960
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-22 18:39:33.961
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-02-22 18:39:34.080
Denali Data Feed | Sending logon request message. | 2023-02-22 18:39:34.080
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 18:39:34.229
Denali Data Feed | Received logon response. | 2023-02-22 18:39:34.966
Denali Data Feed | Server Name: SC Realtime Server. | 2023-02-22 18:39:34.966
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-02-22 18:39:34.966
Denali Data Feed | Successfully connected. | 2023-02-22 18:39:34.966
Denali Data Feed | Trading is not supported. | 2023-02-22 18:39:34.966
Denali Data Feed | Restarting real-time data updates for symbol: MESH3.CME -> MESH23 | 2023-02-22 18:39:34.966
Denali Data Feed | Received security definition for symbol MESH3.CME | 2023-02-22 18:39:35.174
Unsubscribed from market depth data for ESH23_FUT_CME | 2023-02-22 18:39:37.632
Requesting market depth updates for: MESH3.CME if supported. | 2023-02-22 18:39:37.632
Rithmic Direct - DTC | Market Depth data has been rejected for symbol: ESH23_FUT_CME. Exchange not specified | 2023-02-22 18:39:37.751
Denali Data Feed | Market Depth data has been rejected for symbol: MESH3.CME. Not authorized for market depth. | 2023-02-22 18:39:37.862
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 18:39:50.754
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 18:40:11.276
ESH3.CME [CBV-D] Rev. 4t #9 | Reloading chart. | 2023-02-22 18:40:24.999
Enabling compression for file: C:\SierraChart\Data\ESH3.CME.dly. This may take a while. | 2023-02-22 18:40:25.005
File compression enabled. C:\SierraChart\Data\ESH3.CME.dly. CompressionState=0 | 2023-02-22 18:40:25.005
ESH3.CME [CBV-D] Rev. 4t #9 | Waiting for historical downloads to complete with the IDs: 9, | 2023-02-22 18:40:25.035
ESH3.CME [CBV-D] #6 | Reloading chart. | 2023-02-22 18:40:42.603
Added historical Intraday data request for ESZ0.CME to the queue. | 2023-02-22 18:40:42.603
Triggering next historical data download in queue. | 2023-02-22 18:40:42.603
ESH3.CME [CBV-D] #6 | Performing continuous chart historical Daily data download for symbol ESZ0.CME starting at last date in file. | 2023-02-22 18:40:42.605
Added historical Daily data request for ESZ0.CME to the queue. | 2023-02-22 18:40:42.605
Triggering next historical data download in queue. | 2023-02-22 18:40:42.605
Added historical Intraday data request for ESH1.CME to the queue. | 2023-02-22 18:40:42.606
ESH3.CME [CBV-D] #6 | Performing continuous chart historical Daily data download for symbol ESH1.CME starting at last date in file. | 2023-02-22 18:40:42.607
Added historical Daily data request for ESH1.CME to the queue. | 2023-02-22 18:40:42.607
Added historical Intraday data request for ESM1.CME to the queue. | 2023-02-22 18:40:42.608
ESH3.CME [CBV-D] #6 | Performing continuous chart historical Daily data download for symbol ESM1.CME starting at last date in file. | 2023-02-22 18:40:42.609
Added historical Daily data request for ESM1.CME to the queue. | 2023-02-22 18:40:42.609
Added historical Intraday data request for ESU1.CME to the queue. | 2023-02-22 18:40:42.610
ESH3.CME [CBV-D] #6 | Performing continuous chart historical Daily data download for symbol ESU1.CME starting at last date in file. | 2023-02-22 18:40:42.611
Added historical Daily data request for ESU1.CME to the queue. | 2023-02-22 18:40:42.611
Added historical Intraday data request for ESZ1.CME to the queue. | 2023-02-22 18:40:42.612
ESH3.CME [CBV-D] #6 | Performing continuous chart historical Daily data download for symbol ESZ1.CME starting at last date in file. | 2023-02-22 18:40:42.613
Added historical Daily data request for ESZ1.CME to the queue. | 2023-02-22 18:40:42.614
Added historical Intraday data request for ESH2.CME to the queue. | 2023-02-22 18:40:42.614
ESH3.CME [CBV-D] #6 | Performing continuous chart historical Daily data download for symbol ESH2.CME starting at last date in file. | 2023-02-22 18:40:42.616
Added historical Daily data request for ESH2.CME to the queue. | 2023-02-22 18:40:42.616
Added historical Intraday data request for ESM2.CME to the queue. | 2023-02-22 18:40:42.616
ESH3.CME [CBV-D] #6 | Performing continuous chart historical Daily data download for symbol ESM2.CME starting at last date in file. | 2023-02-22 18:40:42.618
Added historical Daily data request for ESM2.CME to the queue. | 2023-02-22 18:40:42.618
Added historical Intraday data request for ESU2.CME to the queue. | 2023-02-22 18:40:42.618
ESH3.CME [CBV-D] #6 | Performing continuous chart historical Daily data download for symbol ESU2.CME starting at last date in file. | 2023-02-22 18:40:42.620
Added historical Daily data request for ESU2.CME to the queue. | 2023-02-22 18:40:42.620
Added historical Intraday data request for ESZ2.CME to the queue. | 2023-02-22 18:40:42.621
ESH3.CME [CBV-D] #6 | Performing continuous chart historical Daily data download for symbol ESZ2.CME starting at last date in file. | 2023-02-22 18:40:42.622
Added historical Daily data request for ESZ2.CME to the queue. | 2023-02-22 18:40:42.622
ESH3.CME [CBV-D] #6 | Waiting for historical downloads to complete with the IDs: 9, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, | 2023-02-22 18:40:42.664
Mapping ESZ0.CME to ESZ20. Service code: cme | 2023-02-22 18:40:42.665
HD Request # 11 | Downloading Historical Daily chart data for ESZ0.CME. Starting date: 1973-02-22. Service: rithmic.trading | 2023-02-22 18:40:42.667
HD Request # 11 | Requesting historical Daily data for ESZ20 starting at 1973-02-21. SC External HD service. | 2023-02-22 18:40:43.027
HD Request # 11 | Receiving historical Daily data for ESZ0.CME starting at 2019-09-09. | 2023-02-22 18:40:43.313
HD Request # 11 | Writing historical Daily data to the file ESZ0.CME.dly. | 2023-02-22 18:40:43.313
HD Request # 11 | Bytes received: 17544 | 2023-02-22 18:40:43.318
HD Request # 11 | Received 325 Daily data records from 2019-09-09 00:00:00 to 2020-12-18 00:00:00 (467.0 days) and wrote 325 records for ESZ0.CME | 2023-02-22 18:40:43.318
HD Request # 11 | Completion time: 1s. | 2023-02-22 18:40:43.319
HD Request # 11 | Daily data download complete for ESZ0.CME. Unique request ID: 13 | 2023-02-22 18:40:43.319
Removing historical data download ID 13. | 2023-02-22 18:40:43.319
Triggering next historical data download in queue. | 2023-02-22 18:40:43.319
Mapping ESH1.CME to ESH21. Service code: cme | 2023-02-22 18:40:43.319
HD Request # 12 | Downloading Historical Daily chart data for ESH1.CME. Starting date: 1973-02-22. Service: rithmic.trading | 2023-02-22 18:40:43.320
HD Request # 12 | Requesting historical Daily data for ESH21 starting at 1973-02-21. SC External HD service. | 2023-02-22 18:40:43.715
HD Request # 12 | Receiving historical Daily data for ESH1.CME starting at 2019-12-09. | 2023-02-22 18:40:44.006
HD Request # 12 | Writing historical Daily data to the file ESH1.CME.dly. | 2023-02-22 18:40:44.006
HD Request # 12 | Bytes received: 17082 | 2023-02-22 18:40:44.012
HD Request # 12 | Received 322 Daily data records from 2019-12-09 00:00:00 to 2021-03-19 00:00:00 (467.0 days) and wrote 322 records for ESH1.CME | 2023-02-22 18:40:44.012
HD Request # 12 | Completion time: 1s. | 2023-02-22 18:40:44.012
HD Request # 12 | Daily data download complete for ESH1.CME. Unique request ID: 15 | 2023-02-22 18:40:44.012
Removing historical data download ID 15. | 2023-02-22 18:40:44.012
Triggering next historical data download in queue. | 2023-02-22 18:40:44.012
Mapping ESM1.CME to ESM21. Service code: cme | 2023-02-22 18:40:44.012
HD Request # 13 | Downloading Historical Daily chart data for ESM1.CME. Starting date: 1973-02-22. Service: rithmic.trading | 2023-02-22 18:40:44.013
HD Request # 13 | Requesting historical Daily data for ESM21 starting at 1973-02-21. SC External HD service. | 2023-02-22 18:40:44.358
HD Request # 13 | Receiving historical Daily data for ESM1.CME starting at 2020-03-09. | 2023-02-22 18:40:44.536
HD Request # 13 | Writing historical Daily data to the file ESM1.CME.dly. | 2023-02-22 18:40:44.537
HD Request # 13 | Bytes received: 17103 | 2023-02-22 18:40:44.543
HD Request # 13 | Received 324 Daily data records from 2020-03-09 00:00:00 to 2021-06-18 00:00:00 (467.0 days) and wrote 324 records for ESM1.CME | 2023-02-22 18:40:44.543
HD Request # 13 | Completion time: 0s. | 2023-02-22 18:40:44.543
HD Request # 13 | Daily data download complete for ESM1.CME. Unique request ID: 17 | 2023-02-22 18:40:44.543
Removing historical data download ID 17. | 2023-02-22 18:40:44.543
Triggering next historical data download in queue. | 2023-02-22 18:40:44.543
Mapping ESU1.CME to ESU21. Service code: cme | 2023-02-22 18:40:44.543
HD Request # 14 | Downloading Historical Daily chart data for ESU1.CME. Starting date: 1973-02-22. Service: rithmic.trading | 2023-02-22 18:40:44.544
HD Request # 14 | Requesting historical Daily data for ESU21 starting at 1973-02-21. SC External HD service. | 2023-02-22 18:40:44.994
HD Request # 14 | Receiving historical Daily data for ESU1.CME starting at 2020-06-08. | 2023-02-22 18:40:45.257
HD Request # 14 | Writing historical Daily data to the file ESU1.CME.dly. | 2023-02-22 18:40:45.258
HD Request # 14 | Bytes received: 16991 | 2023-02-22 18:40:45.263
HD Request # 14 | Received 324 Daily data records from 2020-06-08 00:00:00 to 2021-09-17 00:00:00 (467.0 days) and wrote 324 records for ESU1.CME | 2023-02-22 18:40:45.264
HD Request # 14 | Completion time: 1s. | 2023-02-22 18:40:45.264
HD Request # 14 | Daily data download complete for ESU1.CME. Unique request ID: 19 | 2023-02-22 18:40:45.264
Removing historical data download ID 19. | 2023-02-22 18:40:45.264
Triggering next historical data download in queue. | 2023-02-22 18:40:45.264
Mapping ESZ1.CME to ESZ21. Service code: cme | 2023-02-22 18:40:45.264
HD Request # 15 | Downloading Historical Daily chart data for ESZ1.CME. Starting date: 1973-02-22. Service: rithmic.trading | 2023-02-22 18:40:45.265
HD Request # 15 | Requesting historical Daily data for ESZ21 starting at 1973-02-21. SC External HD service. | 2023-02-22 18:40:45.604
HD Request # 15 | Receiving historical Daily data for ESZ1.CME starting at 2020-09-08. | 2023-02-22 18:40:45.860
HD Request # 15 | Writing historical Daily data to the file ESZ1.CME.dly. | 2023-02-22 18:40:45.861
HD Request # 15 | Bytes received: 17253 | 2023-02-22 18:40:45.866
HD Request # 15 | Received 324 Daily data records from 2020-09-08 00:00:00 to 2021-12-17 00:00:00 (466.0 days) and wrote 324 records for ESZ1.CME | 2023-02-22 18:40:45.866
HD Request # 15 | Completion time: 0s. | 2023-02-22 18:40:45.867
HD Request # 15 | Daily data download complete for ESZ1.CME. Unique request ID: 21 | 2023-02-22 18:40:45.867
Removing historical data download ID 21. | 2023-02-22 18:40:45.867
Triggering next historical data download in queue. | 2023-02-22 18:40:45.867
Mapping ESH2.CME to ESH22. Service code: cme | 2023-02-22 18:40:45.867
HD Request # 16 | Downloading Historical Daily chart data for ESH2.CME. Starting date: 1973-02-22. Service: rithmic.trading | 2023-02-22 18:40:45.868
HD Request # 16 | Requesting historical Daily data for ESH22 starting at 1973-02-21. SC External HD service. | 2023-02-22 18:40:46.224
HD Request # 16 | Receiving historical Daily data for ESH2.CME starting at 2020-12-07. | 2023-02-22 18:40:46.402
HD Request # 16 | Writing historical Daily data to the file ESH2.CME.dly. | 2023-02-22 18:40:46.402
HD Request # 16 | Bytes received: 17262 | 2023-02-22 18:40:46.408
HD Request # 16 | Received 323 Daily data records from 2020-12-07 00:00:00 to 2022-03-18 00:00:00 (467.0 days) and wrote 323 records for ESH2.CME | 2023-02-22 18:40:46.408
HD Request # 16 | Completion time: 1s. | 2023-02-22 18:40:46.408
HD Request # 16 | Daily data download complete for ESH2.CME. Unique request ID: 23 | 2023-02-22 18:40:46.408
Removing historical data download ID 23. | 2023-02-22 18:40:46.408
Triggering next historical data download in queue. | 2023-02-22 18:40:46.408
Mapping ESM2.CME to ESM22. Service code: cme | 2023-02-22 18:40:46.408
HD Request # 17 | Downloading Historical Daily chart data for ESM2.CME. Starting date: 1973-02-22. Service: rithmic.trading | 2023-02-22 18:40:46.410
HD Request # 17 | Requesting historical Daily data for ESM22 starting at 1973-02-21. SC External HD service. | 2023-02-22 18:40:46.769
HD Request # 17 | Receiving historical Daily data for ESM2.CME starting at 2021-03-08. | 2023-02-22 18:40:46.991
HD Request # 17 | Writing historical Daily data to the file ESM2.CME.dly. | 2023-02-22 18:40:46.992
HD Request # 17 | Bytes received: 17703 | 2023-02-22 18:40:46.997
HD Request # 17 | Received 325 Daily data records from 2021-03-08 00:00:00 to 2022-06-17 00:00:00 (467.0 days) and wrote 325 records for ESM2.CME | 2023-02-22 18:40:46.997
HD Request # 17 | Completion time: 0s. | 2023-02-22 18:40:46.997
HD Request # 17 | Daily data download complete for ESM2.CME. Unique request ID: 25 | 2023-02-22 18:40:46.997
Removing historical data download ID 25. | 2023-02-22 18:40:46.997
Triggering next historical data download in queue. | 2023-02-22 18:40:46.997
Mapping ESU2.CME to ESU22. Service code: cme | 2023-02-22 18:40:46.998
HD Request # 18 | Downloading Historical Daily chart data for ESU2.CME. Starting date: 1973-02-22. Service: rithmic.trading | 2023-02-22 18:40:46.999
HD Request # 18 | Requesting historical Daily data for ESU22 starting at 1973-02-21. SC External HD service. | 2023-02-22 18:40:47.413
HD Request # 18 | Receiving historical Daily data for ESU2.CME starting at 2021-06-04. | 2023-02-22 18:40:47.603
HD Request # 18 | Writing historical Daily data to the file ESU2.CME.dly. | 2023-02-22 18:40:47.604
HD Request # 18 | Bytes received: 17187 | 2023-02-22 18:40:47.609
HD Request # 18 | Received 325 Daily data records from 2021-06-04 00:00:00 to 2022-09-16 00:00:00 (470.0 days) and wrote 325 records for ESU2.CME | 2023-02-22 18:40:47.609
HD Request # 18 | Completion time: 1s. | 2023-02-22 18:40:47.609
HD Request # 18 | Daily data download complete for ESU2.CME. Unique request ID: 27 | 2023-02-22 18:40:47.609
Removing historical data download ID 27. | 2023-02-22 18:40:47.609
Triggering next historical data download in queue. | 2023-02-22 18:40:47.609
Mapping ESZ2.CME to ESZ22. Service code: cme | 2023-02-22 18:40:47.610
HD Request # 19 | Downloading Historical Daily chart data for ESZ2.CME. Starting date: 1973-02-22. Service: rithmic.trading | 2023-02-22 18:40:47.611
HD Request # 19 | Requesting historical Daily data for ESZ22 starting at 1973-02-21. SC External HD service. | 2023-02-22 18:40:47.991
HD Request # 19 | Receiving historical Daily data for ESZ2.CME starting at 2021-06-04. | 2023-02-22 18:40:48.166
HD Request # 19 | Writing historical Daily data to the file ESZ2.CME.dly. | 2023-02-22 18:40:48.167
HD Request # 19 | Bytes received: 20622 | 2023-02-22 18:40:48.173
HD Request # 19 | Received 389 Daily data records from 2021-06-04 00:00:00 to 2022-12-16 00:00:00 (561.0 days) and wrote 389 records for ESZ2.CME | 2023-02-22 18:40:48.173
HD Request # 19 | Completion time: 1s. | 2023-02-22 18:40:48.174
HD Request # 19 | Daily data download complete for ESZ2.CME. Unique request ID: 29 | 2023-02-22 18:40:48.174
Removing historical data download ID 29. | 2023-02-22 18:40:48.174
Triggering next historical data download in queue. | 2023-02-22 18:40:48.174
No download requests in the queue to start downloads for. | 2023-02-22 18:40:48.174
ESH3.CME [CBV-D] 30 Min #2 | Reloading chart. | 2023-02-22 18:40:57.873
Enabling compression for file: C:\SierraChart\Data\ESH2.CME.scid. This may take a while. | 2023-02-22 18:40:57.873
File compression enabled. C:\SierraChart\Data\ESH2.CME.scid. CompressionState=0 | 2023-02-22 18:40:57.873
Enabling compression for file: C:\SierraChart\Data\ESM2.CME.scid. This may take a while. | 2023-02-22 18:40:57.877
File compression enabled. C:\SierraChart\Data\ESM2.CME.scid. CompressionState=0 | 2023-02-22 18:40:57.877
Enabling compression for file: C:\SierraChart\Data\ESU2.CME.scid. This may take a while. | 2023-02-22 18:40:57.881
File compression enabled. C:\SierraChart\Data\ESU2.CME.scid. CompressionState=0 | 2023-02-22 18:40:57.881
Enabling compression for file: C:\SierraChart\Data\ESZ2.CME.scid. This may take a while. | 2023-02-22 18:40:57.885
File compression enabled. C:\SierraChart\Data\ESZ2.CME.scid. CompressionState=0 | 2023-02-22 18:40:57.885
Enabling compression for file: C:\SierraChart\Data\ESZ2.CME.dly. This may take a while. | 2023-02-22 18:40:57.923
File compression enabled. C:\SierraChart\Data\ESZ2.CME.dly. CompressionState=0 | 2023-02-22 18:40:57.923
Enabling compression for file: C:\SierraChart\Data\ESU2.CME.dly. This may take a while. | 2023-02-22 18:40:57.969
File compression enabled. C:\SierraChart\Data\ESU2.CME.dly. CompressionState=0 | 2023-02-22 18:40:57.969
Enabling compression for file: C:\SierraChart\Data\ESM2.CME.dly. This may take a while. | 2023-02-22 18:40:58.012
File compression enabled. C:\SierraChart\Data\ESM2.CME.dly. CompressionState=0 | 2023-02-22 18:40:58.013
Enabling compression for file: C:\SierraChart\Data\ESH2.CME.dly. This may take a while. | 2023-02-22 18:40:58.056
File compression enabled. C:\SierraChart\Data\ESH2.CME.dly. CompressionState=0 | 2023-02-22 18:40:58.057
ESH3.CME [CBV-D] 30 Min #2 | Waiting for historical downloads to complete with the IDs: 9, 22, 24, 26, 28, | 2023-02-22 18:40:58.105
ESH3.CME [CBV-D] Daily #4 | Reloading chart. | 2023-02-22 18:41:13.200
ESH3.CME [CBV-D] Daily #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2023-02-22 18:41:13.200
ESH3.CME [CBV-D] Daily #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2023-02-22 18:41:13.200
ESH3.CME [CBV-D] Daily #4 | Performing continuous chart historical Daily data download for symbol ESH8.CME starting at last date in file. | 2023-02-22 18:41:13.201
Added historical Daily data request for ESH8.CME to the queue. | 2023-02-22 18:41:13.201
Triggering next historical data download in queue. | 2023-02-22 18:41:13.202
ESH3.CME [CBV-D] Daily #4 | Performing continuous chart historical Daily data download for symbol ESM8.CME starting at last date in file. | 2023-02-22 18:41:13.203
Added historical Daily data request for ESM8.CME to the queue. | 2023-02-22 18:41:13.203
ESH3.CME [CBV-D] Daily #4 | Performing continuous chart historical Daily data download for symbol ESU8.CME starting at last date in file. | 2023-02-22 18:41:13.205
Added historical Daily data request for ESU8.CME to the queue. | 2023-02-22 18:41:13.205
ESH3.CME [CBV-D] Daily #4 | Performing continuous chart historical Daily data download for symbol ESZ8.CME starting at last date in file. | 2023-02-22 18:41:13.206
Added historical Daily data request for ESZ8.CME to the queue. | 2023-02-22 18:41:13.206
ESH3.CME [CBV-D] Daily #4 | Performing continuous chart historical Daily data download for symbol ESH9.CME starting at last date in file. | 2023-02-22 18:41:13.208
Added historical Daily data request for ESH9.CME to the queue. | 2023-02-22 18:41:13.208
ESH3.CME [CBV-D] Daily #4 | Performing continuous chart historical Daily data download for symbol ESM9.CME starting at last date in file. | 2023-02-22 18:41:13.209
Added historical Daily data request for ESM9.CME to the queue. | 2023-02-22 18:41:13.209
ESH3.CME [CBV-D] Daily #4 | Performing continuous chart historical Daily data download for symbol ESU9.CME starting at last date in file. | 2023-02-22 18:41:13.211
Added historical Daily data request for ESU9.CME to the queue. | 2023-02-22 18:41:13.211
ESH3.CME [CBV-D] Daily #4 | Performing continuous chart historical Daily data download for symbol ESZ9.CME starting at last date in file. | 2023-02-22 18:41:13.213
Added historical Daily data request for ESZ9.CME to the queue. | 2023-02-22 18:41:13.213
ESH3.CME [CBV-D] Daily #4 | Performing continuous chart historical Daily data download for symbol ESH0.CME starting at last date in file. | 2023-02-22 18:41:13.214
Added historical Daily data request for ESH0.CME to the queue. | 2023-02-22 18:41:13.214
ESH3.CME [CBV-D] Daily #4 | Performing continuous chart historical Daily data download for symbol ESM0.CME starting at last date in file. | 2023-02-22 18:41:13.216
Added historical Daily data request for ESM0.CME to the queue. | 2023-02-22 18:41:13.216
ESH3.CME [CBV-D] Daily #4 | Performing continuous chart historical Daily data download for symbol ESU0.CME starting at last date in file. | 2023-02-22 18:41:13.217
Added historical Daily data request for ESU0.CME to the queue. | 2023-02-22 18:41:13.217
Enabling compression for file: C:\SierraChart\Data\ESZ1.CME.dly. This may take a while. | 2023-02-22 18:41:13.451
File compression enabled. C:\SierraChart\Data\ESZ1.CME.dly. CompressionState=0 | 2023-02-22 18:41:13.451
Enabling compression for file: C:\SierraChart\Data\ESU1.CME.dly. This may take a while. | 2023-02-22 18:41:13.496
File compression enabled. C:\SierraChart\Data\ESU1.CME.dly. CompressionState=0 | 2023-02-22 18:41:13.496
Enabling compression for file: C:\SierraChart\Data\ESM1.CME.dly. This may take a while. | 2023-02-22 18:41:13.540
File compression enabled. C:\SierraChart\Data\ESM1.CME.dly. CompressionState=0 | 2023-02-22 18:41:13.540
Enabling compression for file: C:\SierraChart\Data\ESH1.CME.dly. This may take a while. | 2023-02-22 18:41:13.584
File compression enabled. C:\SierraChart\Data\ESH1.CME.dly. CompressionState=0 | 2023-02-22 18:41:13.584
Enabling compression for file: C:\SierraChart\Data\ESZ0.CME.dly. This may take a while. | 2023-02-22 18:41:13.626
File compression enabled. C:\SierraChart\Data\ESZ0.CME.dly. CompressionState=0 | 2023-02-22 18:41:13.626
ESH3.CME [CBV-D] Daily #4 | Waiting for historical downloads to complete with the IDs: 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, | 2023-02-22 18:41:13.680
Mapping ESH8.CME to ESH18. Service code: cme | 2023-02-22 18:41:13.683
HD Request # 20 | Downloading Historical Daily chart data for ESH8.CME. Starting date: 1973-02-22. Service: rithmic.trading | 2023-02-22 18:41:13.684
HD Request # 20 | Requesting historical Daily data for ESH18 starting at 1973-02-21. SC External HD service. | 2023-02-22 18:41:14.017
HD Request # 20 | Receiving historical Daily data for ESH8.CME starting at 2016-12-16. | 2023-02-22 18:41:14.321
HD Request # 20 | Writing historical Daily data to the file ESH8.CME.dly. | 2023-02-22 18:41:14.323
HD Request # 20 | Bytes received: 16611 | 2023-02-22 18:41:14.329
HD Request # 20 | Received 313 Daily data records from 2016-12-16 00:00:00 to 2018-03-16 00:00:00 (456.0 days) and wrote 313 records for ESH8.CME | 2023-02-22 18:41:14.329
HD Request # 20 | Completion time: 1s. | 2023-02-22 18:41:14.329
HD Request # 20 | Daily data download complete for ESH8.CME. Unique request ID: 30 | 2023-02-22 18:41:14.329
Removing historical data download ID 30. | 2023-02-22 18:41:14.329
Triggering next historical data download in queue. | 2023-02-22 18:41:14.329
Mapping ESM8.CME to ESM18. Service code: cme | 2023-02-22 18:41:14.329
HD Request # 21 | Downloading Historical Daily chart data for ESM8.CME. Starting date: 1973-02-22. Service: rithmic.trading | 2023-02-22 18:41:14.330
HD Request # 21 | Requesting historical Daily data for ESM18 starting at 1973-02-21. SC External HD service. | 2023-02-22 18:41:14.675
HD Request # 21 | Receiving historical Daily data for ESM8.CME starting at 2017-03-17. | 2023-02-22 18:41:14.874
HD Request # 21 | Writing historical Daily data to the file ESM8.CME.dly. | 2023-02-22 18:41:14.875
HD Request # 21 | Bytes received: 16826 | 2023-02-22 18:41:14.881
HD Request # 21 | Received 315 Daily data records from 2017-03-17 00:00:00 to 2018-06-15 00:00:00 (456.0 days) and wrote 315 records for ESM8.CME | 2023-02-22 18:41:14.881
HD Request # 21 | Completion time: 0s. | 2023-02-22 18:41:14.882
HD Request # 21 | Daily data download complete for ESM8.CME. Unique request ID: 31 | 2023-02-22 18:41:14.882
Removing historical data download ID 31. | 2023-02-22 18:41:14.882
Triggering next historical data download in queue. | 2023-02-22 18:41:14.882
Mapping ESU8.CME to ESU18. Service code: cme | 2023-02-22 18:41:14.882
HD Request # 22 | Downloading Historical Daily chart data for ESU8.CME. Starting date: 1973-02-22. Service: rithmic.trading | 2023-02-22 18:41:14.883
HD Request # 22 | Requesting historical Daily data for ESU18 starting at 1973-02-21. SC External HD service. | 2023-02-22 18:41:15.221
HD Request # 22 | Receiving historical Daily data for ESU8.CME starting at 2017-06-14. | 2023-02-22 18:41:15.410
HD Request # 22 | Writing historical Daily data to the file ESU8.CME.dly. | 2023-02-22 18:41:15.411
HD Request # 22 | Bytes received: 17339 | 2023-02-22 18:41:15.416
HD Request # 22 | Received 322 Daily data records from 2017-06-14 00:00:00 to 2018-09-21 00:00:00 (465.0 days) and wrote 322 records for ESU8.CME | 2023-02-22 18:41:15.416
HD Request # 22 | Completion time: 1s. | 2023-02-22 18:41:15.416
HD Request # 22 | Daily data download complete for ESU8.CME. Unique request ID: 32 | 2023-02-22 18:41:15.416
Removing historical data download ID 32. | 2023-02-22 18:41:15.416
Triggering next historical data download in queue. | 2023-02-22 18:41:15.416
Mapping ESZ8.CME to ESZ18. Service code: cme | 2023-02-22 18:41:15.416
HD Request # 23 | Downloading Historical Daily chart data for ESZ8.CME. Starting date: 1973-02-22. Service: rithmic.trading | 2023-02-22 18:41:15.418
HD Request # 23 | Requesting historical Daily data for ESZ18 starting at 1973-02-21. SC External HD service. | 2023-02-22 18:41:15.756
HD Request # 23 | Receiving historical Daily data for ESZ8.CME starting at 2017-09-13. | 2023-02-22 18:41:16.037
HD Request # 23 | Writing historical Daily data to the file ESZ8.CME.dly. | 2023-02-22 18:41:16.038
HD Request # 23 | Bytes received: 17557 | 2023-02-22 18:41:16.043
HD Request # 23 | Received 322 Daily data records from 2017-09-13 00:00:00 to 2018-12-21 00:00:00 (465.0 days) and wrote 322 records for ESZ8.CME | 2023-02-22 18:41:16.043
HD Request # 23 | Completion time: 1s. | 2023-02-22 18:41:16.043
HD Request # 23 | Daily data download complete for ESZ8.CME. Unique request ID: 33 | 2023-02-22 18:41:16.043
Removing historical data download ID 33. | 2023-02-22 18:41:16.043
Triggering next historical data download in queue. | 2023-02-22 18:41:16.043
Mapping ESH9.CME to ESH19. Service code: cme | 2023-02-22 18:41:16.043
HD Request # 24 | Downloading Historical Daily chart data for ESH9.CME. Starting date: 1973-02-22. Service: rithmic.trading | 2023-02-22 18:41:16.045
HD Request # 24 | Requesting historical Daily data for ESH19 starting at 1973-02-21. SC External HD service. | 2023-02-22 18:41:16.381
HD Request # 24 | Receiving historical Daily data for ESH9.CME starting at 2017-12-13. | 2023-02-22 18:41:16.561
HD Request # 24 | Writing historical Daily data to the file ESH9.CME.dly. | 2023-02-22 18:41:16.562
HD Request # 24 | Bytes received: 16918 | 2023-02-22 18:41:16.567
HD Request # 24 | Received 314 Daily data records from 2017-12-13 00:00:00 to 2019-03-15 00:00:00 (458.0 days) and wrote 314 records for ESH9.CME | 2023-02-22 18:41:16.567
HD Request # 24 | Completion time: 0s. | 2023-02-22 18:41:16.567
HD Request # 24 | Daily data download complete for ESH9.CME. Unique request ID: 34 | 2023-02-22 18:41:16.567
Removing historical data download ID 34. | 2023-02-22 18:41:16.567
Triggering next historical data download in queue. | 2023-02-22 18:41:16.567
Mapping ESM9.CME to ESM19. Service code: cme | 2023-02-22 18:41:16.568
HD Request # 25 | Downloading Historical Daily chart data for ESM9.CME. Starting date: 1973-02-22. Service: rithmic.trading | 2023-02-22 18:41:16.569
HD Request # 25 | Requesting historical Daily data for ESM19 starting at 1973-02-21. SC External HD service. | 2023-02-22 18:41:16.911
HD Request # 25 | Receiving historical Daily data for ESM9.CME starting at 2018-03-14. | 2023-02-22 18:41:17.169
HD Request # 25 | Writing historical Daily data to the file ESM9.CME.dly. | 2023-02-22 18:41:17.170
HD Request # 25 | Bytes received: 17319 | 2023-02-22 18:41:17.175
HD Request # 25 | Received 321 Daily data records from 2018-03-14 00:00:00 to 2019-06-21 00:00:00 (465.0 days) and wrote 321 records for ESM9.CME | 2023-02-22 18:41:17.175
HD Request # 25 | Completion time: 1s. | 2023-02-22 18:41:17.175
HD Request # 25 | Daily data download complete for ESM9.CME. Unique request ID: 35 | 2023-02-22 18:41:17.175
Removing historical data download ID 35. | 2023-02-22 18:41:17.175
Triggering next historical data download in queue. | 2023-02-22 18:41:17.175
Mapping ESU9.CME to ESU19. Service code: cme | 2023-02-22 18:41:17.175
HD Request # 26 | Downloading Historical Daily chart data for ESU9.CME. Starting date: 1973-02-22. Service: rithmic.trading | 2023-02-22 18:41:17.176
HD Request # 26 | Requesting historical Daily data for ESU19 starting at 1973-02-21. SC External HD service. | 2023-02-22 18:41:17.580
HD Request # 26 | Receiving historical Daily data for ESU9.CME starting at 2018-06-15. | 2023-02-22 18:41:17.844
HD Request # 26 | Writing historical Daily data to the file ESU9.CME.dly. | 2023-02-22 18:41:17.845
HD Request # 26 | Bytes received: 17017 | 2023-02-22 18:41:17.850
HD Request # 26 | Received 319 Daily data records from 2018-06-15 00:00:00 to 2019-09-20 00:00:00 (463.0 days) and wrote 319 records for ESU9.CME | 2023-02-22 18:41:17.850
HD Request # 26 | Completion time: 0s. | 2023-02-22 18:41:17.850
HD Request # 26 | Daily data download complete for ESU9.CME. Unique request ID: 36 | 2023-02-22 18:41:17.850
Removing historical data download ID 36. | 2023-02-22 18:41:17.850
Triggering next historical data download in queue. | 2023-02-22 18:41:17.850
Mapping ESZ9.CME to ESZ19. Service code: cme | 2023-02-22 18:41:17.851
HD Request # 27 | Downloading Historical Daily chart data for ESZ9.CME. Starting date: 1973-02-22. Service: rithmic.trading | 2023-02-22 18:41:17.852
HD Request # 27 | Requesting historical Daily data for ESZ19 starting at 1973-02-21. SC External HD service. | 2023-02-22 18:41:18.196
HD Request # 27 | Receiving historical Daily data for ESZ9.CME starting at 2018-09-13. | 2023-02-22 18:41:18.367
HD Request # 27 | Writing historical Daily data to the file ESZ9.CME.dly. | 2023-02-22 18:41:18.367
HD Request # 27 | Bytes received: 17225 | 2023-02-22 18:41:18.372
HD Request # 27 | Received 321 Daily data records from 2018-09-13 00:00:00 to 2019-12-20 00:00:00 (464.0 days) and wrote 321 records for ESZ9.CME | 2023-02-22 18:41:18.372
HD Request # 27 | Completion time: 1s. | 2023-02-22 18:41:18.373
HD Request # 27 | Daily data download complete for ESZ9.CME. Unique request ID: 37 | 2023-02-22 18:41:18.373
Removing historical data download ID 37. | 2023-02-22 18:41:18.373
Triggering next historical data download in queue. | 2023-02-22 18:41:18.373
Mapping ESH0.CME to ESH20. Service code: cme | 2023-02-22 18:41:18.373
HD Request # 28 | Downloading Historical Daily chart data for ESH0.CME. Starting date: 1973-02-22. Service: rithmic.trading | 2023-02-22 18:41:18.374
HD Request # 28 | Requesting historical Daily data for ESH20 starting at 1973-02-21. SC External HD service. | 2023-02-22 18:41:18.716
HD Request # 28 | Receiving historical Daily data for ESH0.CME starting at 2018-12-20. | 2023-02-22 18:41:18.904
HD Request # 28 | Writing historical Daily data to the file ESH0.CME.dly. | 2023-02-22 18:41:18.904
HD Request # 28 | Bytes received: 16858 | 2023-02-22 18:41:18.911
HD Request # 28 | Received 314 Daily data records from 2018-12-20 00:00:00 to 2020-03-20 00:00:00 (457.0 days) and wrote 314 records for ESH0.CME | 2023-02-22 18:41:18.911
HD Request # 28 | Completion time: 0s. | 2023-02-22 18:41:18.912
HD Request # 28 | Daily data download complete for ESH0.CME. Unique request ID: 38 | 2023-02-22 18:41:18.912
Removing historical data download ID 38. | 2023-02-22 18:41:18.912
Triggering next historical data download in queue. | 2023-02-22 18:41:18.912
Mapping ESM0.CME to ESM20. Service code: cme | 2023-02-22 18:41:18.912
HD Request # 29 | Downloading Historical Daily chart data for ESM0.CME. Starting date: 1973-02-22. Service: rithmic.trading | 2023-02-22 18:41:18.913
HD Request # 29 | Requesting historical Daily data for ESM20 starting at 1973-02-21. SC External HD service. | 2023-02-22 18:41:19.326
HD Request # 29 | Receiving historical Daily data for ESM0.CME starting at 2019-03-14. | 2023-02-22 18:41:19.505
HD Request # 29 | Writing historical Daily data to the file ESM0.CME.dly. | 2023-02-22 18:41:19.506
HD Request # 29 | Bytes received: 17048 | 2023-02-22 18:41:19.511
HD Request # 29 | Received 321 Daily data records from 2019-03-14 00:00:00 to 2020-06-19 00:00:00 (464.0 days) and wrote 321 records for ESM0.CME | 2023-02-22 18:41:19.511
HD Request # 29 | Completion time: 1s. | 2023-02-22 18:41:19.511
HD Request # 29 | Daily data download complete for ESM0.CME. Unique request ID: 39 | 2023-02-22 18:41:19.511
Removing historical data download ID 39. | 2023-02-22 18:41:19.511
Triggering next historical data download in queue. | 2023-02-22 18:41:19.511
Mapping ESU0.CME to ESU20. Service code: cme | 2023-02-22 18:41:19.511
HD Request # 30 | Downloading Historical Daily chart data for ESU0.CME. Starting date: 1973-02-22. Service: rithmic.trading | 2023-02-22 18:41:19.513
HD Request # 30 | Requesting historical Daily data for ESU20 starting at 1973-02-21. SC External HD service. | 2023-02-22 18:41:19.843
HD Request # 30 | Receiving historical Daily data for ESU0.CME starting at 2019-06-10. | 2023-02-22 18:41:20.032
HD Request # 30 | Writing historical Daily data to the file ESU0.CME.dly. | 2023-02-22 18:41:20.033
HD Request # 30 | Bytes received: 17142 | 2023-02-22 18:41:20.039
HD Request # 30 | Received 324 Daily data records from 2019-06-10 00:00:00 to 2020-09-18 00:00:00 (467.0 days) and wrote 324 records for ESU0.CME | 2023-02-22 18:41:20.039
HD Request # 30 | Completion time: 1s. | 2023-02-22 18:41:20.039
HD Request # 30 | Daily data download complete for ESU0.CME. Unique request ID: 40 | 2023-02-22 18:41:20.039
Removing historical data download ID 40. | 2023-02-22 18:41:20.039
Triggering next historical data download in queue. | 2023-02-22 18:41:20.039
No download requests in the queue to start downloads for. | 2023-02-22 18:41:20.039
ESH3.CME [CBV] Daily #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-22 18:41:20.203
ESH3.CME [CBV] Daily #4 | Reloading chart. | 2023-02-22 18:41:20.205
Enabling compression for file: C:\SierraChart\Data\ESH8.CME.dly. This may take a while. | 2023-02-22 18:41:20.424
File compression enabled. C:\SierraChart\Data\ESH8.CME.dly. CompressionState=0 | 2023-02-22 18:41:20.424
Enabling compression for file: C:\SierraChart\Data\ESM8.CME.dly. This may take a while. | 2023-02-22 18:41:20.436
File compression enabled. C:\SierraChart\Data\ESM8.CME.dly. CompressionState=0 | 2023-02-22 18:41:20.436
Enabling compression for file: C:\SierraChart\Data\ESU8.CME.dly. This may take a while. | 2023-02-22 18:41:20.453
File compression enabled. C:\SierraChart\Data\ESU8.CME.dly. CompressionState=0 | 2023-02-22 18:41:20.453
Enabling compression for file: C:\SierraChart\Data\ESZ8.CME.dly. This may take a while. | 2023-02-22 18:41:20.480
File compression enabled. C:\SierraChart\Data\ESZ8.CME.dly. CompressionState=0 | 2023-02-22 18:41:20.480
Enabling compression for file: C:\SierraChart\Data\ESH9.CME.dly. This may take a while. | 2023-02-22 18:41:20.507
File compression enabled. C:\SierraChart\Data\ESH9.CME.dly. CompressionState=0 | 2023-02-22 18:41:20.507
Enabling compression for file: C:\SierraChart\Data\ESM9.CME.dly. This may take a while. | 2023-02-22 18:41:20.534
File compression enabled. C:\SierraChart\Data\ESM9.CME.dly. CompressionState=2 | 2023-02-22 18:41:20.534
Enabling compression for file: C:\SierraChart\Data\ESU9.CME.dly. This may take a while. | 2023-02-22 18:41:20.561
File compression enabled. C:\SierraChart\Data\ESU9.CME.dly. CompressionState=0 | 2023-02-22 18:41:20.561
Enabling compression for file: C:\SierraChart\Data\ESZ9.CME.dly. This may take a while. | 2023-02-22 18:41:20.589
File compression enabled. C:\SierraChart\Data\ESZ9.CME.dly. CompressionState=0 | 2023-02-22 18:41:20.589
Enabling compression for file: C:\SierraChart\Data\ESH0.CME.dly. This may take a while. | 2023-02-22 18:41:20.619
File compression enabled. C:\SierraChart\Data\ESH0.CME.dly. CompressionState=0 | 2023-02-22 18:41:20.619
Enabling compression for file: C:\SierraChart\Data\ESM0.CME.dly. This may take a while. | 2023-02-22 18:41:20.636
File compression enabled. C:\SierraChart\Data\ESM0.CME.dly. CompressionState=0 | 2023-02-22 18:41:20.636
Enabling compression for file: C:\SierraChart\Data\ESU0.CME.dly. This may take a while. | 2023-02-22 18:41:20.652
File compression enabled. C:\SierraChart\Data\ESU0.CME.dly. CompressionState=0 | 2023-02-22 18:41:20.653
ESH3.CME [CBV] Daily #4 | Reloading chart. | 2023-02-22 18:41:23.440
ESH3.CME [CBV] Daily #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2023-02-22 18:41:23.440
ESH3.CME [CBV] Daily #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2023-02-22 18:41:23.440
Denali Data Feed | Starting real-time market data updates for: ESH3.CME (ESH23). ID: 8 Service code: cme | 2023-02-22 18:41:27.887
Denali Data Feed | Requesting security definition data for: ESH3.CME (ESH23). ID: 8 | 2023-02-22 18:41:27.887
Denali Data Feed | Received security definition for symbol ESH3.CME | 2023-02-22 18:41:28.111
Socket (3) | CloseSocket call. | 2023-02-22 18:41:59.213
Historical data download thread signaled to stop. | 2023-02-22 18:41:59.213
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:41:59.214
HD Request # 9 | Received 54167044 Intraday data records from 2022-11-30 01:00:13.733000 to 2023-02-22 18:41:55.041000 (84.7 days) and wrote 54167044 records for ESH3.CME | 2023-02-22 18:41:59.214
HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2023-02-22 17:41:55.041000 | 2023-02-22 18:41:59.215
Added 33 Time and Sales records to Intraday data file for ESH3.CME after download. | 2023-02-22 18:41:59.215
HD Request # 9 | Completion time: 2m 44s. | 2023-02-22 18:41:59.215
HD Request # 9 | Intraday data download complete for ESH3.CME. Unique request ID: 9 | 2023-02-22 18:41:59.215
Removing historical data download ID 9. | 2023-02-22 18:41:59.215
Real-time Intraday chart data file updates started for ESH3.CME | 2023-02-22 18:41:59.215
Intraday chart data file opened for ESH3.CME | 2023-02-22 18:41:59.215
HD Request # 9 | Enabling Intraday chart updating for symbol. | 2023-02-22 18:41:59.215
Triggering next historical data download in queue. | 2023-02-22 18:41:59.215
Initiating new historical data download for ESH3.CME to get the latest data since the download was started while not connected to primary service. | 2023-02-22 18:41:59.215
Added historical Intraday data request for ESH3.CME to the queue. | 2023-02-22 18:41:59.215
Intraday data recording state for symbol ESH3.CME is set to download 'Pending'. | 2023-02-22 18:41:59.215
HD Request # 31 | Downloading Intraday chart data for ESH3.CME to the file ESH3.CME.scid. Service: cme | 2023-02-22 18:41:59.215
HD Request # 31 | Download start date-time: 2023-02-22 18:41:58.000000. File last date-time: 2023-02-22 18:41:58.509000 | 2023-02-22 18:41:59.216
HD Request # 31 | Using server: ds28.sierracharts.com port 10150 | 2023-02-22 18:41:59.216
Socket (5) | Creating socket. | 2023-02-22 18:41:59.216
Socket (5) | New receive buffer size: 5242880 | 2023-02-22 18:41:59.216
Socket (5) | Connecting to IP: 142.215.18.147. | 2023-02-22 18:41:59.216
Socket (3) | Socket gracefully closed by remote side. | 2023-02-22 18:41:59.326
Socket (3) | Closed. | 2023-02-22 18:41:59.326
HD Request # 31 | Setting DTC encoding to Binary VLS | 2023-02-22 18:41:59.445
HD Request # 31 | Sending historical data logon request message. | 2023-02-22 18:41:59.445
ESH3.CME [CBV] Rev. 4t #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-22 18:41:59.521
ESH3.CME [CBV] Rev. 4t #9 | Reloading chart. | 2023-02-22 18:41:59.655
ESH3.CME [CBV] 1 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-22 18:41:59.664
ESH3.CME [CBV] 1 Min #1 | Reloading chart. | 2023-02-22 18:41:59.666
HD Request # 31 | Requesting Intraday data. Start date-time: 2023-02-22 18:41:58. Record interval: 0. Symbol: ESH23 | 2023-02-22 18:42:00.074
ESH3.CME [CBV] Rev. 4t #9 | Reloading chart. | 2023-02-22 18:42:00.145
ESH3.CME [CBV] Rev. 4t #9 | Waiting for historical downloads to complete with the IDs: 41, | 2023-02-22 18:42:00.178
ESH3.CME [CBV] 1 Min #1 | Reloading chart. | 2023-02-22 18:42:00.181
HD Request # 31 | Decompressing data. | 2023-02-22 18:42:00.193
HD Request # 31 | Receiving Intraday data for ESH3.CME starting at 2023-02-22 18:41:58.093000 | 2023-02-22 18:42:00.194
Socket (5) | CloseSocket call. | 2023-02-22 18:42:00.194
Socket (5) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:42:00.194
ESH3.CME [CBV] 1 Min #1 | Waiting for historical downloads to complete with the IDs: 41, | 2023-02-22 18:42:00.215
Historical data download thread signaled to stop. | 2023-02-22 18:42:00.217
HD Request # 31 | Received 28 Intraday data records from 2023-02-22 18:41:58.093000 to 2023-02-22 18:41:58.509000 (0.4 seconds) and wrote 0 records for ESH3.CME | 2023-02-22 18:42:00.217
HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2023-02-22 17:41:58.509000 | 2023-02-22 18:42:00.218
Added 28 Time and Sales records to Intraday data file for ESH3.CME after download. | 2023-02-22 18:42:00.218
HD Request # 31 | Timestamp of first Intraday data file record written: 2023-02-22 18:41:59.643000. | 2023-02-22 18:42:00.218
HD Request # 31 | Completion time: 1s. | 2023-02-22 18:42:00.218
HD Request # 31 | Intraday data download complete for ESH3.CME. Unique request ID: 41 | 2023-02-22 18:42:00.218
Removing historical data download ID 41. | 2023-02-22 18:42:00.218
Real-time Intraday chart data file updates started for ESH3.CME | 2023-02-22 18:42:00.218
Intraday chart data file opened for ESH3.CME | 2023-02-22 18:42:00.218
HD Request # 31 | Enabling Intraday chart updating for symbol. | 2023-02-22 18:42:00.218
Triggering next historical data download in queue. | 2023-02-22 18:42:00.218
HD Request # 32 | Downloading Intraday chart data for MESH3.CME to the file MESH3.CME.scid. Service: cme | 2023-02-22 18:42:00.219
HD Request # 32 | Download start date-time: 2022-08-20 19:42:00.000000. File last date-time: 00:00:00.000000 | 2023-02-22 18:42:00.219
HD Request # 32 | Using server: ds23.sierracharts.com port 10149 | 2023-02-22 18:42:00.219
Socket (3) | Creating socket. | 2023-02-22 18:42:00.220
Socket (3) | New receive buffer size: 5242880 | 2023-02-22 18:42:00.220
Socket (3) | Connecting to IP: 142.215.17.190. | 2023-02-22 18:42:00.220
Socket (5) | Socket gracefully closed by remote side. | 2023-02-22 18:42:00.308
Socket (5) | Closed. | 2023-02-22 18:42:00.308
HD Request # 32 | Setting DTC encoding to Binary VLS | 2023-02-22 18:42:00.458
HD Request # 32 | Sending historical data logon request message. | 2023-02-22 18:42:00.458
ESH3.CME [CBV] Rev. 4t #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-22 18:42:00.645
ESH3.CME [CBV] Rev. 4t #9 | Reloading chart. | 2023-02-22 18:42:00.646
ESH3.CME [CBV] 1 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-22 18:42:00.675
ESH3.CME [CBV] 1 Min #1 | Reloading chart. | 2023-02-22 18:42:00.676
ESH3.CME [CBV] 1 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 18:42:01.067
HD Request # 32 | Requesting Intraday data. Start date-time: 2022-08-20 19:42:00. Record interval: 0. Symbol: MESH23 | 2023-02-22 18:42:01.099
HD Request # 32 | Decompressing data. | 2023-02-22 18:42:01.212
Opened cached Intraday file: C:\SierraChart\Data\ESH3.CME.scid. Thread ID: 70332 | 2023-02-22 18:42:01.238
ESH3.CME [CBV] Rev. 4t #9 | Reloading chart. | 2023-02-22 18:42:01.496
ESH3.CME [CBV] 1 Min #1 | Reloading chart. | 2023-02-22 18:42:01.539
HD Request # 32 | Receiving Intraday data for MESH3.CME starting at 2022-08-22 01:13:30.069000 | 2023-02-22 18:42:01.711
HD Request # 32 | Timestamp of first Intraday data file record written: 2022-08-22 01:13:30.069000. | 2023-02-22 18:42:02.748
ESH3.CME [CBV][M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 18:42:02.989
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 18:42:11.755
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 18:42:11.882
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 18:42:34.150
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 18:43:33.219
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 18:43:33.234
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 18:43:37.708
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 18:43:37.849
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 18:43:52.471
Socket (3) | CloseSocket call. | 2023-02-22 18:44:16.813
Historical data download thread signaled to stop. | 2023-02-22 18:44:16.813
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:44:16.813
HD Request # 32 | Received 35062019 Intraday data records from 2022-08-22 01:13:30.069000 to 2023-02-22 18:44:16.179000 (184.8 days) and wrote 35062019 records for MESH3.CME | 2023-02-22 18:44:16.814
HD Request # 32 | Add time&sales data | Remembered last file record date-time: 2023-02-22 17:44:16.179000 | 2023-02-22 18:44:16.815
Added 10 Time and Sales records to Intraday data file for MESH3.CME after download. | 2023-02-22 18:44:16.815
HD Request # 32 | Completion time: 2m 16s. | 2023-02-22 18:44:16.815
HD Request # 32 | Intraday data download complete for MESH3.CME. Unique request ID: 11 | 2023-02-22 18:44:16.815
Removing historical data download ID 11. | 2023-02-22 18:44:16.815
Real-time Intraday chart data file updates started for MESH3.CME | 2023-02-22 18:44:16.815
Intraday chart data file opened for MESH3.CME | 2023-02-22 18:44:16.815
HD Request # 32 | Enabling Intraday chart updating for symbol. | 2023-02-22 18:44:16.815
Triggering next historical data download in queue. | 2023-02-22 18:44:16.815
HD Request # 33 | Downloading Intraday chart data for ESZ0.CME to the file ESZ0.CME.scid. Service: cme | 2023-02-22 18:44:16.815
Enabling compression for file: C:\SierraChart\Data\ESZ0.CME.scid. This may take a while. | 2023-02-22 18:44:16.815
File compression enabled. C:\SierraChart\Data\ESZ0.CME.scid. CompressionState=0 | 2023-02-22 18:44:16.815
HD Request # 33 | Download start date-time: 2020-09-02 02:00:00.000000. File last date-time: 00:00:00.000000 | 2023-02-22 18:44:16.816
HD Request # 33 | Using server: ds26.sierracharts.com port 10150 | 2023-02-22 18:44:16.816
Socket (5) | Creating socket. | 2023-02-22 18:44:16.816
Socket (5) | New receive buffer size: 5242880 | 2023-02-22 18:44:16.816
Socket (5) | Connecting to IP: 142.215.17.188. | 2023-02-22 18:44:16.816
Socket (3) | Socket gracefully closed by remote side. | 2023-02-22 18:44:16.928
Socket (3) | Closed. | 2023-02-22 18:44:16.928
HD Request # 33 | Setting DTC encoding to Binary VLS | 2023-02-22 18:44:17.046
HD Request # 33 | Sending historical data logon request message. | 2023-02-22 18:44:17.046
HD Request # 33 | Requesting Intraday data. Start date-time: 2020-09-02 02:00:00. Record interval: 0. Symbol: ESZ20 | 2023-02-22 18:44:17.678
Opened cached Intraday file: C:\SierraChart\Data\MESH3.CME.scid. Thread ID: 70332 | 2023-02-22 18:44:17.682
HD Request # 33 | Decompressing data. | 2023-02-22 18:44:17.825
HD Request # 33 | Receiving Intraday data for ESZ0.CME starting at 2020-09-02 02:00:01.098000 | 2023-02-22 18:44:18.075
HD Request # 33 | Timestamp of first Intraday data file record written: 2020-09-02 02:00:01.098000. | 2023-02-22 18:44:18.664
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 18:47:06.461
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 18:47:06.648
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 18:47:22.383
Socket (5) | CloseSocket call. | 2023-02-22 18:47:29.529
Historical data download thread signaled to stop. | 2023-02-22 18:47:29.529
Socket (5) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:47:29.529
HD Request # 33 | Received 59426676 Intraday data records from 2020-09-02 02:00:01.098000 to 2020-12-18 15:29:59.953003 (107.6 days) and wrote 59426676 records for ESZ0.CME | 2023-02-22 18:47:29.529
HD Request # 33 | Add time&sales data | Remembered last file record date-time: 2020-12-18 14:29:59.953003 | 2023-02-22 18:47:29.530
HD Request # 33 | Completion time: 3m 13s. | 2023-02-22 18:47:29.530
HD Request # 33 | Intraday data download complete for ESZ0.CME. Unique request ID: 12 | 2023-02-22 18:47:29.530
Removing historical data download ID 12. | 2023-02-22 18:47:29.530
Real-time Intraday chart data file updates started for ESZ0.CME | 2023-02-22 18:47:29.530
Intraday chart data file opened for ESZ0.CME | 2023-02-22 18:47:29.530
HD Request # 33 | Enabling Intraday chart updating for symbol. | 2023-02-22 18:47:29.530
Triggering next historical data download in queue. | 2023-02-22 18:47:29.530
HD Request # 34 | Downloading Intraday chart data for ESH1.CME to the file ESH1.CME.scid. Service: cme | 2023-02-22 18:47:29.530
Enabling compression for file: C:\SierraChart\Data\ESH1.CME.scid. This may take a while. | 2023-02-22 18:47:29.531
File compression enabled. C:\SierraChart\Data\ESH1.CME.scid. CompressionState=0 | 2023-02-22 18:47:29.531
HD Request # 34 | Download start date-time: 2020-12-02 01:00:00.000000. File last date-time: 00:00:00.000000 | 2023-02-22 18:47:29.531
HD Request # 34 | Using server: ds28.sierracharts.com port 10149 | 2023-02-22 18:47:29.531
Socket (3) | Creating socket. | 2023-02-22 18:47:29.531
Socket (3) | New receive buffer size: 5242880 | 2023-02-22 18:47:29.531
Socket (3) | Connecting to IP: 142.215.18.147. | 2023-02-22 18:47:29.531
Socket (5) | Socket gracefully closed by remote side. | 2023-02-22 18:47:29.645
Socket (5) | Closed. | 2023-02-22 18:47:29.645
HD Request # 34 | Setting DTC encoding to Binary VLS | 2023-02-22 18:47:29.764
HD Request # 34 | Sending historical data logon request message. | 2023-02-22 18:47:29.764
HD Request # 34 | Requesting Intraday data. Start date-time: 2020-12-02 01:00:00. Record interval: 0. Symbol: ESH21 | 2023-02-22 18:47:30.409
HD Request # 34 | Decompressing data. | 2023-02-22 18:47:30.522
HD Request # 34 | Receiving Intraday data for ESH1.CME starting at 2020-12-02 01:00:16.125000 | 2023-02-22 18:47:30.868
HD Request # 34 | Timestamp of first Intraday data file record written: 2020-12-02 01:00:16.125000. | 2023-02-22 18:47:31.913
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 18:48:35.634
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 18:50:55.612
Socket (3) | CloseSocket call. | 2023-02-22 18:50:59.055
Historical data download thread signaled to stop. | 2023-02-22 18:50:59.055
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:50:59.055
HD Request # 34 | Received 56181555 Intraday data records from 2020-12-02 01:00:16.125000 to 2021-03-19 14:29:59.841000 (107.6 days) and wrote 56181555 records for ESH1.CME | 2023-02-22 18:50:59.055
HD Request # 34 | Add time&sales data | Remembered last file record date-time: 2021-03-19 13:29:59.841000 | 2023-02-22 18:50:59.056
HD Request # 34 | Completion time: 3m 30s. | 2023-02-22 18:50:59.056
HD Request # 34 | Intraday data download complete for ESH1.CME. Unique request ID: 14 | 2023-02-22 18:50:59.056
Removing historical data download ID 14. | 2023-02-22 18:50:59.056
Real-time Intraday chart data file updates started for ESH1.CME | 2023-02-22 18:50:59.056
Intraday chart data file opened for ESH1.CME | 2023-02-22 18:50:59.056
HD Request # 34 | Enabling Intraday chart updating for symbol. | 2023-02-22 18:50:59.056
Triggering next historical data download in queue. | 2023-02-22 18:50:59.056
HD Request # 35 | Downloading Intraday chart data for ESM1.CME to the file ESM1.CME.scid. Service: cme | 2023-02-22 18:50:59.056
Enabling compression for file: C:\SierraChart\Data\ESM1.CME.scid. This may take a while. | 2023-02-22 18:50:59.057
File compression enabled. C:\SierraChart\Data\ESM1.CME.scid. CompressionState=0 | 2023-02-22 18:50:59.057
HD Request # 35 | Download start date-time: 2021-03-03 01:00:00.000000. File last date-time: 00:00:00.000000 | 2023-02-22 18:50:59.057
HD Request # 35 | Using server: ds23.sierracharts.com port 10150 | 2023-02-22 18:50:59.057
Socket (5) | Creating socket. | 2023-02-22 18:50:59.057
Socket (5) | New receive buffer size: 5242880 | 2023-02-22 18:50:59.057
Socket (5) | Connecting to IP: 142.215.17.190. | 2023-02-22 18:50:59.057
Socket (3) | Socket gracefully closed by remote side. | 2023-02-22 18:50:59.167
Socket (3) | Closed. | 2023-02-22 18:50:59.167
HD Request # 35 | Setting DTC encoding to Binary VLS | 2023-02-22 18:50:59.296
HD Request # 35 | Sending historical data logon request message. | 2023-02-22 18:50:59.296
HD Request # 35 | Requesting Intraday data. Start date-time: 2021-03-03 01:00:00. Record interval: 0. Symbol: ESM21 | 2023-02-22 18:50:59.939
HD Request # 35 | Decompressing data. | 2023-02-22 18:51:00.060
HD Request # 35 | Receiving Intraday data for ESM1.CME starting at 2021-03-03 01:00:02.110000 | 2023-02-22 18:51:00.415
HD Request # 35 | Timestamp of first Intraday data file record written: 2021-03-03 01:00:02.110000. | 2023-02-22 18:51:01.617
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2023-02-08 18:51:40 | 2023-02-22 18:51:40.663
ESH3.CME [CBV][M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 2023-02-08 18:51:40 | 2023-02-22 18:51:40.703
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2023-02-08 18:52:23 | 2023-02-22 18:52:23.908
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 18:53:04.170
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2023-02-08 18:53:03 | 2023-02-22 18:53:04.354
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 18:53:11.144
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2023-02-08 18:53:11 | 2023-02-22 18:53:11.312
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2023-02-08 18:53:55 | 2023-02-22 18:53:55.822
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2023-02-08 18:53:56 | 2023-02-22 18:53:56.840
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2023-02-08 18:54:01 | 2023-02-22 18:54:01.152
Socket (5) | CloseSocket call. | 2023-02-22 18:54:01.200
Historical data download thread signaled to stop. | 2023-02-22 18:54:01.200
Socket (5) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:54:01.200
HD Request # 35 | Received 51839833 Intraday data records from 2021-03-03 01:00:02.110000 to 2021-06-18 15:29:59.991000 (107.6 days) and wrote 51839833 records for ESM1.CME | 2023-02-22 18:54:01.200
HD Request # 35 | Add time&sales data | Remembered last file record date-time: 2021-06-18 13:29:59.991000 | 2023-02-22 18:54:01.201
HD Request # 35 | Completion time: 3m 2s. | 2023-02-22 18:54:01.202
HD Request # 35 | Intraday data download complete for ESM1.CME. Unique request ID: 16 | 2023-02-22 18:54:01.202
Removing historical data download ID 16. | 2023-02-22 18:54:01.202
Real-time Intraday chart data file updates started for ESM1.CME | 2023-02-22 18:54:01.202
Intraday chart data file opened for ESM1.CME | 2023-02-22 18:54:01.202
HD Request # 35 | Enabling Intraday chart updating for symbol. | 2023-02-22 18:54:01.202
Triggering next historical data download in queue. | 2023-02-22 18:54:01.202
HD Request # 36 | Downloading Intraday chart data for ESU1.CME to the file ESU1.CME.scid. Service: cme | 2023-02-22 18:54:01.202
Enabling compression for file: C:\SierraChart\Data\ESU1.CME.scid. This may take a while. | 2023-02-22 18:54:01.202
File compression enabled. C:\SierraChart\Data\ESU1.CME.scid. CompressionState=0 | 2023-02-22 18:54:01.202
HD Request # 36 | Download start date-time: 2021-06-02 02:00:00.000000. File last date-time: 00:00:00.000000 | 2023-02-22 18:54:01.202
HD Request # 36 | Using server: ds26.sierracharts.com port 10149 | 2023-02-22 18:54:01.202
Socket (3) | Creating socket. | 2023-02-22 18:54:01.202
Socket (3) | New receive buffer size: 5242880 | 2023-02-22 18:54:01.202
Socket (3) | Connecting to IP: 142.215.17.188. | 2023-02-22 18:54:01.203
Socket (5) | Socket gracefully closed by remote side. | 2023-02-22 18:54:01.316
Socket (5) | Closed. | 2023-02-22 18:54:01.316
HD Request # 36 | Setting DTC encoding to Binary VLS | 2023-02-22 18:54:01.435
HD Request # 36 | Sending historical data logon request message. | 2023-02-22 18:54:01.435
HD Request # 36 | Requesting Intraday data. Start date-time: 2021-06-02 02:00:00. Record interval: 0. Symbol: ESU21 | 2023-02-22 18:54:02.064
HD Request # 36 | Decompressing data. | 2023-02-22 18:54:02.184
HD Request # 36 | Receiving Intraday data for ESU1.CME starting at 2021-06-02 02:00:40.896000 | 2023-02-22 18:54:02.425
HD Request # 36 | Timestamp of first Intraday data file record written: 2021-06-02 02:00:40.896000. | 2023-02-22 18:54:02.901
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 18:54:05.293
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2023-02-08 18:54:05 | 2023-02-22 18:54:05.457
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2023-02-08 18:54:09 | 2023-02-22 18:54:09.329
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2023-02-08 18:54:20 | 2023-02-22 18:54:20.998
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2023-02-08 18:54:33 | 2023-02-22 18:54:32.850
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2023-02-08 18:54:39 | 2023-02-22 18:54:39.287
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 18:54:55.999
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2023-02-08 18:54:54 | 2023-02-22 18:54:56.157
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2023-02-08 18:55:04 | 2023-02-22 18:55:04.293
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2023-02-08 18:55:07 | 2023-02-22 18:55:08.299
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2023-02-08 18:55:14 | 2023-02-22 18:55:14.802
ESH3.CME #3 | Reloading chart. | 2023-02-22 18:55:27.468
ESH3.CME #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 18:55:27.470
Requesting market depth updates for: ESH3.CME if supported. | 2023-02-22 18:55:27.681
Denali Data Feed | Market Depth data has been rejected for symbol: ESH3.CME. Not authorized for market depth. | 2023-02-22 18:55:27.895
Unsubscribed from market depth data for ESH3.CME | 2023-02-22 18:55:37.677
Socket (3) | CloseSocket call. | 2023-02-22 18:56:19.697
Historical data download thread signaled to stop. | 2023-02-22 18:56:19.697
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:56:19.697
HD Request # 36 | Received 41219719 Intraday data records from 2021-06-02 02:00:40.896000 to 2021-09-17 15:29:56.819002 (107.6 days) and wrote 41219719 records for ESU1.CME | 2023-02-22 18:56:19.785
HD Request # 36 | Add time&sales data | Remembered last file record date-time: 2021-09-17 13:29:56.819002 | 2023-02-22 18:56:19.786
HD Request # 36 | Completion time: 2m 18s. | 2023-02-22 18:56:19.786
HD Request # 36 | Intraday data download complete for ESU1.CME. Unique request ID: 18 | 2023-02-22 18:56:19.786
Removing historical data download ID 18. | 2023-02-22 18:56:19.786
Real-time Intraday chart data file updates started for ESU1.CME | 2023-02-22 18:56:19.786
Intraday chart data file opened for ESU1.CME | 2023-02-22 18:56:19.786
HD Request # 36 | Enabling Intraday chart updating for symbol. | 2023-02-22 18:56:19.786
Triggering next historical data download in queue. | 2023-02-22 18:56:19.786
HD Request # 37 | Downloading Intraday chart data for ESZ1.CME to the file ESZ1.CME.scid. Service: cme | 2023-02-22 18:56:19.786
Enabling compression for file: C:\SierraChart\Data\ESZ1.CME.scid. This may take a while. | 2023-02-22 18:56:19.786
File compression enabled. C:\SierraChart\Data\ESZ1.CME.scid. CompressionState=0 | 2023-02-22 18:56:19.786
HD Request # 37 | Download start date-time: 2021-09-01 02:00:00.000000. File last date-time: 00:00:00.000000 | 2023-02-22 18:56:19.787
HD Request # 37 | Using server: ds28.sierracharts.com port 10150 | 2023-02-22 18:56:19.787
Socket (3) | Socket gracefully closed by remote side. | 2023-02-22 18:56:19.833
Socket (3) | Closed. | 2023-02-22 18:56:19.833
Socket (5) | Creating socket. | 2023-02-22 18:56:19.834
Socket (5) | New receive buffer size: 5242880 | 2023-02-22 18:56:19.834
Socket (5) | Connecting to IP: 142.215.18.147. | 2023-02-22 18:56:19.834
HD Request # 37 | Setting DTC encoding to Binary VLS | 2023-02-22 18:56:20.066
HD Request # 37 | Sending historical data logon request message. | 2023-02-22 18:56:20.066
HD Request # 37 | Requesting Intraday data. Start date-time: 2021-09-01 02:00:00. Record interval: 0. Symbol: ESZ21 | 2023-02-22 18:56:20.696
HD Request # 37 | Decompressing data. | 2023-02-22 18:56:20.811
HD Request # 37 | Receiving Intraday data for ESZ1.CME starting at 2021-09-01 02:01:45.241000 | 2023-02-22 18:56:21.156
HD Request # 37 | Timestamp of first Intraday data file record written: 2021-09-01 02:01:45.241000. | 2023-02-22 18:56:22.220
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 18:58:14.571
ESH3.CME [CBV][M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 18:58:14.851
Socket (5) | CloseSocket call. | 2023-02-22 18:59:41.952
Historical data download thread signaled to stop. | 2023-02-22 18:59:41.952
Socket (5) | Shutdown started. Waiting for graceful close. | 2023-02-22 18:59:41.953
HD Request # 37 | Received 58128075 Intraday data records from 2021-09-01 02:01:45.241000 to 2021-12-17 15:29:58.216000 (107.6 days) and wrote 58128075 records for ESZ1.CME | 2023-02-22 18:59:41.953
HD Request # 37 | Add time&sales data | Remembered last file record date-time: 2021-12-17 14:29:58.216000 | 2023-02-22 18:59:41.954
HD Request # 37 | Completion time: 3m 22s. | 2023-02-22 18:59:41.954
HD Request # 37 | Intraday data download complete for ESZ1.CME. Unique request ID: 20 | 2023-02-22 18:59:41.954
Removing historical data download ID 20. | 2023-02-22 18:59:41.954
Real-time Intraday chart data file updates started for ESZ1.CME | 2023-02-22 18:59:41.954
Intraday chart data file opened for ESZ1.CME | 2023-02-22 18:59:41.954
HD Request # 37 | Enabling Intraday chart updating for symbol. | 2023-02-22 18:59:41.954
Triggering next historical data download in queue. | 2023-02-22 18:59:41.954
HD Request # 38 | Downloading Intraday chart data for ESH2.CME to the file ESH2.CME.scid. Service: cme | 2023-02-22 18:59:41.954
HD Request # 38 | Download start date-time: 2021-12-01 01:00:00.000000. File last date-time: 00:00:00.000000 | 2023-02-22 18:59:41.955
HD Request # 38 | Using server: ds23.sierracharts.com port 10149 | 2023-02-22 18:59:41.955
Socket (3) | Creating socket. | 2023-02-22 18:59:42.003
Socket (3) | New receive buffer size: 5242880 | 2023-02-22 18:59:42.003
Socket (3) | Connecting to IP: 142.215.17.190. | 2023-02-22 18:59:42.003
Socket (5) | Socket gracefully closed by remote side. | 2023-02-22 18:59:42.067
Socket (5) | Closed. | 2023-02-22 18:59:42.067
HD Request # 38 | Setting DTC encoding to Binary VLS | 2023-02-22 18:59:42.244
HD Request # 38 | Sending historical data logon request message. | 2023-02-22 18:59:42.244
HD Request # 38 | Requesting Intraday data. Start date-time: 2021-12-01 01:00:00. Record interval: 0. Symbol: ESH22 | 2023-02-22 18:59:42.877
HD Request # 38 | Decompressing data. | 2023-02-22 18:59:42.991
HD Request # 38 | Receiving Intraday data for ESH2.CME starting at 2021-12-01 01:00:08.367000 | 2023-02-22 18:59:43.353
HD Request # 38 | Timestamp of first Intraday data file record written: 2021-12-01 01:00:08.367000. | 2023-02-22 18:59:44.282
Socket (3) | CloseSocket call. | 2023-02-22 19:04:25.191
Historical data download thread signaled to stop. | 2023-02-22 19:04:25.191
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-02-22 19:04:25.191
HD Request # 38 | Received 79638850 Intraday data records from 2021-12-01 01:00:08.367000 to 2022-03-18 14:29:59.181000 (107.6 days) and wrote 79638850 records for ESH2.CME | 2023-02-22 19:04:25.192
HD Request # 38 | Add time&sales data | Remembered last file record date-time: 2022-03-18 13:29:59.181000 | 2023-02-22 19:04:25.192
HD Request # 38 | Completion time: 4m 44s. | 2023-02-22 19:04:25.192
HD Request # 38 | Intraday data download complete for ESH2.CME. Unique request ID: 22 | 2023-02-22 19:04:25.192
Removing historical data download ID 22. | 2023-02-22 19:04:25.192
Real-time Intraday chart data file updates started for ESH2.CME | 2023-02-22 19:04:25.193
Intraday chart data file opened for ESH2.CME | 2023-02-22 19:04:25.193
HD Request # 38 | Enabling Intraday chart updating for symbol. | 2023-02-22 19:04:25.193
Triggering next historical data download in queue. | 2023-02-22 19:04:25.193
HD Request # 39 | Downloading Intraday chart data for ESM2.CME to the file ESM2.CME.scid. Service: cme | 2023-02-22 19:04:25.193
HD Request # 39 | Download start date-time: 2022-03-02 01:00:00.000000. File last date-time: 00:00:00.000000 | 2023-02-22 19:04:25.193
HD Request # 39 | Using server: ds26.sierracharts.com port 10150 | 2023-02-22 19:04:25.193
Socket (5) | Creating socket. | 2023-02-22 19:04:25.234
Socket (5) | New receive buffer size: 5242880 | 2023-02-22 19:04:25.234
Socket (5) | Connecting to IP: 142.215.17.188. | 2023-02-22 19:04:25.234
Socket (3) | Socket gracefully closed by remote side. | 2023-02-22 19:04:25.306
Socket (3) | Closed. | 2023-02-22 19:04:25.306
HD Request # 39 | Setting DTC encoding to Binary VLS | 2023-02-22 19:04:25.465
HD Request # 39 | Sending historical data logon request message. | 2023-02-22 19:04:25.465
HD Request # 39 | Requesting Intraday data. Start date-time: 2022-03-02 01:00:00. Record interval: 0. Symbol: ESM22 | 2023-02-22 19:04:26.101
HD Request # 39 | Decompressing data. | 2023-02-22 19:04:26.223
HD Request # 39 | Receiving Intraday data for ESM2.CME starting at 2022-03-02 01:00:00.754000 | 2023-02-22 19:04:26.464
HD Request # 39 | Timestamp of first Intraday data file record written: 2022-03-02 01:00:00.754000. | 2023-02-22 19:04:27.042
Socket (5) | CloseSocket call. | 2023-02-22 19:09:01.862
Historical data download thread signaled to stop. | 2023-02-22 19:09:01.862
Socket (5) | Shutdown started. Waiting for graceful close. | 2023-02-22 19:09:01.862
HD Request # 39 | Received 79440412 Intraday data records from 2022-03-02 01:00:00.754000 to 2022-06-17 15:29:59.065001 (107.6 days) and wrote 79440412 records for ESM2.CME | 2023-02-22 19:09:01.862
HD Request # 39 | Add time&sales data | Remembered last file record date-time: 2022-06-17 13:29:59.065001 | 2023-02-22 19:09:01.863
HD Request # 39 | Completion time: 4m 36s. | 2023-02-22 19:09:01.863
HD Request # 39 | Intraday data download complete for ESM2.CME. Unique request ID: 24 | 2023-02-22 19:09:01.863
Removing historical data download ID 24. | 2023-02-22 19:09:01.863
Real-time Intraday chart data file updates started for ESM2.CME | 2023-02-22 19:09:01.863
Intraday chart data file opened for ESM2.CME | 2023-02-22 19:09:01.863
HD Request # 39 | Enabling Intraday chart updating for symbol. | 2023-02-22 19:09:01.863
Triggering next historical data download in queue. | 2023-02-22 19:09:01.863
HD Request # 40 | Downloading Intraday chart data for ESU2.CME to the file ESU2.CME.scid. Service: cme | 2023-02-22 19:09:01.863
HD Request # 40 | Download start date-time: 2022-06-01 02:00:00.000000. File last date-time: 00:00:00.000000 | 2023-02-22 19:09:01.864
HD Request # 40 | Using server: ds28.sierracharts.com port 10149 | 2023-02-22 19:09:01.864
Socket (3) | Creating socket. | 2023-02-22 19:09:01.864
Socket (3) | New receive buffer size: 5242880 | 2023-02-22 19:09:01.864
Socket (3) | Connecting to IP: 142.215.18.147. | 2023-02-22 19:09:01.864
Socket (5) | Socket gracefully closed by remote side. | 2023-02-22 19:09:01.984
Socket (5) | Closed. | 2023-02-22 19:09:01.984
HD Request # 40 | Setting DTC encoding to Binary VLS | 2023-02-22 19:09:02.100
HD Request # 40 | Sending historical data logon request message. | 2023-02-22 19:09:02.100
HD Request # 40 | Requesting Intraday data. Start date-time: 2022-06-01 02:00:00. Record interval: 0. Symbol: ESU22 | 2023-02-22 19:09:02.743
HD Request # 40 | Decompressing data. | 2023-02-22 19:09:02.856
HD Request # 40 | Receiving Intraday data for ESU2.CME starting at 2022-06-01 02:00:00.001000 | 2023-02-22 19:09:03.201
HD Request # 40 | Timestamp of first Intraday data file record written: 2022-06-01 02:00:00.001000. | 2023-02-22 19:09:04.239
Socket (3) | CloseSocket call. | 2023-02-22 19:13:19.424
Historical data download thread signaled to stop. | 2023-02-22 19:13:19.424
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-02-22 19:13:19.424
HD Request # 40 | Received 77179564 Intraday data records from 2022-06-01 02:00:00.001000 to 2022-09-16 15:29:59.499000 (107.6 days) and wrote 77179564 records for ESU2.CME | 2023-02-22 19:13:19.425
HD Request # 40 | Add time&sales data | Remembered last file record date-time: 2022-09-16 13:29:59.499000 | 2023-02-22 19:13:19.426
HD Request # 40 | Completion time: 4m 18s. | 2023-02-22 19:13:19.426
HD Request # 40 | Intraday data download complete for ESU2.CME. Unique request ID: 26 | 2023-02-22 19:13:19.426
Removing historical data download ID 26. | 2023-02-22 19:13:19.426
Real-time Intraday chart data file updates started for ESU2.CME | 2023-02-22 19:13:19.426
Intraday chart data file opened for ESU2.CME | 2023-02-22 19:13:19.426
HD Request # 40 | Enabling Intraday chart updating for symbol. | 2023-02-22 19:13:19.426
Triggering next historical data download in queue. | 2023-02-22 19:13:19.426
HD Request # 41 | Downloading Intraday chart data for ESZ2.CME to the file ESZ2.CME.scid. Service: cme | 2023-02-22 19:13:19.427
HD Request # 41 | Download start date-time: 2022-08-31 02:00:00.000000. File last date-time: 00:00:00.000000 | 2023-02-22 19:13:19.427
HD Request # 41 | Using server: ds23.sierracharts.com port 10150 | 2023-02-22 19:13:19.428
Socket (5) | Creating socket. | 2023-02-22 19:13:19.428
Socket (5) | New receive buffer size: 5242880 | 2023-02-22 19:13:19.428
Socket (5) | Connecting to IP: 142.215.17.190. | 2023-02-22 19:13:19.428
Socket (3) | Socket gracefully closed by remote side. | 2023-02-22 19:13:19.536
Socket (3) | Closed. | 2023-02-22 19:13:19.536
HD Request # 41 | Setting DTC encoding to Binary VLS | 2023-02-22 19:13:19.677
HD Request # 41 | Sending historical data logon request message. | 2023-02-22 19:13:19.677
HD Request # 41 | Requesting Intraday data. Start date-time: 2022-08-31 02:00:00. Record interval: 0. Symbol: ESZ22 | 2023-02-22 19:13:20.307
HD Request # 41 | Decompressing data. | 2023-02-22 19:13:20.420
HD Request # 41 | Receiving Intraday data for ESZ2.CME starting at 2022-08-31 02:00:03.286000 | 2023-02-22 19:13:20.781
HD Request # 41 | Timestamp of first Intraday data file record written: 2022-08-31 02:00:03.286000. | 2023-02-22 19:13:21.838
Socket (5) | CloseSocket call. | 2023-02-22 19:18:48.778
Socket (5) | Shutdown started. Waiting for graceful close. | 2023-02-22 19:18:48.778
Historical data download thread signaled to stop. | 2023-02-22 19:18:48.812
HD Request # 41 | Received 93264560 Intraday data records from 2022-08-31 02:00:03.286000 to 2022-12-16 15:29:59.597000 (107.6 days) and wrote 93264560 records for ESZ2.CME | 2023-02-22 19:18:48.813
HD Request # 41 | Add time&sales data | Remembered last file record date-time: 2022-12-16 14:29:59.597000 | 2023-02-22 19:18:48.814
HD Request # 41 | Completion time: 5m 29s. | 2023-02-22 19:18:48.814
HD Request # 41 | Intraday data download complete for ESZ2.CME. Unique request ID: 28 | 2023-02-22 19:18:48.814
Removing historical data download ID 28. | 2023-02-22 19:18:48.814
Real-time Intraday chart data file updates started for ESZ2.CME | 2023-02-22 19:18:48.814
Intraday chart data file opened for ESZ2.CME | 2023-02-22 19:18:48.814
HD Request # 41 | Enabling Intraday chart updating for symbol. | 2023-02-22 19:18:48.814
Triggering next historical data download in queue. | 2023-02-22 19:18:48.814
No download requests in the queue to start downloads for. | 2023-02-22 19:18:48.814
ESH3.CME [CBV] #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-22 19:18:48.814
ESH3.CME [CBV] #6 | Reloading chart. | 2023-02-22 19:18:48.815
Socket (5) | Socket gracefully closed by remote side. | 2023-02-22 19:18:48.890
Socket (5) | Closed. | 2023-02-22 19:18:48.890
ESH3.CME [CBV] 30 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-22 19:18:49.208
ESH3.CME [CBV] 30 Min #2 | Reloading chart. | 2023-02-22 19:18:49.209
ESH3.CME [CBV] #6 | Reloading chart. | 2023-02-22 19:18:49.446
ESH3.CME [CBV] 30 Min #2 | Reloading chart. | 2023-02-22 19:18:50.405
Chart: ESH3.CME [CBV][M] 30 Min #2 | Study: Draw Peak and Valley | Draw Peak And Valley : in | 2023-02-22 20:27:36.933
Chart: ESH3.CME [CBV][M] 30 Min #2 | Study: Draw Peak and Valley | Draw Peak And Valley : out | 2023-02-22 20:27:38.936
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:16:14.913
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:16:15.212
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:16:32.698
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:16:33.197
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:16:39.712
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:16:40.211
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:17:00.217
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:17:00.744
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:17:02.219
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:17:13.245
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:17:13.695
Bankable Julio account data changed. Requesting updated account information. | 2023-02-22 21:17:21.693
Successfully processed Bankable Julio account data. | 2023-02-22 21:17:22.282
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:17:47.211
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:17:47.690
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:18:48.741
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:18:49.218
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:19:31.728
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:19:32.075
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:21:04.736
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:21:05.230
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:21:13.729
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:21:14.217
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:21:15.366
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:25:11.461
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:25:11.832
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:27:34.834
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:27:35.342
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:49:46.074
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:49:46.585
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:51:57.306
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:51:57.837
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:52:03.845
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:52:04.314
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:52:33.645
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:52:34.147
ESH3.CME [CBV][M] Rev. 4t #9 | Reloading chart. | 2023-02-22 21:53:02.347
ESH3.CME [CBV][M] Rev. 4t #9 | Performing continuous chart historical Daily data download for symbol ESH3.CME starting at last date in file. | 2023-02-22 21:53:02.351
Added historical Daily data request for ESH3.CME to the queue. | 2023-02-22 21:53:02.351
Triggering next historical data download in queue. | 2023-02-22 21:53:02.351
ESH3.CME [CBV][M] Rev. 4t #9 | Waiting for historical downloads to complete with the IDs: 42, | 2023-02-22 21:53:02.381
HD Request # 42 | Downloading Historical Daily chart data for ESH3.CME. Starting date: 2023-02-16. Service: rithmic.trading | 2023-02-22 21:53:02.386
HD Request # 42 | Requesting historical Daily data for ESH23 starting at 2023-02-15. SC External HD service. | 2023-02-22 21:53:02.809
HD Request # 42 | Receiving historical Daily data for ESH3.CME starting at 2023-02-16. | 2023-02-22 21:53:03.286
HD Request # 42 | Writing historical Daily data to the file ESH3.CME.dly. | 2023-02-22 21:53:03.287
HD Request # 42 | Bytes received: 239 | 2023-02-22 21:53:03.295
HD Request # 42 | Received 4 Daily data records from 2023-02-16 00:00:00 to 2023-02-21 00:00:00 (6.0 days) and wrote 3 records for ESH3.CME | 2023-02-22 21:53:03.295
HD Request # 42 | Completion time: 1s. | 2023-02-22 21:53:03.295
HD Request # 42 | Daily data download complete for ESH3.CME. Unique request ID: 42 | 2023-02-22 21:53:03.295
Removing historical data download ID 42. | 2023-02-22 21:53:03.295
Triggering next historical data download in queue. | 2023-02-22 21:53:03.295
No download requests in the queue to start downloads for. | 2023-02-22 21:53:03.295
ESH3.CME [CBV][M] Rev. 4t #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-02-22 21:53:03.356
ESH3.CME [CBV][M] Rev. 4t #9 | Reloading chart. | 2023-02-22 21:53:03.357
ESH3.CME [CBV][M] Daily #4 | Reloading chart. | 2023-02-22 21:53:03.800
ESH3.CME [CBV][M] Daily #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2023-02-22 21:53:03.800
ESH3.CME [CBV][M] Daily #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2023-02-22 21:53:03.800
ESH3.CME [CBV][M] Rev. 4t #9 | Reloading chart. | 2023-02-22 21:53:05.606
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:53:14.803
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:53:15.283
Bankable Julio account data changed. Requesting updated account information. | 2023-02-22 21:53:21.283
Successfully processed Bankable Julio account data. | 2023-02-22 21:53:22.218
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:53:29.660
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:53:30.182
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:53:51.455
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:53:51.959
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:54:37.020
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:54:37.419
Bankable Julio account data changed. Requesting updated account information. | 2023-02-22 21:56:21.081
Successfully processed Bankable Julio account data. | 2023-02-22 21:56:21.997
ESH3.CME [CBV][M] Rev. 4t #9 | Reloading chart. | 2023-02-22 21:56:37.355
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:56:42.833
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:56:45.838
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:56:46.316
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:57:55.833
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:57:56.341
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:58:03.828
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:58:04.347
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:58:04.965
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:58:10.859
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 21:58:17.562
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:58:17.878
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 21:58:21.908
Requested new login tokens. | 2023-02-22 22:04:05.078
Received 8 login tokens. | 2023-02-22 22:04:05.598
MESH3.CME[M] #4 | Reloading chart. | 2023-02-22 22:51:58.451
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-22 22:51:58.793
MESH3.CME[M] #4 | Reloading chart. | 2023-02-23 02:38:28.781
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-23 02:38:28.798
ESH3.CME #3 | Reloading chart. | 2023-02-23 02:38:38.116
ESH3.CME #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-23 02:38:38.118
Requesting market depth updates for: ESH3.CME if supported. | 2023-02-23 02:38:38.702
Denali Data Feed | Market Depth data has been rejected for symbol: ESH3.CME. Not authorized for market depth. | 2023-02-23 02:38:39.001
Unsubscribed from market depth data for ESH3.CME | 2023-02-23 02:38:48.813
HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (3) | Creating socket. Using TLS 1.2. | 2023-02-23 02:39:07.954
HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (3) | New receive buffer size: 32768 | 2023-02-23 02:39:07.954
HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (3) | Connecting to IP: 38.79.0.89. | 2023-02-23 02:39:07.954
HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (3) | Socket gracefully closed by remote side. | 2023-02-23 02:39:08.519
HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (3) | CloseSocket call. | 2023-02-23 02:39:08.520
HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-02-23 02:39:08.520
HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (3) | Closed. | 2023-02-23 02:39:08.520
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-23 02:45:12.883
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-23 02:45:33.606
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-23 02:45:41.533
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-23 02:45:49.962
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-23 02:45:51.106
MESH3.CME #3 | Reloading chart. | 2023-02-23 02:45:56.986
MESH3.CME #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-23 02:45:57.013
ESH3.CME[M] #3 | Reloading chart. | 2023-02-23 02:46:05.530
ESH3.CME[M] #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-23 02:46:05.618
Requesting market depth updates for: ESH3.CME if supported. | 2023-02-23 02:46:08.725
Denali Data Feed | Market Depth data has been rejected for symbol: ESH3.CME. Not authorized for market depth. | 2023-02-23 02:46:08.931
Unsubscribed from market depth data for ESH3.CME | 2023-02-23 02:47:23.738
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2023-02-09 09:01:17 | 2023-02-23 09:01:18.875
ESH3.CME [CBV][M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 2023-02-09 09:01:17 | 2023-02-23 09:01:18.914
HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (3) | Creating socket. Using TLS 1.2. | 2023-02-23 10:39:09.580
HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (3) | New receive buffer size: 32768 | 2023-02-23 10:39:09.580
HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (3) | Connecting to IP: 38.79.0.89. | 2023-02-23 10:39:09.580
HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (3) | Socket gracefully closed by remote side. | 2023-02-23 10:39:10.214
HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (3) | CloseSocket call. | 2023-02-23 10:39:10.216
HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-02-23 10:39:10.216
HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (3) | Closed. | 2023-02-23 10:39:10.216
Chart: ESH3.CME [CBV][M] 30 Min #2 | Study: Draw Peak and Valley | Draw Peak And Valley : in | 2023-02-23 15:12:29.608
Chart: ESH3.CME [CBV][M] 30 Min #2 | Study: Draw Peak and Valley | Draw Peak And Valley : out | 2023-02-23 15:12:31.532
Uploaded an image to the server. Request ID: 1 | 2023-02-23 15:58:41.856
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (3) | Creating socket. Using TLS 1.2. | 2023-02-23 15:58:41.856
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (3) | New receive buffer size: 32768 | 2023-02-23 15:58:41.856
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (3) | Connecting to IP: 95.216.233.104. | 2023-02-23 15:58:41.856
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (3) | CloseSocket call. | 2023-02-23 15:58:46.611
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (3) | Shutdown started. Waiting for graceful close. | 2023-02-23 15:58:46.611
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (3) | Socket gracefully closed by remote side. | 2023-02-23 15:58:46.677
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (3) | Closed. | 2023-02-23 15:58:46.677
Uploaded an image to the server. Request ID: 2 | 2023-02-23 15:59:16.703
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (3) | Creating socket. Using TLS 1.2. | 2023-02-23 15:59:16.703
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (3) | New receive buffer size: 32768 | 2023-02-23 15:59:16.703
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (3) | Connecting to IP: 95.216.233.104. | 2023-02-23 15:59:16.703
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (3) | Socket gracefully closed by remote side. | 2023-02-23 15:59:22.391
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (3) | CloseSocket call. | 2023-02-23 15:59:22.659
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-02-23 15:59:22.659
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (3) | Closed. | 2023-02-23 15:59:22.659
Bankable Julio account data changed. Requesting updated account information. | 2023-02-23 16:02:21.778
Successfully processed Bankable Julio account data. | 2023-02-23 16:02:22.485
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2023-02-09 16:36:08 | 2023-02-23 16:36:10.139
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2023-02-09 16:36:09 | 2023-02-23 16:36:11.723
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2023-02-09 16:36:11 | 2023-02-23 16:36:12.772
MESH3.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2023-02-09 16:36:12 | 2023-02-23 16:36:13.908
File >> Disconnect selected. | 2023-02-23 16:38:28.247
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-02-23 16:38:28.247
DTC Client socket (2) | CloseSocket call. | 2023-02-23 16:38:28.247
DTC Client socket (2) | Max send buffers used during socket life: 3 | 2023-02-23 16:38:28.247
DTC Client socket (2) | Max send buffer size during socket life: 802 | 2023-02-23 16:38:28.247
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-23 16:38:28.248
Rithmic Direct - DTC | Disconnected from the server. | 2023-02-23 16:38:28.248
DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-02-23 16:38:28.363
DTC Client socket (2) | Closed. | 2023-02-23 16:38:28.363
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-02-23 16:38:28.467
DTC Client socket (1) | CloseSocket call. | 2023-02-23 16:38:28.468
DTC Client socket (1) | Max send buffers used during socket life: 3 | 2023-02-23 16:38:28.468
DTC Client socket (1) | Max send buffer size during socket life: 1213 | 2023-02-23 16:38:28.468
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-02-23 16:38:28.468
Denali Data Feed | Waiting for socket receive thread to end | 2023-02-23 16:38:28.468
DTC Client socket (4) | CloseSocket call. | 2023-02-23 16:38:28.468
Denali Data Feed | Disconnected from the server. | 2023-02-23 16:38:28.468
Rithmic Direct - DTC | Disconnected. | 2023-02-23 16:38:28.468
DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2023-02-23 16:38:28.468
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-02-23 16:38:28.581
DTC Client socket (1) | Closed. | 2023-02-23 16:38:28.581
Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated | 2023-02-23 16:38:30.706
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 | 2023-02-23 16:38:30.711
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-02-23 16:38:30.969
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-02-23 16:38:30.969
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2023-02-23 16:38:30.969
Rithmic Direct - DTC | Network connection to server complete. | 2023-02-23 16:38:31.083
Rithmic Direct - DTC | Starting socket receive thread. | 2023-02-23 16:38:31.083
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-02-23 16:38:31.084
Rithmic Direct - DTC | Sending logon request message. | 2023-02-23 16:38:31.084
Rithmic Direct - DTC | Received logon response. | 2023-02-23 16:38:31.516
Rithmic Direct - DTC | Server Name: . | 2023-02-23 16:38:31.516
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2023-02-23 16:38:31.516
Rithmic Direct - DTC | Successfully connected. | 2023-02-23 16:38:31.516
Rithmic Direct - DTC | Trading is supported. | 2023-02-23 16:38:31.516
Rithmic Direct - DTC | Order cancel and replace is supported. | 2023-02-23 16:38:31.516
Rithmic Direct - DTC | OCO Orders supported. | 2023-02-23 16:38:31.516
Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2023-02-23 16:38:31.516
Rithmic Direct - DTC | Connected to server complete. | 2023-02-23 16:38:31.516
Triggering next historical data download in queue. | 2023-02-23 16:38:31.519
Updated verified funded futures trading account ending date to: 2023-03-25 15:38:31 | 2023-02-23 16:38:31.519
No download requests in the queue to start downloads for. | 2023-02-23 16:38:31.721
No download requests in the queue to start downloads for. | 2023-02-23 16:38:31.722
Mapping ESH3.CME to ESH23. Service code: cme | 2023-02-23 16:38:31.722
Using symbol data fast lookup vector | 2023-02-23 16:38:31.722
Denali Data Feed | Starting real-time market data updates for: ESH3.CME (ESH23). ID: 1 Service code: cme | 2023-02-23 16:38:31.723
Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 10048 | 2023-02-23 16:38:31.723
Denali Data Feed | Requesting security definition data for: ESH3.CME (ESH23). ID: 1 | 2023-02-23 16:38:31.723
Added historical Intraday data request for ESH3.CME to the queue. | 2023-02-23 16:38:31.723
Intraday data recording state for symbol ESH3.CME is set to download 'Pending'. | 2023-02-23 16:38:31.723
Triggering next historical data download in queue. | 2023-02-23 16:38:31.723
DTC Client socket (2) | Creating socket. | 2023-02-23 16:38:31.754
DTC Client socket (2) | New receive buffer size: 5242880 | 2023-02-23 16:38:31.754
DTC Client socket (2) | Connecting to IP: 142.215.17.188. | 2023-02-23 16:38:31.754
Delaying start of download for ESH3.CME. | 2023-02-23 16:38:32.069
Denali Data Feed | Network connection to server complete. | 2023-02-23 16:38:32.069
Denali Data Feed | Starting socket receive thread. | 2023-02-23 16:38:32.069
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-23 16:38:32.070
Updated verified funded futures trading account ending date to: 2023-03-25 15:38:32 | 2023-02-23 16:38:32.070
Rithmic Direct - DTC | Starting real-time market data updates for: ESZ22. ID: 2 | 2023-02-23 16:38:32.210
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50529 | 2023-02-23 16:38:32.210
DTC Client socket (3) | Creating socket. Using TLS 1.2. | 2023-02-23 16:38:32.211
DTC Client socket (3) | New receive buffer size: 5242880 | 2023-02-23 16:38:32.211
DTC Client socket (3) | Connecting to IP: 216.57.156.163. | 2023-02-23 16:38:32.211
Rithmic Direct - DTC | Requesting security definition data for: ESZ22. ID: 2 | 2023-02-23 16:38:32.213
Requesting market depth updates for: ESZ22 if supported. | 2023-02-23 16:38:32.213
Separate subscription for market depth updates not supported. ESZ22 | 2023-02-23 16:38:32.213
Added historical Intraday data request for ESZ22 to the queue. | 2023-02-23 16:38:32.213
Intraday data recording state for symbol ESZ22 is set to download 'Pending'. | 2023-02-23 16:38:32.213
Triggering next historical data download in queue. | 2023-02-23 16:38:32.213
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-02-23 16:38:32.214
Denali Data Feed | Sending logon request message. | 2023-02-23 16:38:32.214
Mapping MESH3.CME to MESH23. Service code: cme | 2023-02-23 16:38:32.214
Denali Data Feed | Starting real-time market data updates for: MESH3.CME (MESH23). ID: 3 Service code: cme | 2023-02-23 16:38:32.214
Denali Data Feed | Requesting security definition data for: MESH3.CME (MESH23). ID: 3 | 2023-02-23 16:38:32.214
Added historical Intraday data request for MESH3.CME to the queue. | 2023-02-23 16:38:32.214
Intraday data recording state for symbol MESH3.CME is set to download 'Pending'. | 2023-02-23 16:38:32.214
Triggering next historical data download in queue. | 2023-02-23 16:38:32.214
Rithmic Direct - DTC | Starting real-time market data updates for: ZBU22. ID: 4 | 2023-02-23 16:38:32.224
Rithmic Direct - DTC | Requesting security definition data for: ZBU22. ID: 4 | 2023-02-23 16:38:32.225
Rithmic Direct - DTC | Starting real-time market data updates for: ZNH23. ID: 5 | 2023-02-23 16:38:32.226
Rithmic Direct - DTC | Requesting security definition data for: ZNH23. ID: 5 | 2023-02-23 16:38:32.226
Rithmic Direct - DTC | Starting real-time market data updates for: ZFU22. ID: 6 | 2023-02-23 16:38:32.227
Rithmic Direct - DTC | Requesting security definition data for: ZFU22. ID: 6 | 2023-02-23 16:38:32.227
Rithmic Direct - DTC | Starting real-time market data updates for: UDU22. ID: 7 | 2023-02-23 16:38:32.255
Rithmic Direct - DTC | Requesting security definition data for: UDU22. ID: 7 | 2023-02-23 16:38:32.255
Rithmic Direct - DTC | Network connection to server complete. | 2023-02-23 16:38:32.405
Rithmic Direct - DTC | Starting socket receive thread. | 2023-02-23 16:38:32.405
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-02-23 16:38:32.407
Rithmic Direct - DTC | Sending logon request message. | 2023-02-23 16:38:32.407
Rithmic Direct - DTC | Received logon response. | 2023-02-23 16:38:32.751
Rithmic Direct - DTC | Server Name: . | 2023-02-23 16:38:32.751
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2023-02-23 16:38:32.751
Rithmic Direct - DTC | Successfully connected. | 2023-02-23 16:38:32.751
Rithmic Direct - DTC | Trading is not supported. | 2023-02-23 16:38:32.751
Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2023-02-23 16:38:32.751
Rithmic Direct - DTC | Restarting real-time data updates for symbol: ESZ22. Market Depth data restarted. | 2023-02-23 16:38:32.751
Rithmic Direct - DTC | Restarting real-time data updates for symbol: UDU22 | 2023-02-23 16:38:32.751
Rithmic Direct - DTC | Restarting real-time data updates for symbol: ZBU22 | 2023-02-23 16:38:32.751
Rithmic Direct - DTC | Restarting real-time data updates for symbol: ZFU22 | 2023-02-23 16:38:32.751
Rithmic Direct - DTC | Restarting real-time data updates for symbol: ZNH23 | 2023-02-23 16:38:32.751
Symbol Error - ESZ22 is unknown, unavailable, or improperly formatted. Exchange not specified | 2023-02-23 16:38:32.866
Rithmic Direct - DTC | Market Depth data has been rejected for symbol: ESZ22. Exchange not specified | 2023-02-23 16:38:32.867
Symbol Error - UDU22 is unknown, unavailable, or improperly formatted. Exchange not specified | 2023-02-23 16:38:32.867
Symbol Error - ZBU22 is unknown, unavailable, or improperly formatted. Exchange not specified | 2023-02-23 16:38:32.867
Symbol Error - ZFU22 is unknown, unavailable, or improperly formatted. Exchange not specified | 2023-02-23 16:38:32.867
Symbol Error - ZNH23 is unknown, unavailable, or improperly formatted. Exchange not specified | 2023-02-23 16:38:32.867
Denali Data Feed | Received logon response. | 2023-02-23 16:38:33.085
Denali Data Feed | Server Name: SC Realtime Server. | 2023-02-23 16:38:33.085
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-02-23 16:38:33.085
Denali Data Feed | Successfully connected. | 2023-02-23 16:38:33.085
Denali Data Feed | Trading is not supported. | 2023-02-23 16:38:33.085
Denali Data Feed | Restarting real-time data updates for symbol: ESH3.CME -> ESH23 | 2023-02-23 16:38:33.085
Denali Data Feed | Restarting real-time data updates for symbol: MESH3.CME -> MESH23 | 2023-02-23 16:38:33.085
Denali Data Feed | Received security definition for symbol ESH3.CME | 2023-02-23 16:38:33.304
Denali Data Feed | Received security definition for symbol MESH3.CME | 2023-02-23 16:38:33.304
Requesting market depth updates for: MESH3.CME if supported. | 2023-02-23 16:38:36.929
Denali Data Feed | Clearing market depth for MESH3.CME | 2023-02-23 16:38:37.395
HD Request # 43 | Downloading Intraday chart data for ESH3.CME to the file ESH3.CME.scid. Service: cme | 2023-02-23 16:38:39.286
HD Request # 43 | Download start date-time: 2023-02-23 16:38:27.000000. File last date-time: 2023-02-23 16:38:27.100002 | 2023-02-23 16:38:39.287
HD Request # 43 | Using server: ds26.sierracharts.com port 10149 | 2023-02-23 16:38:39.289
Socket (5) | Creating socket. | 2023-02-23 16:38:39.289
Socket (5) | New receive buffer size: 5242880 | 2023-02-23 16:38:39.289
Socket (5) | Connecting to IP: 142.215.17.188. | 2023-02-23 16:38:39.289
HD Request # 43 | Setting DTC encoding to Binary VLS | 2023-02-23 16:38:39.522
HD Request # 43 | Sending historical data logon request message. | 2023-02-23 16:38:39.522
HD Request # 43 | Requesting Intraday data. Start date-time: 2023-02-23 16:38:27. Record interval: 0. Symbol: ESH23 | 2023-02-23 16:38:40.163
HD Request # 43 | Decompressing data. | 2023-02-23 16:38:40.276
HD Request # 43 | Receiving Intraday data for ESH3.CME starting at 2023-02-23 16:38:27.002000 | 2023-02-23 16:38:40.277
Socket (5) | CloseSocket call. | 2023-02-23 16:38:40.278
Socket (5) | Shutdown started. Waiting for graceful close. | 2023-02-23 16:38:40.278
Historical data download thread signaled to stop. | 2023-02-23 16:38:40.305
HD Request # 43 | Timestamp of first Intraday data file record written: 2023-02-23 16:38:27.435000. | 2023-02-23 16:38:40.306
HD Request # 43 | Received 258 Intraday data records from 2023-02-23 16:38:27.002000 to 2023-02-23 16:38:37.612000 (10.6 seconds) and wrote 254 records for ESH3.CME | 2023-02-23 16:38:40.306
HD Request # 43 | Add time&sales data | Remembered last file record date-time: 2023-02-23 15:38:37.612000 | 2023-02-23 16:38:40.307
Added 10 Time and Sales records to Intraday data file for ESH3.CME after download. | 2023-02-23 16:38:40.307
HD Request # 43 | Completion time: 1s. | 2023-02-23 16:38:40.307
HD Request # 43 | Intraday data download complete for ESH3.CME. Unique request ID: 43 | 2023-02-23 16:38:40.307
Removing historical data download ID 43. | 2023-02-23 16:38:40.307
Real-time Intraday chart data file updates started for ESH3.CME | 2023-02-23 16:38:40.307
Intraday chart data file opened for ESH3.CME | 2023-02-23 16:38:40.307
HD Request # 43 | Enabling Intraday chart updating for symbol. | 2023-02-23 16:38:40.307
Triggering next historical data download in queue. | 2023-02-23 16:38:40.307
HD Request # 44 | Downloading Intraday chart data for ESZ22 to the file ESZ22.scid. Service: rithmic_v2.trading | 2023-02-23 16:38:40.307
HD Request # 44 | Download start date-time: 2022-08-21 17:38:40.000000. File last date-time: 00:00:00.000000 | 2023-02-23 16:38:40.308
HD Request # 44 | Using server: rsc.rithmic.com port 50530. Use encryption. | 2023-02-23 16:38:40.313
Socket (6) | Creating socket. Using TLS 1.2. | 2023-02-23 16:38:40.313
Socket (6) | New receive buffer size: 5242880 | 2023-02-23 16:38:40.313
Socket (6) | Connecting to IP: 216.57.156.163. | 2023-02-23 16:38:40.313
Socket (5) | Socket gracefully closed by remote side. | 2023-02-23 16:38:40.390
Socket (5) | Closed. | 2023-02-23 16:38:40.390
HD Request # 44 | Sending historical data logon request message. | 2023-02-23 16:38:40.428
HD Request # 44 | Requesting Intraday data. Start date-time: 2022-08-21 17:38:40. Record interval: 0. Symbol: ESZ22 | 2023-02-23 16:38:40.771
Socket (6) | CloseSocket call. | 2023-02-23 16:38:40.885
Socket (6) | Shutdown started. Waiting for graceful close. | 2023-02-23 16:38:40.886
Socket (6) | Socket gracefully closed by remote side. | 2023-02-23 16:38:40.999
Socket (6) | Closed. | 2023-02-23 16:38:40.999
HD Request # 44 | Error downloading historical Intraday data for ESZ22. Exchange not specified | 2023-02-23 16:38:41.050
Historical data download thread signaled to stop. | 2023-02-23 16:38:41.050
HD Request # 44 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for ESZ22 | 2023-02-23 16:38:41.050
HD Request # 44 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2023-02-23 16:38:41.050
HD Request # 44 | Completion time: 1s. | 2023-02-23 16:38:41.054
HD Request # 44 | Intraday data download complete for ESZ22. Unique request ID: 44 | 2023-02-23 16:38:41.054
Removing historical data download ID 44. | 2023-02-23 16:38:41.054
Real-time Intraday chart data file updates started for ESZ22 | 2023-02-23 16:38:41.054
Intraday chart data file opened for ESZ22 | 2023-02-23 16:38:41.054
HD Request # 44 | Enabling Intraday chart updating for symbol. | 2023-02-23 16:38:41.054
Triggering next historical data download in queue. | 2023-02-23 16:38:41.054
HD Request # 45 | Downloading Intraday chart data for MESH3.CME to the file MESH3.CME.scid. Service: cme | 2023-02-23 16:38:41.054
HD Request # 45 | Download start date-time: 2023-02-23 16:38:27.000000. File last date-time: 2023-02-23 16:38:27.100000 | 2023-02-23 16:38:41.054
HD Request # 45 | Using server: ds28.sierracharts.com port 10149 | 2023-02-23 16:38:41.056
Socket (5) | Creating socket. | 2023-02-23 16:38:41.078
Socket (5) | New receive buffer size: 5242880 | 2023-02-23 16:38:41.078
Socket (5) | Connecting to IP: 142.215.18.147. | 2023-02-23 16:38:41.078
HD Request # 45 | Setting DTC encoding to Binary VLS | 2023-02-23 16:38:41.322
HD Request # 45 | Sending historical data logon request message. | 2023-02-23 16:38:41.322
HD Request # 45 | Requesting Intraday data. Start date-time: 2023-02-23 16:38:27. Record interval: 0. Symbol: MESH23 | 2023-02-23 16:38:41.949
HD Request # 45 | Decompressing data. | 2023-02-23 16:38:42.077
HD Request # 45 | Receiving Intraday data for MESH3.CME starting at 2023-02-23 16:38:27.085000 | 2023-02-23 16:38:42.078
Socket (5) | CloseSocket call. | 2023-02-23 16:38:42.078
Socket (5) | Shutdown started. Waiting for graceful close. | 2023-02-23 16:38:42.079
Socket (5) | Socket gracefully closed by remote side. | 2023-02-23 16:38:42.190
Socket (5) | Closed. | 2023-02-23 16:38:42.190
Historical data download thread signaled to stop. | 2023-02-23 16:38:42.279
HD Request # 45 | Timestamp of first Intraday data file record written: 2023-02-23 16:38:28.077000. | 2023-02-23 16:38:42.279
HD Request # 45 | Received 90 Intraday data records from 2023-02-23 16:38:27.085000 to 2023-02-23 16:38:38.759000 (11.7 seconds) and wrote 87 records for MESH3.CME | 2023-02-23 16:38:42.279
HD Request # 45 | Add time&sales data | Remembered last file record date-time: 2023-02-23 15:38:38.759000 | 2023-02-23 16:38:42.280
Added 19 Time and Sales records to Intraday data file for MESH3.CME after download. | 2023-02-23 16:38:42.280
HD Request # 45 | Completion time: 1s. | 2023-02-23 16:38:42.281
HD Request # 45 | Intraday data download complete for MESH3.CME. Unique request ID: 45 | 2023-02-23 16:38:42.281
Removing historical data download ID 45. | 2023-02-23 16:38:42.281
Real-time Intraday chart data file updates started for MESH3.CME | 2023-02-23 16:38:42.281
Intraday chart data file opened for MESH3.CME | 2023-02-23 16:38:42.281
HD Request # 45 | Enabling Intraday chart updating for symbol. | 2023-02-23 16:38:42.281
Triggering next historical data download in queue. | 2023-02-23 16:38:42.281
No download requests in the queue to start downloads for. | 2023-02-23 16:38:42.281
Opened cached Intraday file: C:\SierraChart\Data\ESH3.CME.scid. Thread ID: 70332 | 2023-02-23 16:38:44.173
Opened cached Intraday file: C:\SierraChart\Data\MESH3.CME.scid. Thread ID: 70332 | 2023-02-23 16:38:44.174
HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (5) | Creating socket. Using TLS 1.2. | 2023-02-23 16:38:54.417
HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (5) | New receive buffer size: 32768 | 2023-02-23 16:38:54.417
HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (5) | Connecting to IP: 38.79.0.89. | 2023-02-23 16:38:54.417
HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (5) | New receive buffer size: 65536 | 2023-02-23 16:38:55.054
HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (5) | Socket gracefully closed by remote side. | 2023-02-23 16:38:55.206
HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (5) | CloseSocket call. | 2023-02-23 16:38:55.207
HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-02-23 16:38:55.207
HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (5) | Closed. | 2023-02-23 16:38:55.207
Source file does not exist when saving backup of C:\SierraChart\SymbolSettings\CustomSymbolSettings.rithmic_v2.trading.xml. No backup made. | 2023-02-23 16:39:51.489
DTC Client socket (4) | Timed out waiting for shutdown. Performing an immediate socket close. | 2023-02-23 16:40:35.658
DTC Client socket (4) | Closed. | 2023-02-23 16:40:35.658
DTC Client socket (4) | Deleting network socket now after delay. | 2023-02-23 16:41:05.660
MESH3.CME #3 | Reloading chart. | 2023-02-23 16:41:20.839
MESH3.CME #3 | StartDateTimeForLoadingOrderFills: 2023-02-09 16:41:19 | 2023-02-23 16:41:21.094
ESH3.CME[M] #3 | Reloading chart. | 2023-02-23 16:41:53.354
ESH3.CME[M] #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-23 16:41:53.355
ESH3.CME[M] #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-23 16:41:54.122
ESH3.CME[M] #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-23 16:41:55.626
Requesting market depth updates for: ESH3.CME if supported. | 2023-02-23 16:41:56.997
Denali Data Feed | Clearing market depth for ESH3.CME | 2023-02-23 16:41:57.459
Unsubscribed from market depth data for ESH3.CME | 2023-02-23 16:44:52.186
MESH3.CME #3 | Reloading chart. | 2023-02-23 16:46:10.907
MESH3.CME #3 | StartDateTimeForLoadingOrderFills: 2023-02-09 16:46:10 | 2023-02-23 16:46:11.186
Enabling compression for file: C:\SierraChart\Data\MYMH3.CBOT.scid. This may take a while. | 2023-02-23 16:46:37.315
File compression enabled. C:\SierraChart\Data\MYMH3.CBOT.scid. CompressionState=0 | 2023-02-23 16:46:37.315
MYMH3.CBOT[M] #3 | Reloading chart. | 2023-02-23 16:46:37.317
MYMH3.CBOT[M] #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-23 16:46:37.328
Rithmic Direct - DTC | Starting real-time market data updates for: MYMH3.CBOT. ID: 8 Service code: rithmic.trading | 2023-02-23 16:46:37.707
Rithmic Direct - DTC | Requesting security definition data for: MYMH3.CBOT. ID: 8 | 2023-02-23 16:46:37.707
Added historical Intraday data request for MYMH3.CBOT to the queue. | 2023-02-23 16:46:37.707
Intraday data recording state for symbol MYMH3.CBOT is set to download 'Pending'. | 2023-02-23 16:46:37.707
Triggering next historical data download in queue. | 2023-02-23 16:46:37.707
Delaying start of download for MYMH3.CBOT. | 2023-02-23 16:46:37.713
MYMH3.CBOT #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-23 16:46:38.334
Requesting market depth updates for: MYMH3.CBOT if supported. | 2023-02-23 16:46:42.221
HD Request # 46 | Downloading Intraday chart data for MYMH3.CBOT to the file MYMH3.CBOT.scid. Service: rithmic.trading | 2023-02-23 16:46:42.274
HD Request # 46 | Download start date-time: 2022-08-21 17:46:42.000000. File last date-time: 00:00:00.000000 | 2023-02-23 16:46:42.275
HD Request # 46 | Using server: rsc.rithmic.com port 50530. Use encryption. | 2023-02-23 16:46:42.275
Socket (4) | Creating socket. Using TLS 1.2. | 2023-02-23 16:46:42.275
Socket (4) | New receive buffer size: 5242880 | 2023-02-23 16:46:42.275
Socket (4) | Connecting to IP: 216.57.156.163. | 2023-02-23 16:46:42.275
HD Request # 46 | Sending historical data logon request message. | 2023-02-23 16:46:42.390
Rithmic Direct - DTC | Market Depth data has been rejected for symbol: MYMH3.CBOT. permission denied | 2023-02-23 16:46:42.448
HD Request # 46 | Requesting Intraday data. Start date-time: 2022-08-21 17:46:42. Record interval: 0. Symbol: MYMH3.CBOT | 2023-02-23 16:46:42.735
HD Request # 46 | Receiving Intraday data for MYMH3.CBOT starting at 2022-08-22 15:32:22.923000 | 2023-02-23 16:46:42.854
HD Request # 46 | Timestamp of first Intraday data file record written: 2022-08-22 15:32:22.923000. | 2023-02-23 16:46:47.159
Source file does not exist when saving backup of C:\SierraChart\Data\6TDJ.twconfig. No backup made. | 2023-02-23 16:48:18.759
Source file does not exist when saving backup of C:\SierraChart\Data\6TDJ.twconfig. No backup made. | 2023-02-23 16:48:18.764
Socket (4) | CloseSocket call. | 2023-02-23 16:48:25.812
Socket (4) | Shutdown started. Waiting for graceful close. | 2023-02-23 16:48:25.812
Socket (4) | Socket gracefully closed by remote side. | 2023-02-23 16:48:25.926
Socket (4) | Closed. | 2023-02-23 16:48:25.926
Historical data download thread signaled to stop. | 2023-02-23 16:48:26.066
HD Request # 46 | Received 5921174 Intraday data records from 2022-08-22 15:32:22.923000 to 2023-02-23 16:48:20.238000 (185.1 days) and wrote 5921123 records for MYMH3.CBOT | 2023-02-23 16:48:26.066
HD Request # 46 | Add time&sales data | Remembered last file record date-time: 2023-02-23 15:48:20.238000 | 2023-02-23 16:48:26.067
Added 28 Time and Sales records to Intraday data file for MYMH3.CBOT after download. | 2023-02-23 16:48:26.067
HD Request # 46 | Completion time: 1m 44s. | 2023-02-23 16:48:26.068
HD Request # 46 | Intraday data download complete for MYMH3.CBOT. Unique request ID: 46 | 2023-02-23 16:48:26.068
Removing historical data download ID 46. | 2023-02-23 16:48:26.068
Real-time Intraday chart data file updates started for MYMH3.CBOT | 2023-02-23 16:48:26.068
Intraday chart data file opened for MYMH3.CBOT | 2023-02-23 16:48:26.068
HD Request # 46 | Enabling Intraday chart updating for symbol. | 2023-02-23 16:48:26.068
Triggering next historical data download in queue. | 2023-02-23 16:48:26.068
No download requests in the queue to start downloads for. | 2023-02-23 16:48:26.068
Opened cached Intraday file: C:\SierraChart\Data\MYMH3.CBOT.scid. Thread ID: 70332 | 2023-02-23 16:48:29.296
MYMH3.CBOT #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-02-23 16:51:02.411
File >> Disconnect selected. | 2023-02-23 16:51:34.742
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-02-23 16:51:34.742
DTC Client socket (3) | CloseSocket call. | 2023-02-23 16:51:34.748
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2023-02-23 16:51:34.748
Rithmic Direct - DTC | Disconnected from the server. | 2023-02-23 16:51:34.748
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-02-23 16:51:34.958
DTC Client socket (1) | CloseSocket call. | 2023-02-23 16:51:34.958
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-02-23 16:51:34.958
Denali Data Feed | Waiting for socket receive thread to end | 2023-02-23 16:51:34.959
DTC Client socket (2) | CloseSocket call. | 2023-02-23 16:51:34.959
Denali Data Feed | Disconnected from the server. | 2023-02-23 16:51:34.959
Rithmic Direct - DTC | Disconnected. | 2023-02-23 16:51:34.959
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-23 16:51:34.959
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-02-23 16:51:35.071
DTC Client socket (1) | Closed. | 2023-02-23 16:51:35.071
Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated | 2023-02-23 16:51:36.860
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 | 2023-02-23 16:51:36.865
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-02-23 16:51:36.865
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-02-23 16:51:36.866
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2023-02-23 16:51:36.866
Rithmic Direct - DTC | Network connection to server complete. | 2023-02-23 16:51:36.982
Rithmic Direct - DTC | Starting socket receive thread. | 2023-02-23 16:51:36.982
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-02-23 16:51:36.983
Rithmic Direct - DTC | Sending logon request message. | 2023-02-23 16:51:36.983
Rithmic Direct - DTC | Received logon response. | 2023-02-23 16:51:37.332
Rithmic Direct - DTC | Server Name: . | 2023-02-23 16:51:37.332
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2023-02-23 16:51:37.332
Rithmic Direct - DTC | Successfully connected. | 2023-02-23 16:51:37.332
Rithmic Direct - DTC | Trading is supported. | 2023-02-23 16:51:37.332
Rithmic Direct - DTC | Order cancel and replace is supported. | 2023-02-23 16:51:37.332
Rithmic Direct - DTC | OCO Orders supported. | 2023-02-23 16:51:37.332
Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2023-02-23 16:51:37.332
Rithmic Direct - DTC | Connected to server complete. | 2023-02-23 16:51:37.332
Triggering next historical data download in queue. | 2023-02-23 16:51:37.333
Updated verified funded futures trading account ending date to: 2023-03-25 15:51:37 | 2023-02-23 16:51:37.333
No download requests in the queue to start downloads for. | 2023-02-23 16:51:37.540
Using symbol data fast lookup vector | 2023-02-23 16:51:37.543
Rithmic Direct - DTC | Starting real-time market data updates for: MYMH3.CBOT. ID: 1 Service code: rithmic.trading | 2023-02-23 16:51:37.543
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50529 | 2023-02-23 16:51:37.543
DTC Client socket (4) | Creating socket. Using TLS 1.2. | 2023-02-23 16:51:37.543
DTC Client socket (4) | New receive buffer size: 5242880 | 2023-02-23 16:51:37.544
DTC Client socket (4) | Connecting to IP: 216.57.156.163. | 2023-02-23 16:51:37.544
Rithmic Direct - DTC | Requesting security definition data for: MYMH3.CBOT. ID: 1 | 2023-02-23 16:51:37.546
Added historical Intraday data request for MYMH3.CBOT to the queue. | 2023-02-23 16:51:37.546
Intraday data recording state for symbol MYMH3.CBOT is set to download 'Pending'. | 2023-02-23 16:51:37.546
Triggering next historical data download in queue. | 2023-02-23 16:51:37.546
Delaying start of download for MYMH3.CBOT. | 2023-02-23 16:51:37.553
Mapping MESH3.CME to MESH23. Service code: cme | 2023-02-23 16:51:37.554
Denali Data Feed | Starting real-time market data updates for: MESH3.CME (MESH23). ID: 2 Service code: cme | 2023-02-23 16:51:37.554
Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443 | 2023-02-23 16:51:37.554
Denali Data Feed | Requesting security definition data for: MESH3.CME (MESH23). ID: 2 | 2023-02-23 16:51:37.554
Added historical Intraday data request for MESH3.CME to the queue. | 2023-02-23 16:51:37.554
Intraday data recording state for symbol MESH3.CME is set to download 'Pending'. | 2023-02-23 16:51:37.554
Triggering next historical data download in queue. | 2023-02-23 16:51:37.554
DTC Client socket (5) | Creating socket. | 2023-02-23 16:51:37.554
DTC Client socket (5) | New receive buffer size: 5242880 | 2023-02-23 16:51:37.554
DTC Client socket (5) | Connecting to IP: 142.215.18.147. | 2023-02-23 16:51:37.554
Rithmic Direct - DTC | Starting real-time market data updates for: ESZ22. ID: 3 | 2023-02-23 16:51:37.566
Rithmic Direct - DTC | Requesting security definition data for: ESZ22. ID: 3 | 2023-02-23 16:51:37.566
Requesting market depth updates for: ESZ22 if supported. | 2023-02-23 16:51:37.566
Separate subscription for market depth updates not supported. ESZ22 | 2023-02-23 16:51:37.566
Added historical Intraday data request for ESZ22 to the queue. | 2023-02-23 16:51:37.567
Intraday data recording state for symbol ESZ22 is set to download 'Pending'. | 2023-02-23 16:51:37.567
Triggering next historical data download in queue. | 2023-02-23 16:51:37.567
Mapping ESH3.CME to ESH23. Service code: cme | 2023-02-23 16:51:37.567
Denali Data Feed | Starting real-time market data updates for: ESH3.CME (ESH23). ID: 4 Service code: cme | 2023-02-23 16:51:37.567
Denali Data Feed | Requesting security definition data for: ESH3.CME (ESH23). ID: 4 | 2023-02-23 16:51:37.567
Added historical Intraday data request for ESH3.CME to the queue. | 2023-02-23 16:51:37.567
Intraday data recording state for symbol ESH3.CME is set to download 'Pending'. | 2023-02-23 16:51:37.567
Rithmic Direct - DTC | Network connection to server complete. | 2023-02-23 16:51:37.908
Rithmic Direct - DTC | Starting socket receive thread. | 2023-02-23 16:51:37.908
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-02-23 16:51:37.909
Rithmic Direct - DTC | Sending logon request message. | 2023-02-23 16:51:37.909
Denali Data Feed | Network connection to server complete. | 2023-02-23 16:51:37.909
Denali Data Feed | Starting socket receive thread. | 2023-02-23 16:51:37.909
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-23 16:51:37.910
Updated verified funded futures trading account ending date to: 2023-03-25 15:51:37 | 2023-02-23 16:51:37.910
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-02-23 16:51:38.056
Denali Data Feed | Sending logon request message. | 2023-02-23 16:51:38.056
Rithmic Direct - DTC | Starting real-time market data updates for: UDU22. ID: 5 | 2023-02-23 16:51:38.075
Rithmic Direct - DTC | Requesting security definition data for: UDU22. ID: 5 | 2023-02-23 16:51:38.075
Rithmic Direct - DTC | Starting real-time market data updates for: ZNH23. ID: 6 | 2023-02-23 16:51:38.216
Rithmic Direct - DTC | Requesting security definition data for: ZNH23. ID: 6 | 2023-02-23 16:51:38.216
Rithmic Direct - DTC | Starting real-time market data updates for: ZFU22. ID: 7 | 2023-02-23 16:51:38.217
Rithmic Direct - DTC | Requesting security definition data for: ZFU22. ID: 7 | 2023-02-23 16:51:38.217
Rithmic Direct - DTC | Starting real-time market data updates for: ZBU22. ID: 8 | 2023-02-23 16:51:38.226
Rithmic Direct - DTC | Requesting security definition data for: ZBU22. ID: 8 | 2023-02-23 16:51:38.226
Rithmic Direct - DTC | Received logon response. | 2023-02-23 16:51:38.259
Rithmic Direct - DTC | Server Name: . | 2023-02-23 16:51:38.259
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2023-02-23 16:51:38.259
Rithmic Direct - DTC | Successfully connected. | 2023-02-23 16:51:38.259
Rithmic Direct - DTC | Trading is not supported. | 2023-02-23 16:51:38.259
Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2023-02-23 16:51:38.259
Rithmic Direct - DTC | Restarting real-time data updates for symbol: ESZ22. Market Depth data restarted. | 2023-02-23 16:51:38.259
Rithmic Direct - DTC | Restarting real-time data updates for symbol: MYMH3.CBOT | 2023-02-23 16:51:38.259
Rithmic Direct - DTC | Restarting real-time data updates for symbol: UDU22 | 2023-02-23 16:51:38.259
Rithmic Direct - DTC | Restarting real-time data updates for symbol: ZBU22 | 2023-02-23 16:51:38.259
Rithmic Direct - DTC | Restarting real-time data updates for symbol: ZFU22 | 2023-02-23 16:51:38.259
Rithmic Direct - DTC | Restarting real-time data updates for symbol: ZNH23 | 2023-02-23 16:51:38.259
Symbol Error - ESZ22 is unknown, unavailable, or improperly formatted. Exchange not specified | 2023-02-23 16:51:38.375
Rithmic Direct - DTC | Market Depth data has been rejected for symbol: ESZ22. Exchange not specified | 2023-02-23 16:51:38.376
Symbol Error - UDU22 is unknown, unavailable, or improperly formatted. Exchange not specified | 2023-02-23 16:51:38.376
Symbol Error - ZBU22 is unknown, unavailable, or improperly formatted. Exchange not specified | 2023-02-23 16:51:38.376
Symbol Error - ZFU22 is unknown, unavailable, or improperly formatted. Exchange not specified | 2023-02-23 16:51:38.376
Symbol Error - ZNH23 is unknown, unavailable, or improperly formatted. Exchange not specified | 2023-02-23 16:51:38.376
Rithmic Direct - DTC | Received security definition for symbol MYMH3.CBOT | 2023-02-23 16:51:38.380
Denali Data Feed | Received logon response. | 2023-02-23 16:51:39.102
Denali Data Feed | Server Name: SC Realtime Server. | 2023-02-23 16:51:39.102
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-02-23 16:51:39.102
Denali Data Feed | Successfully connected. | 2023-02-23 16:51:39.102
Denali Data Feed | Trading is not supported. | 2023-02-23 16:51:39.102
Denali Data Feed | Restarting real-time data updates for symbol: ESH3.CME -> ESH23 | 2023-02-23 16:51:39.102
Denali Data Feed | Restarting real-time data updates for symbol: MESH3.CME -> MESH23 | 2023-02-23 16:51:39.102
Denali Data Feed | Received security definition for symbol ESH3.CME | 2023-02-23 16:51:39.314
Denali Data Feed | Received security definition for symbol MESH3.CME | 2023-02-23 16:51:39.314
Requesting market depth updates for: MESH3.CME if supported. | 2023-02-23 16:51:42.729
Requesting market depth updates for: MYMH3.CBOT if supported. | 2023-02-23 16:51:42.729
Rithmic Direct - DTC | Market Depth data has been rejected for symbol: MYMH3.CBOT. permission denied | 2023-02-23 16:51:43.221
Denali Data Feed | Clearing market depth for MESH3.CME | 2023-02-23 16:51:43.221
HD Request # 47 | Downloading Intraday chart data for MYMH3.CBOT to the file MYMH3.CBOT.scid. Service: rithmic.trading | 2023-02-23 16:51:43.296
HD Request # 47 | Download start date-time: 2023-02-23 16:51:33.000000. File last date-time: 2023-02-23 16:51:33.000002 | 2023-02-23 16:51:43.296
HD Request # 47 | Using server: rsc.rithmic.com port 50530. Use encryption. | 2023-02-23 16:51:43.296
Socket (6) | Creating socket. Using TLS 1.2. | 2023-02-23 16:51:43.297
Socket (6) | New receive buffer size: 5242880 | 2023-02-23 16:51:43.297
Socket (6) | Connecting to IP: 216.57.156.163. | 2023-02-23 16:51:43.297
HD Request # 47 | Sending historical data logon request message. | 2023-02-23 16:51:43.412
HD Request # 47 | Requesting Intraday data. Start date-time: 2023-02-23 16:51:33. Record interval: 0. Symbol: MYMH3.CBOT | 2023-02-23 16:51:43.756
HD Request # 47 | Receiving Intraday data for MYMH3.CBOT starting at 2023-02-23 16:51:33.581000 | 2023-02-23 16:51:43.877
Socket (6) | CloseSocket call. | 2023-02-23 16:51:43.988
Socket (6) | Shutdown started. Waiting for graceful close. | 2023-02-23 16:51:43.988
Historical data download thread signaled to stop. | 2023-02-23 16:51:44.031
HD Request # 47 | Timestamp of first Intraday data file record written: 2023-02-23 16:51:33.581000. | 2023-02-23 16:51:44.031
HD Request # 47 | Received 25 Intraday data records from 2023-02-23 16:51:33.581000 to 2023-02-23 16:51:42.798000 (9.2 seconds) and wrote 25 records for MYMH3.CBOT | 2023-02-23 16:51:44.032
HD Request # 47 | Add time&sales data | Remembered last file record date-time: 2023-02-23 15:51:42.798000 | 2023-02-23 16:51:44.032
HD Request # 47 | Completion time: 1s. | 2023-02-23 16:51:44.032
HD Request # 47 | Intraday data download complete for MYMH3.CBOT. Unique request ID: 47 | 2023-02-23 16:51:44.032
Removing historical data download ID 47. | 2023-02-23 16:51:44.032
Real-time Intraday chart data file updates started for MYMH3.CBOT | 2023-02-23 16:51:44.032
Intraday chart data file opened for MYMH3.CBOT | 2023-02-23 16:51:44.032
HD Request # 47 | Enabling Intraday chart updating for symbol. | 2023-02-23 16:51:44.032
Triggering next historical data download in queue. | 2023-02-23 16:51:44.032
HD Request # 48 | Downloading Intraday chart data for MESH3.CME to the file MESH3.CME.scid. Service: cme | 2023-02-23 16:51:44.035
HD Request # 48 | Download start date-time: 2023-02-23 16:51:33.000000. File last date-time: 2023-02-23 16:51:33.779000 | 2023-02-23 16:51:44.036
HD Request # 48 | Using server: ds23.sierracharts.com port 10150 | 2023-02-23 16:51:44.036
Socket (7) | Creating socket. | 2023-02-23 16:51:44.083
Socket (7) | New receive buffer size: 5242880 | 2023-02-23 16:51:44.083
Socket (7) | Connecting to IP: 142.215.17.190. | 2023-02-23 16:51:44.083
Socket (6) | Socket gracefully closed by remote side. | 2023-02-23 16:51:44.104
Socket (6) | Closed. | 2023-02-23 16:51:44.104
HD Request # 48 | Setting DTC encoding to Binary VLS | 2023-02-23 16:51:44.322
HD Request # 48 | Sending historical data logon request message. | 2023-02-23 16:51:44.322
HD Request # 48 | Requesting Intraday data. Start date-time: 2023-02-23 16:51:33. Record interval: 0. Symbol: MESH23 | 2023-02-23 16:51:44.953
HD Request # 48 | Decompressing data. | 2023-02-23 16:51:45.067
HD Request # 48 | Receiving Intraday data for MESH3.CME starting at 2023-02-23 16:51:33.083000 | 2023-02-23 16:51:45.068
Socket (7) | CloseSocket call. | 2023-02-23 16:51:45.069
Socket (7) | Shutdown started. Waiting for graceful close. | 2023-02-23 16:51:45.069
Historical data download thread signaled to stop. | 2023-02-23 16:51:45.104
HD Request # 48 | Timestamp of first Intraday data file record written: 2023-02-23 16:51:33.849000. | 2023-02-23 16:51:45.104
HD Request # 48 | Received 217 Intraday data records from 2023-02-23 16:51:33.083000 to 2023-02-23 16:51:40.315000 (7.2 seconds) and wrote 175 records for MESH3.CME | 2023-02-23 16:51:45.104
HD Request # 48 | Add time&sales data | Remembered last file record date-time: 2023-02-23 15:51:40.315000 | 2023-02-23 16:51:45.105
Added 45 Time and Sales records to Intraday data file for MESH3.CME after download. | 2023-02-23 16:51:45.105
HD Request # 48 | Completion time: 1s. | 2023-02-23 16:51:45.105
HD Request # 48 | Intraday data download complete for MESH3.CME. Unique request ID: 48 | 2023-02-23 16:51:45.105
Removing historical data download ID 48. | 2023-02-23 16:51:45.105
Real-time Intraday chart data file updates started for MESH3.CME | 2023-02-23 16:51:45.105
Intraday chart data file opened for MESH3.CME | 2023-02-23 16:51:45.105
HD Request # 48 | Enabling Intraday chart updating for symbol. | 2023-02-23 16:51:45.105
Triggering next historical data download in queue. | 2023-02-23 16:51:45.106
HD Request # 49 | Downloading Intraday chart data for ESZ22 to the file ESZ22.scid. Service: rithmic_v2.trading | 2023-02-23 16:51:45.106
HD Request # 49 | Download start date-time: 2022-08-21 17:51:45.000000. File last date-time: 00:00:00.000000 | 2023-02-23 16:51:45.106
HD Request # 49 | Using server: rsc.rithmic.com port 50530. Use encryption. | 2023-02-23 16:51:45.106
Socket (6) | Creating socket. Using TLS 1.2. | 2023-02-23 16:51:45.106
Socket (6) | New receive buffer size: 5242880 | 2023-02-23 16:51:45.107
Socket (6) | Connecting to IP: 216.57.156.163. | 2023-02-23 16:51:45.107
Socket (7) | Socket gracefully closed by remote side. | 2023-02-23 16:51:45.183
Socket (7) | Closed. | 2023-02-23 16:51:45.183
HD Request # 49 | Sending historical data logon request message. | 2023-02-23 16:51:45.223
HD Request # 49 | Requesting Intraday data. Start date-time: 2022-08-21 17:51:45. Record interval: 0. Symbol: ESZ22 | 2023-02-23 16:51:45.577
Socket (6) | CloseSocket call. | 2023-02-23 16:51:45.691
Socket (6) | Shutdown started. Waiting for graceful close. | 2023-02-23 16:51:45.691
HD Request # 49 | Error downloading historical Intraday data for ESZ22. Exchange not specified | 2023-02-23 16:51:45.720
Historical data download thread signaled to stop. | 2023-02-23 16:51:45.720
HD Request # 49 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for ESZ22 | 2023-02-23 16:51:45.720
HD Request # 49 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2023-02-23 16:51:45.721
HD Request # 49 | Completion time: 0s. | 2023-02-23 16:51:45.721
HD Request # 49 | Intraday data download complete for ESZ22. Unique request ID: 49 | 2023-02-23 16:51:45.721
Removing historical data download ID 49. | 2023-02-23 16:51:45.721
Real-time Intraday chart data file updates started for ESZ22 | 2023-02-23 16:51:45.721
Intraday chart data file opened for ESZ22 | 2023-02-23 16:51:45.721
HD Request # 49 | Enabling Intraday chart updating for symbol. | 2023-02-23 16:51:45.721
Triggering next historical data download in queue. | 2023-02-23 16:51:45.721
HD Request # 50 | Downloading Intraday chart data for ESH3.CME to the file ESH3.CME.scid. Service: cme | 2023-02-23 16:51:45.721
HD Request # 50 | Download start date-time: 2023-02-23 16:51:33.000000. File last date-time: 2023-02-23 16:51:33.814002 | 2023-02-23 16:51:45.721
HD Request # 50 | Using server: ds26.sierracharts.com port 10150 | 2023-02-23 16:51:45.721
Socket (7) | Creating socket. | 2023-02-23 16:51:45.722
Socket (7) | New receive buffer size: 5242880 | 2023-02-23 16:51:45.722
Socket (7) | Connecting to IP: 142.215.17.188. | 2023-02-23 16:51:45.722
Socket (6) | Socket gracefully closed by remote side. | 2023-02-23 16:51:45.805
Socket (6) | Closed. | 2023-02-23 16:51:45.805
HD Request # 50 | Setting DTC encoding to Binary VLS | 2023-02-23 16:51:45.953
HD Request # 50 | Sending historical data logon request message. | 2023-02-23 16:51:45.953
Opened cached Intraday file: C:\SierraChart\Data\MYMH3.CBOT.scid. Thread ID: 70332 | 2023-02-23 16:51:46.125
Opened cached Intraday file: C:\SierraChart\Data\MESH3.CME.scid. Thread ID: 70332 | 2023-02-23 16:51:46.125
HD Request # 50 | Requesting Intraday data. Start date-time: 2023-02-23 16:51:33. Record interval: 0. Symbol: ESH23 | 2023-02-23 16:51:46.577
HD Request # 50 | Decompressing data. | 2023-02-23 16:51:46.690
HD Request # 50 | Receiving Intraday data for ESH3.CME starting at 2023-02-23 16:51:33.102000 | 2023-02-23 16:51:46.691
Socket (7) | CloseSocket call. | 2023-02-23 16:51:46.692
Socket (7) | Shutdown started. Waiting for graceful close. | 2023-02-23 16:51:46.692
Historical data download thread signaled to stop. | 2023-02-23 16:51:46.718
HD Request # 50 | Timestamp of first Intraday data file record written: 2023-02-23 16:51:33.825000. | 2023-02-23 16:51:46.718
HD Request # 50 | Received 534 Intraday data records from 2023-02-23 16:51:33.102000 to 2023-02-23 16:51:44.891001 (11.8 seconds) and wrote 503 records for ESH3.CME | 2023-02-23 16:51:46.718
HD Request # 50 | Add time&sales data | Remembered last file record date-time: 2023-02-23 15:51:44.891001 | 2023-02-23 16:51:46.719
Added 55 Time and Sales records to Intraday data file for ESH3.CME after download. | 2023-02-23 16:51:46.719
HD Request # 50 | Completion time: 1s. | 2023-02-23 16:51:46.719
HD Request # 50 | Intraday data download complete for ESH3.CME. Unique request ID: 50 | 2023-02-23 16:51:46.719
Removing historical data download ID 50. | 2023-02-23 16:51:46.719
Real-time Intraday chart data file updates started for ESH3.CME | 2023-02-23 16:51:46.719
Intraday chart data file opened for ESH3.CME | 2023-02-23 16:51:46.719
HD Request # 50 | Enabling Intraday chart updating for symbol. | 2023-02-23 16:51:46.719
Triggering next historical data download in queue. | 2023-02-23 16:51:46.719
No download requests in the queue to start downloads for. | 2023-02-23 16:51:46.719
Socket (7) | Socket gracefully closed by remote side. | 2023-02-23 16:51:46.804
Socket (7) | Closed. | 2023-02-23 16:51:46.804
Opened cached Intraday file: C:\SierraChart\Data\ESH3.CME.scid. Thread ID: 70332 | 2023-02-23 16:51:51.168
HTTPS connection ID:11 to www.rithmic.com:443 for request ID:11 (6) | Creating socket. Using TLS 1.2. | 2023-02-23 16:51:57.464
HTTPS connection ID:11 to www.rithmic.com:443 for request ID:11 (6) | New receive buffer size: 32768 | 2023-02-23 16:51:57.464
HTTPS connection ID:11 to www.rithmic.com:443 for request ID:11 (6) | Connecting to IP: 38.79.0.89. | 2023-02-23 16:51:57.464
HTTPS connection ID:11 to www.rithmic.com:443 for request ID:11 (6) | New receive buffer size: 65536 | 2023-02-23 16:51:57.939
HTTPS connection ID:11 to www.rithmic.com:443 for request ID:11 (6) | Socket gracefully closed by remote side. | 2023-02-23 16:51:58.099
HTTPS connection ID:11 to www.rithmic.com:443 for request ID:11 (6) | CloseSocket call. | 2023-02-23 16:51:58.100
HTTPS connection ID:11 to www.rithmic.com:443 for request ID:11 (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-02-23 16:51:58.100
HTTPS connection ID:11 to www.rithmic.com:443 for request ID:11 (6) | Closed. | 2023-02-23 16:51:58.100
DTC Client socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2023-02-23 16:53:35.838
DTC Client socket (2) | Closed. | 2023-02-23 16:53:35.838
DTC Client socket (3) | Timed out waiting for shutdown. Performing an immediate socket close. | 2023-02-23 16:53:35.838
DTC Client socket (3) | Closed. | 2023-02-23 16:53:35.838
DTC Client socket (2) | Deleting network socket now after delay. | 2023-02-23 16:54:05.852
DTC Client socket (3) | Deleting network socket now after delay. | 2023-02-23 16:54:05.852
