Date/Time: Tue, 22 Apr 2025 02:24:33 +0000
No data feed
View Count: 270
[2023-02-23 15:01:00] |
User556972 - Posts: 1 |
Hello, I have put my user name and password from amp and cqg but my charts won't load....
[2023-02-23 16:06:06] |
If you just changed your Current Selected Service to CQG from another setting, then you need to update the symbols in your chart. Each service uses a different set of symbols. Please open your Chartbooks and then select Edit >> Translate Symbols to Current Service and this should resolve your issue. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
