Date/Time: Tue, 26 Nov 2024 19:42:05 +0000
Average True Range - ATR study
View Count: 1278
[2014-06-12 13:39:17] |
mayerrs - Posts: 70 |
hi, i would like to set ATR study in dollars because it is much more faster information for me to know the average true range in dollars. is this somehow possible? thank you |
[2014-06-12 16:49:02] |
You could use the Study Subgraph-Multiply study and multiply it by the currency value per 1 full point. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s260 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
