Date/Time: Tue, 22 Apr 2025 02:24:37 +0000
Flex Renko
View Count: 576
[2023-02-23 01:46:04]
User509820 - Posts: 69
Hello, I am trying to get bars that look like images in the attachments. But have not been able to get it to work. Ningatrader was bars called NinzaRenko bars. Is there a way to get this using SC?
imageScreen Shot 2023-02-22 at 5.45.18 PM.png / V - Attached On 2023-02-23 01:45:41 UTC - Size: 263.38 KB - 146 views
imageScreen Shot 2023-02-22 at 5.39.13 PM.png / V - Attached On 2023-02-23 01:45:47 UTC - Size: 109.06 KB - 115 views
[2023-02-23 14:39:36]
John - SC Support - Posts: 39395
The image named "Screen Shot 2023-02-22 at 5.39.13 PM.png" is taken directly from our website. If you did not take it, you will find the image at the following link:
Renko Bar Charts: Examples
The page above gives all the information on Renko charts in Sierra Chart.
The example given should give you something close to what you are looking for (Flex Renko). You will have to work out the exact numbers you want for the Renko settings.
All of the information you need is on the page referenced above.
