Date/Time: Fri, 18 Oct 2024 04:17:16 +0000
[User Discussion] - Studies window
View Count: 364
[2023-02-22 20:11:48] |
User499894 - Posts: 45 |
Hi I wuold like to have the possibility of adding blank rows / some kind of separators in the list of "studies to graph" (right side of the studies window); This would make it possible to group studies in separate "families" easily traceable (something that is possible to do with buttons in control bars). Possible? |
[2024-07-09 07:54:39] |
cnev - Posts: 15 |
Or the ability to create study groups with a drop down menu option would be even better. Is this a consideration for the future?
[2024-07-09 11:42:26] |
Sierra_Chart Engineering - Posts: 16656 |
No, this is not supported or planned. The only thing possible is Study Collections.
[2024-07-10 00:02:03] |
ForgivingComputers.com - Posts: 947 |
Unless you are running out of settings, you can create a dummy setting. SCInputRef Line = sc.Input[0];
andLine.Name = "------------ Section Line -----------------";
Line.SetString(""); |
