Date/Time: Tue, 22 Apr 2025 02:27:41 +0000
Control size of delta profile within the volume profile?
View Count: 401
[2023-02-22 19:27:59] |
TopGunTrader - Posts: 191 |
Hi, I'm curious if volume by price has option, I can't find it that lets me adjust how big the delta bar portion shows up, right now its very small on right side want it 2-3x bigger. Or if I create a separate Delta Profile is there an option somewhere to put the volume profile behind it so delta is over top of volume profile? If I add two profiles now they are side by side. |
[2023-02-22 21:13:21] |
Refer to the following Input: Volume By Price Study: Draw Difference of Bid and Ask Volume Using Percent of Max Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-23 11:22:41] |
Fantastic!!
