Date/Time: Tue, 22 Apr 2025 07:08:35 +0000
Automate trade window
View Count: 535
[2023-02-22 15:44:03]
Hopeman - Posts: 166
I would like to know if it is possible to automate the selection of Trade window strategies. My intention is to vary the stop and target according to volatility
thank you
[2023-02-22 20:50:34]
John - SC Support - Posts: 39395
We are not exactly sure what you are asking for, but you can setup keyboard shortcuts or control bar options to change the Trade Window Configurations.
You can also change the Trade Window configuration through a Custom study. Refer to the following:
ACSIL Interface Members - Variables and Arrays: sc.TradeWindowConfigFileName
Date Time Of Last Edit: 2023-02-27 09:50:14
[2023-02-22 22:16:43]
Sawtooth - Posts: 4209
You can also change the Trade Window configuration using the Spreadsheet System for Trading study, in cell J112.
[2023-02-23 05:15:46]
Hi @tomgilb
I need to choose through the spreadsheet the different configuration of the trade window depending on the states of the market one or the other. Is this possible?
Date Time Of Last Edit: 2023-02-24 16:42:07
[2023-02-27 09:49:49]
Sierra_Chart Engineering - Posts: 19293
Yes you can use the spreadsheet IF function to accomplish something like this.
[2023-02-27 12:58:46]
Use a formula like this in cell J112:
=IF(J1=1,"Seahawk.twconfig",IF(J1=2,"SimpleBracket.twconfig",0))
Date Time Of Last Edit: 2023-03-02 15:24:23
[2023-03-02 15:09:46]
Thank you @Tomgilb
