Date/Time: Mon, 21 Apr 2025 23:36:07 +0000
No C++ build output messages
View Count: 537
[2023-02-22 15:09:13] |
tecman240 - Posts: 16 |
Nothing appears in the "Build Output" window when I try to build a custom study. There is no Build Output text from either "Build>>Remote" or from "Build>>Build Visual C++ Release". If there are no compile errors, both remote and local build will successfully create the dll that can be used to attach the study to a chart. If there are compile errors, the Build Output window stays blank and the dll doesn't get created. How do I get the build output to appear in the Build Output window? thanks. |
[2023-02-22 15:16:58] |
Sierra_Chart Engineering - Posts: 19290 |
This might be a color settings issue. Refer to: Graphics Settings: Setting the Background Color, Text Color, and Font for Text Only Windows Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-22 15:37:07] |
The documentation we gave is not accurate regarding this. We have to check on how those colors are set.
[2023-02-22 15:44:27] |
I found the problem --- The popup window for the build needs to be made taller. Otherwise, the Build Output text window is only 1 line high so you only can see the last line which is a blank line. If possible, this issue could be resolved if SC could default that popup window height to be taller. thanks for the help. |
[2023-02-22 15:46:48] |
Ok but we will also make the colors controllable as well.
