Date/Time: Tue, 22 Apr 2025 02:18:41 +0000
Large volume indicator
View Count: 353
[2023-02-22 14:12:29] |
Vak412 - Posts: 4 |
Hello, im trying to make a heatmap on sierra but i can't use my large volume indicator it show no volume dots can you please help me? - ive tried removing it but the funny thing is that when i go studies>settings>subgraphs the drawstyle is on ignore so i tried to set it on visible but it automaticly turns back to ignore so maybe thats something ? |
[2023-02-22 19:44:48] |
Sierra_Chart Engineering - Posts: 19290 |
First thing to check is this: Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
