Date/Time: Tue, 26 Nov 2024 19:13:49 +0000
table of contents...
View Count: 1026
[2014-06-12 12:59:33]
User53765 - Posts: 66
Hi Support,
Upon reviewing the daily pivot points on the table of contents, can I ask if its possible to label formula 14 in the list of pivot point formulas as the floor pivots please.
I believe they are the correct floor pivot points but would appreciate the reference like other types of pivot points at the start of the head section.
Thanks in advance.
[2014-06-12 23:13:47]
We will make sure this is documented.
[2014-06-12 23:27:14]
Formula type 14 for the Pivot Points is documented here:
http://www.sierrachart.com/index.php?l=doc/doc_PivotPoints.html#PPFormulas
There was an error with the documentation for two of the support formulas. This has now been corrected.
[2014-06-12 23:28:00]
As far as the particular type goes, we do not know. We are hesitant to be putting labels on these formulas.
