Date/Time: Mon, 21 Apr 2025 23:27:31 +0000
Binance Data - Historical ok RealTime KO
View Count: 316
[2023-02-22 09:46:32] |
User251043 - Posts: 47 |
Hi, BTCUSDT-BINANCE is down at the moment. Historical data loads (if I erase the chart it loads up until few minutes earlier), but realtime data is not working. Any information about when this can be solved? Thank you |
[2023-02-22 11:47:28] |
Sierra_Chart Engineering - Posts: 19290 |
Yes we have seen interruptions on and off, over the last about 10 hours or so. All of the Binance data feeds are working now. Are you still noticing any issue? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-22 12:04:27] |
No more issues now, thanks.
