Date/Time: Tue, 22 Apr 2025 02:21:38 +0000
About purchasing HKFE real-time data
View Count: 501
[2023-02-22 05:28:18] |
User806728 - Posts: 5 |
Hello, I would like to purchase real-time data of HKFE for one month. Is the data purchased today valid for one month from today?
[2023-02-22 20:08:16] |
The exchanges work on a Calendar month basis and are not pro-rated. Therefore, if you activate the exchange today, you will have access through the rest of the month, but you will pay the full amount. With the HKFE exchange, you need to also pay for the Sierra Chart Connectivity Fee. This is $25.00 per month and also works on a Calendar month basis, but it is pro-rated, so you will not pay the full amount if you activate it today. Follow the instructions at the following link to set this up: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
