Date/Time: Mon, 15 Dec 2025 09:11:48 +0000
stream activation new version sierra
View Count: 475
[2023-02-21 21:54:46]
User121377 - Posts: 6
hello, I did the sierra update and now and can't connect to the DINALI stream, the CQG does not work anymore? what and how to do?
[2023-02-21 22:49:10]
John - SC Support - Posts: 43443
We are not sure what you mean by "the CQG does not work anymore". We see that you have a verified your trading account through March 22, 2023, so you are good in this respect.
Also, there is a current issue with CQG order routing right now, so that could be what you are referring to.
But, you do not have any exchanges activated for the CME Group. You can activate the exchange(s) you need here:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
[2023-02-22 09:18:27]
Sierra_Chart Engineering - Posts: 21843
Since Sierra Chart does not support the CME Group and EUREX data from CQG you need to activate the exchanges you require here:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliExchangeDataFeed
And get the data from our Denali Data Feed.
