Date/Time: Mon, 21 Apr 2025 23:27:29 +0000
pending orders sitting there won't cancel
View Count: 396
[2023-02-21 21:50:54]
User460561 - Posts: 5
Hi, I'm trying to reach Amp Futures and cant get through. Not sure what's happening where this glitch is coming from but I have 2 order that went in, they're pending and they won't fill and a I can't cancel them. What do I do???
[2023-02-21 22:33:43]
John - SC Support - Posts: 39395
There is an issue with CQG. There is nothing we can do. You need to wait for your broker to deal with the situation.
[2023-02-22 00:01:39]
Sierra_Chart Engineering - Posts: 19290
We see you are using CQG. This is an issue with CQG. You need to contact your broker about this problem.
If you use Teton order routing you will not have this issue:
