Date/Time: Mon, 21 Apr 2025 23:30:20 +0000
Chart fills not showing
View Count: 403
[2023-02-21 18:26:34]
StephenL - Posts: 120
Hi guys,
Can you see any reason why my chart fills are not showing correctly in the screenshot provided?
imageCapture.JPG / V - Attached On 2023-02-21 18:26:20 UTC - Size: 221.33 KB - 96 views
[2023-02-21 18:28:29]
bit more info this screenshot, let me know if i can send a more clear one.
imageCapture.JPG / V - Attached On 2023-02-21 18:28:24 UTC - Size: 95.38 KB - 92 views
[2023-02-21 18:55:42]
ivory - Posts: 95
Last time I had issues with order fills markers on charts, I was manually removing some trades from the trade log and I removed the entry without all matching exits, breaking the order matching system. Hope that helps.
[2023-02-22 14:26:36]
Sierra_Chart Engineering - Posts: 19290
What is the price of the fill as it is shown in the Trade Activity Log?
[2023-02-22 17:42:30]
Ah yes, I see my error now you ask that question. Thank you.
