Date/Time: Fri, 22 Nov 2024 21:13:00 +0000
Flatten position - emergency situation
View Count: 554
[2023-02-21 18:08:41] |
User887126 - Posts: 66 |
Hi SC team, I am trying to build in some safety function for my automated trading system. What is the best practice to manage open trades and flatten open positions/orders in case of internet disconnect, electrical issue, etc. please advise. |
[2023-02-21 18:14:52] |
John - SC Support - Posts: 36236 |
Call your broker.
[2023-02-22 09:15:54] |
Sierra_Chart Engineering - Posts: 17145 |
We see you are using Teton order routing, so in this case you just need to use the Teton order routing web-based control panel on your Mobile device: Sierra Chart Teton Futures Order Routing: Web-Based Trading Panel Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-25 20:23:15] |
SC team, do you plan to develop an android/iphone app for sierra chart in the near future? |
[2024-09-25 21:34:01] |
We can definitely say that this will not happen in the near future, as there are too many other things we need to do.
