Date/Time: Mon, 21 Apr 2025 23:36:10 +0000
Canadian Stocks
View Count: 450
[2023-02-21 17:57:36] |
Dan the Man - Posts: 92 |
Hi John, When using SC Data- All Services for charting Canadian Stock (SU.TO as an example), I am not receiving delayed intraday data. In the attached chart it is about 3 months delayed. "Use number of days to load" is selected in the Chart setting but it seems to default to "Date Range in File to" for the chart end date I can not change the "Date Range in File to" as it is greyed out. Any ideas? Regards, Dan |
[2023-02-21 18:14:20] |
We do not offer the Toronto Stock Exchange any longer. So any data you get is just a bonus from our old provider. We are surprised you got any data all. You would need to find a different data source for that data. You can try IQFeed - refer to the following: DTN IQ Feed Data Service If you do find another source, then it is best to have a separate installation of Sierra Chart for that data. Refer to the following for how to install a second Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
