Date/Time: Tue, 26 Nov 2024 20:02:17 +0000
increase value/label size
View Count: 1333
[2014-06-12 08:40:30] |
Dom7364 - Posts: 257 |
Is there a way to increase the size of the Value Label & name Label in the Setings & Inputs tab? Thanks |
[2014-06-12 08:55:59] |
This is controlled through the Chart Text Font set through Global Settings >> Graphics Settings. You can also individually control this for a specific chart. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_GraphicsSettings.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-12 09:05:07] |
Thanks, it can't be independently increased then, if I increase the font, it increases everything including scale figures font size, etc...?
Date Time Of Last Edit: 2014-06-12 09:25:07
[2014-06-12 16:58:32] |
Yes.
