Date/Time: Mon, 21 Apr 2025 23:27:32 +0000
Alert for different values on same subgraph
View Count: 269
[2023-02-21 13:57:04]
dberliner - Posts: 16
I want to create an alert when a certain value of a subgraph closes above a certain number, say 20, but not over 40. If at 40 or over , I want a different alert sound for the same subgraph. Is that possible to create?
[2023-02-21 17:28:07]
John - SC Support - Posts: 39395
You would have to create multiple alerts to do what you want. If you just need 2 alerts (20-40, and 40+) then you would put one alert in the Alert tab for the study and then put the other alert on the Alert tab for the Chart Settings.
