Date/Time: Tue, 22 Apr 2025 02:24:37 +0000
[Programming Help] - sc.GetSymbolDataValue AND XLK-NQTV
View Count: 325
[2023-02-20 17:47:42]
PeteB - Posts: 17
Is this symbol supported for the function? I get IBM okay but zeroes for this one. Thanks
[2023-02-22 01:59:47]
PeteB - Posts: 17
So should I assume this symbol is simply not supported by the function? Thanks
[2023-02-23 15:48:28]
PeteB - Posts: 17
Please document which symbols are supported by this function so that, in the future, I can avoid writing code that cannot function. Thank You.
