Date/Time: Mon, 21 Apr 2025 23:33:11 +0000
60 ticks candles not loading correctly
View Count: 399
[2023-02-20 16:21:26]
User573977 - Posts: 8
Hi guys.
I am using an ES 60T as you can see in the attached image.
The problem is that some candles are smaller than 60T.
I appreciate any feedback.
Thanks in advance.
https://www.sierrachart.com/image.php?Image=1676909959915.png
[2023-02-20 16:34:57]
User431178 - Posts: 654
Disable New Bar at Session Start, the small candle you have marked are around the session start/end times.
Chart Settings: New Bar at Session Start (Chart >> Chart Settings >> Session Times >> Intraday Chart Session Times menu)
[2023-02-20 21:59:20]
John - SC Support - Posts: 39395
Also, refer to the information for Range Bars - Standard here:
Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Range Per Bar - Standard (in ticks) (Chart >> Chart Settings menu)
You may want to consider using the Range Bars - True instead (if you are not already). Refer to the following:
Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Range Per Bar - True (in ticks)
