Date/Time: Mon, 21 Apr 2025 23:36:06 +0000
Best combo for highest quality Numbers Bars
View Count: 375
[2023-02-20 16:05:28] |
User912281 - Posts: 18 |
Hello. I apologize for needing to ask this but my search came up blank with my specific question. I trade exclusively futures and heavily lean on the Numbers Bars for my trading method. I use Service Package 11 in conjunction with Denali as my datafeed and AMP Futures as my broker. I want the highest quality data for the Numbers Bars / Footprints. What should I be using as my Current Selected Service? It is currently set to CQG WebAPI. Thank you in advance for your assistance! |
[2023-02-20 21:51:14] |
You are already doing what you need. You are getting the data from our Denali Exchange Data Feed, and as long as you have the data set to come in as 1 tick data, then that is the best you can do. Refer to the following setting and ensure it is set to 1 tick: Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings) You need to keep your Current Selected Service set to CQG WebAPI as that is your trading service. You are still getting the data from our Denali Exchange Data Feed. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
