Date/Time: Mon, 21 Apr 2025 23:33:13 +0000
Time Price Opportunity (TPO) Profile Charts - Opening Price
View Count: 309
[2023-02-20 16:04:06] |
User513390 - Posts: 49 |
Dear Support. I've tried to look around but did not find the answer. I was wondering how can I change the Opening Price TPO to "O" instead "A" Color in the Open Marker Color (Subgraph 18). I'm color blind so it would be easier for me to find the correct opening price on the (TPO) Profile Charts. Thanks for your support |
[2023-02-20 21:48:17] |
You can change the color of the Open Marker by changing the color of the subgraph for Open Marker Color. Refer to the following for how to change a Subgraph color: Chart Studies: Subgraphs Tab >> Color For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
