Date/Time: Mon, 21 Apr 2025 23:36:09 +0000
How to retrieve chart studies S_ID with ACSIL ?
View Count: 450
[2023-02-20 16:01:03] |
Trader & Sierra++ developer - Posts: 110 |
Hi Sierra, When listing chart studies using ACSIL, i can get their ID and name, but I can't find any way to retrieve their type (what is called S_ID). Is it possible and how ? Otherwise, could you please implement such a function ? Something like GetStudyTypeUsingID() Thank you |
[2023-02-20 17:08:33] |
Sierra_Chart Engineering - Posts: 19290 |
S_ID is the internal identifier of the study. It might be not too difficult for us to give you the ability to get the internal identifier of a particular study on the chart but not any other. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-20 17:43:33] |
Thank you. To ensure I understand your answer : would that be through a new ACSIL function that takes chartNumber and StudyID as parameters, and returns the S_ID ? Or some other way ? |
