Date/Time: Mon, 21 Apr 2025 23:30:21 +0000
connect rithmic
View Count: 304
[2023-02-20 15:25:09] |
User492599 - Posts: 2 |
Hello I contact you because I did not succeed in connecting with Rithmic
[2023-02-20 17:07:05] |
Sierra_Chart Engineering - Posts: 19290 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed: Select "File >> Disconnect" Select "File >> Connect to Data Feed" After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
